OFFICIAL Samsung 4k HU8550 and HU9000 thread - Page 88 - AVS Forum | Home Theater Discussions And Reviews
 4650Likes
post #2611 of 21979 Old 07-06-2014, 07:36 PM
doctorwizz's Avatar
Quoted: 730 Post(s)
Liked: 229
Originally Posted by doctorwizz View Post
You can change the sync on the TV
Press, menu, sound, additonal settings, Audio Delay <--- Turn the audio delay way down. Default is 70. Mine is like close to zero for NF.
Made a mistake. I wasn't home when I wrote that. The default audio delay is 230ms. I had it at 40. Not near zero.
Auto lip sync on my Denon 3312 AVR does not work for Netflix app on the smart hub with ARC. I have to set the audio delay on the TV to 40 for good lip sync on Netflix.
My TV does not have any auto lip sync feature. TheHU9000 has it?
doctorwizz is offline
post #2612 of 21979 Old 07-06-2014, 07:46 PM
DeanS's Avatar
Quoted: 28 Post(s)
Well I finally pulled this 65-inch monster out of the box and got it set up. Just now fooling around with picture settings. I got a good panel - no light leakage at the corners, no cloudy or dark spots and no banding. Yeah.
4K looks spectacular. I got this content from Youtube and it looks great. The blacks are also suprisingly good for an LCD panel. But the biggest surprise of all was the set's OTA tuner and its sensitivity. It pulled in all of the stations from Mt. Wilson, including stations I NEVER was able to get such as ABC 7.1 and KCOP 13.1 at my location. No other tuner captured these, including Sony and DTV tuners. Way to go Samsung!!!
doctorwizz likes this.
DeanS is offline
post #2613 of 21979 Old 07-06-2014, 08:59 PM
FirNaTine's Avatar
Soap Opera
Anyone know what picture settings get you the soap opera effect? I've been wanting to try and switch between the two to see what I really like.
FirNaTine is offline
post #2614 of 21979 Old 07-06-2014, 09:11 PM
rlb
rlb's Avatar
Quoted: 1701 Post(s)
Liked: 1354
Originally Posted by baddceo View Post
There is lypsync feature on the tv as we'll.
Sent from my iPad using Tapatalk HD
If by any case, you are using optical digital, automatic sync features don't work. Must be HDMI 1.3 or higher.
rlb is offline
post #2615 of 21979 Old 07-07-2014, 12:31 AM
thewayacts92's Avatar
Quoted: 96 Post(s)
Liked: 38
Red face Great Deal!!
Hey there, been reading this thread for the last few days. So, Best Buy exchanged my 55C8000. I decided to upgrade and went with the 60" 8550 and only paid the difference of $850 with taxes. I thought it was a deal considering my set was 4 years old and I had set up an appointment with Geek Squad the very last day before the warranty expired . At first I thought the C8000 looked much better but after playing with the settings I'm blown away. So glad to own this set. I've had it for three days it's keeping me up until 3 or 4am just so I can keep enjoying how awesome the picture is. I noticed a huge difference from my old set streaming on Netflix (PS3) HD content. I had my doubts but it does a great job upscaling.
I have made it my goal to just enjoy this set. It is really a lot easier to enjoy it than to try to finds faults in it although it all looks great
thewayacts92 is offline
post #2616 of 21979 Old 07-07-2014, 01:52 AM
DELTAsnake's Avatar
Quoted: 45 Post(s)
I have a couple of pairs of SSG-3500CR's which are officially only compatible with the D and E gen TV's. I used them with my F8500 but had some issues. Anyone know if they will work with my HU9000 when it turns up or should I go order some newer rechargeable 3D glasses?
Samsung UA55HU9000, Samsung HW-J7500, Xbox One, PS4, Wii U. Plus a bunch of old consoles.
XBL: DELTAprime, PSN: DELTAsnake, Wii U: DELTAprime
DELTAsnake is offline
post #2617 of 21979 Old 07-07-2014, 04:56 AM
doctorwizz's Avatar
Quoted: 730 Post(s)
Liked: 229
Use a custom setting under Auto Motion Plus. Set blur at 10 and judder at 5. You will get too much judder at zero. Anything higher than 5 can give the soap opera effect.
post #2618 of 21979 Old 07-07-2014, 05:06 AM
Stonedcl's Avatar
Quoted: 51 Post(s)
I was wondering if anyone has any dead pixels on there 8550.
I just noticed yesterday that the TV has 2-3 dead pixels close to each other. I only notice it on a pure white screen. I do not know what to do, my eye is now drawn to it. Has anyone had issues with dead pixel on there 8550? Will samsung come out and swap the TV or do I have to lug it back to the store? I really do not want to have to take it down , pack it up and take the risk of damaging it on the way to the store.
Stonedcl is offline
post #2619 of 21979 Old 07-07-2014, 05:30 AM
vddobrev's Avatar
Quoted: 83 Post(s)
Liked: 40
You have to check warranty policy, as to the number and location of dead pixels, i.e. center, corner, etc.
vddobrev is offline
post #2620 of 21979 Old 07-07-2014, 05:31 AM
Quoted: 20 Post(s)
Liked: 1
Great to hear DeanS that your happy with your 8550
Which panel version do you have
JonyB is offline
post #2621 of 21979 Old 07-07-2014, 05:37 AM
Quoted: 20 Post(s)
Liked: 1
Originally Posted by JonyB View Post
Hey guys planning on buying a hu8550 65inch
Question is does anyone know how much wall clearance is recommended for it when wall mounting for ventilation etc (as I cannot find the answer in the online manual)
The wall mount I'm interested in is the Vogels thin305 which is 15mm from the wall
Luckily all the connections I need are on the side otherwise that would suck
Stupid samsung
Anyone have any idea ???
JonyB is offline
post #2622 of 21979 Old 07-07-2014, 06:09 AM
DELTAsnake's Avatar
Quoted: 45 Post(s)
Here in Australia I had a E8000 plasma and F8500 plasma replaced with only two dead pixels each. Apparently Samsung over here believes in zero dead pixels on high end displays (I personally can live with dark dead pixels, but not bright stuck pixels). It's worth calling your countries Samsung customer support number and discussing it with them.
Samsung's own Mini Wall Mount Kit puts the TV really close to the wall, less than an inch at off the wall. I'd go with that as a minimum, but more for cabling than airflow.
Last edited by DELTAsnake; 07-07-2014 at 06:25 AM. Reason: Adding answer for other user.
post #2623 of 21979 Old 07-07-2014, 08:21 AM
sikclown's Avatar
Quoted: 1377 Post(s)
Liked: 691
Worth noting the HU8550's ARC HDMI port is on the back of the TV vs side back so flush mounting is difficult. I would recommend an HDMI cable with a 90 degree elbow if you aren't using the IR extender as it sits right under the HDMI input or a 270 degree if you are going to use the IR extender or just generally hate blocking any connections. If you look at a picture of the back of the 8550 you will see what I am talking about.
UN65F9000AFXZA + SEK3500u/za firmware version 1461
Denon AVR-X7200WA, Apple TV, UBD-K8500, PS4, Xbox One, Nvidia Sheild Pro, PC
(2) Klipsch RF-82IIs, (4)RS-52IIs,, (1)RP-450CA, (4) RP-140SA, (1) SVS PB12-Plus
Emotiva XPA-100, XPA-200, Emotiva A-700
UN55KS9000 firmware 1132,Denon x4200w, Apple TV, Panny BDT460, PC,
Nvidia Shield, Klipsch G-42,(2) R-3650-W-II,(4) RSL-C34E, SVS SB-1000, UPA-200
sikclown is offline
post #2624 of 21979 Old 07-07-2014, 08:35 AM
Phrawst's Avatar
Quoted: 104 Post(s)
Liked: 33
Man cave phase 1 complete. Behold! Camera on my phone sucks, I apologize.
ID:	151233   Click image for larger version
ID:	151241   Click image for larger version
ID:	151249   Click image for larger version
ID:	151257   Click image for larger version
Janibrewski, tanishq02 and Ahzari like this.
Phrawst is offline
post #2625 of 21979 Old 07-07-2014, 08:38 AM
Phrawst's Avatar
Quoted: 104 Post(s)
Liked: 33
Yeah I used a 90 degree port saver with my HDMI cable on that port when wall mounting mine. (See above post pics)
Phrawst is offline
post #2626 of 21979 Old 07-07-2014, 08:43 AM
doctorwizz's Avatar
Quoted: 730 Post(s)
Liked: 229
Nice Prawst! Nice and clean.
That AVR has no room to breathe.
post #2627 of 21979 Old 07-07-2014, 09:22 AM
Phrawst's Avatar
Quoted: 104 Post(s)
Liked: 33
Yeaaaaah I'm a little worried about that. I've stuck my hand in that bay and its not too warm in there. The warmest bays are the one with the Xbox One and the Cable Box. (why does a cable box put out so much heat??)
But yeah if there's a low noise cooling solution anyone knows of I'd love to hear about it. I could just make the hole in the back of the unit even bigger to allow for more venting.. though the thought of unhooking the AVR makes me cringe. Was so much work!
Phrawst is offline
post #2628 of 21979 Old 07-07-2014, 09:24 AM
jbug's Avatar
Quoted: 248 Post(s)
Liked: 127
Samsung doesn't treart OTA TV like a step child. Sony and Panasonic skimp on features for OTA TV. Samsung lets you see what programs are showing down the road for example where the other manufactures don't and has other features the others don't.
jbug is offline
post #2629 of 21979 Old 07-07-2014, 09:37 AM
Mrorange303's Avatar
Quoted: 1199 Post(s)
Liked: 355
Standard is a clean soap effect.
Smooth is a tiny bit sharper than standard but has small ghosting.
Clear and custom with led engaged will give little to no soap effect.
Custom is as mentioned in previous post.
I use standard.
Mrorange303 is offline
post #2630 of 21979 Old 07-07-2014, 10:11 AM
Ohiojosh78's Avatar
Hi all.
I'm coming from aa defective F8000 which samsung exchanged for an HU8550. I am concerned that I have a defective unit again for 2 reasons. First of all Netflix does not load up. As soon as I click on the icon the screen goes black but does not load up. Secondly I can not get the brightness anywhere close to what my F8000 could do.
Thanks for your replies ahead of time.
Ohiojosh78 is offline
post #2631 of 21979 Old 07-07-2014, 10:48 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 1975 Post(s)
Liked: 2140
Sometimes those extended warranties are worth the cost
thewayacts92 likes this.
Cleveland Plasma is offline
post #2632 of 21979 Old 07-07-2014, 10:58 AM
Stonedcl's Avatar
Quoted: 51 Post(s)
I am having a guy from PC Richards looking at it on Wednesday. I called my friends that sold me the TV and he said to call PC Richards instead of Samsung to have them come out. He also asked me if I had the box and told me to just return it but It is heavy and I have it mounted and secured to the way and do not want to go through trying to get it to the store without damaging it. If the tech says they will not replace it then I will exchange it to the store.. I feel bad going through PC Richards because this is a Samsung issue not PC Richards but my friend who is the manager at C Richards said they will return it to Samsung.
Stonedcl is offline
post #2633 of 21979 Old 07-07-2014, 12:55 PM
Quoted: 96 Post(s)
Liked: 38
Indeed they are. I almost did not care but before leaving home the day before the warranty expired I thought "I should just set up an appointment and see if they still can do something". My C8000 had some clouding that I lived up with for two years. So, paying that $ difference for 5" more, plus 4k when I almost did not care was definitely an excellent feeling.
By the way, Best Buy service was excellent at my local store. I was not expecting that at all. I thought I would walk out with a H7150 and maybe I could pay the difference to get the 55H8000. So I'm digging it!
post #2634 of 21979 Old 07-07-2014, 01:07 PM
rlb
rlb's Avatar
Liked: 1354
I bought one with a Sony XBR1 (SXRD) and during the term of the extended warranty they replaced the light engine three times. Don't know what it really cost; but the paperwork they gave me each time showed that it would have cost around $2,000 per repair. They also replaced a couple other parts.
That was my first ever purchase of an extended warranty. I lucked out; but now I'm a believer!
rlb is offline
post #2635 of 21979 Old 07-07-2014, 01:53 PM
NickB123's Avatar
Quoted: 46 Post(s)
Liked: 25
I have never once purchased an extended warranty. I have on occasion needed to replace something after the warranty expired, but by turning down all of them I have more then made out...it is after all, how insurance companies make their money.
NickB123 is offline
post #2636 of 21979 Old 07-07-2014, 02:18 PM
Roberyu's Avatar
Quoted: 18 Post(s)
Liked: 24
Sony extended the SXRD customer warranty coverage due to the light engine defect. I had Sony replace the light engine twice in my SXRD, at no cost to me, all substantially outside of the original warranty period.
I don't think your extended warranty paid a dime for those light engine replacements, and they likely got Sony to fix it as it was a well-known and well-documented product design defect.
Roberyu is offline
post #2637 of 21979 Old 07-07-2014, 03:03 PM
rlb
rlb's Avatar
Liked: 1354
I had forgotten that; but I'm sure you are right; and it's probably why Sears was always so happy to come out and do it. Unfortunately, I had a professional calibration on the original and first replacement. Finally realized that was throwing money away. Bought a meter and software and "hacked" my way through calibrations on the last two.
For my primary HD TV, I've had a Mitsubishi RPTV, a Sony XBR1, a Panasonic vt25 plasma, and now a Samsung F9000. The Sony was the most expensive and most disappointing.
rlb is offline
post #2638 of 21979 Old 07-07-2014, 03:48 PM
lgroveman's Avatar
Quoted: 80 Post(s)
Liked: 29
If you use an AMEX card they double the warranty up to an additional year for no charge.
lgroveman is offline
post #2639 of 21979 Old 07-08-2014, 12:18 AM
vddobrev's Avatar
Quoted: 83 Post(s)
Liked: 40
Is the warranty 1 year in the US? It is 2 years in Europe.
vddobrev is offline
post #2640 of 21979 Old 07-08-2014, 01:48 AM
Ahzari's Avatar
Quoted: 52 Post(s)
Liked: 50
Yea 1 year here in the US. Some European markets have an advantage with warranties when it comes to electronics - but I think we end up saving some $ on the sale price so maybe it evens out in the long run..
Audio: Yamaha A-S1000 Stereo Amp // Kef LS50s // Dual JL Audio e112
Analog:Pro-Ject RM5.1SE Turntable // Pro-Ject Tube Box II SE Phono Amp // Pro-ject Speed Box II
Video: Samsung 65' HU9000 UHD // Oppo BDP-105 // Apple TV (4G - 64gb)
Power: Furman PST-8 AC Power Conditioner
Ahzari is offline
Reply LCD Flat Panel Displays
samsung u8550 , Samsung Un55c8000 55 Inch 1080p 240 Hz 3d Led Hdtv
