OFFICIAL Samsung 4k HU8550 and HU9000 thread - Page 89 - AVS Forum | Home Theater Discussions And Reviews
 4674Likes
post #2641 of 22062 Old 07-08-2014, 03:27 AM
vega509's Avatar
Quoted: 185 Post(s)
Liked: 55
Has anyone seen the 78" HU9000? How does it compare to the 65" model?
vega509 is offline
post #2642 of 22062 Old 07-08-2014, 05:11 AM
Dallas West's Avatar
Liked: 0
Hey guys,
I have a question about the HU and the one connect box. On my wall I only wired in power, ethernet and one HDMI. So I'm thinking now that my one connect box is going to have to be co-located at the TV given the one connect cable is a proprietary cable. Is there anyway to mount the one connect on the TV itself short of me getting some velcro? I'm really going for a clean finish on the wall and would hate to have the box laying around messing things up.
DeeDub
Dallas West is offline
post #2643 of 22062 Old 07-08-2014, 06:41 AM
Mrorange303's Avatar
Quoted: 1199 Post(s)
Liked: 355
Originally Posted by Dallas West View Post
Hey guys,
DeeDub
Just one thing of advice. Elevate the one connect box. I have my box about an inch off of the surface. The unit gets extremely hot. So where ever you put it make sure the one connect box is not flush. Not just laying on the surface or up on the wall.
Literally elevate the box. This will help with heat tremendously.
Mrorange303 is offline
post #2644 of 22062 Old 07-08-2014, 06:57 AM
NickB123's Avatar
Quoted: 59 Post(s)
Liked: 26
Originally Posted by lgroveman View Post
If you use an AMEX card they double the warranty up to an additional year for no charge.
Really? I just bought my 60HU8550 with an amex. fantastic!
NickB123 is offline
post #2645 of 22062 Old 07-08-2014, 08:54 AM
Phrawst's Avatar
Quoted: 126 Post(s)
Liked: 41
Hey guys,
So I'm using a 75HU8550 with a Onkyo TX-NR636. When running smart hub apps like Netflix and having the audio go over ARC to the receiver I'm not getting full surround sound. Just front speakers and bass. Any ideas why that would be happening? Not sure if its something with the TV or the receiver.
Also not getting surround sound via my cable box which is wired via: Cable box > xbox one hdmi in > xbox > onkyo avr > TV.
Phrawst is offline
post #2646 of 22062 Old 07-08-2014, 10:20 AM
ashepp's Avatar
Sonos Playbar and Purchasing a 65" 8550
Hi Folks,
I'm moving home and changing from my old Sony Projector / Onkyo receiver setup to a Samsung Samsung UN65HU8550 with Sonos Playbar, 2 x Play 3's and the Subwoofer.
Have a few questions for the guru's here.
1) PRICING - Seems to be a big variance between dealers. Amazon / Best Buy all seem to be in the $3297 range at the moment with online outlets quoting nearly a thousand cheaper. Has anyone had good success with one of these cheaper outlets or is it too good to be true?
2) SONOS QUALITY - While I'm not a music purist I am interested in those who have the 8550 set up as a surround system with the Sonos Playbar and 5.1 setup above. Am I going to notice a big difference from a dedicated setup using my Onkyo TX-SR608 Amp or is is negligible?
3) 5.1 pass through from HDMI to Optical? I believe that the 8550 passes through to the optical in of the Playbar but I think I also read that you want the component e.g. Xbox One for Bluray to pass through directly? Any clarification here appreciated.
4) Any alternatives to the 8500 I should consider?
Adam.
ashepp is offline
post #2647 of 22062 Old 07-08-2014, 10:24 AM
baddceo's Avatar
Quoted: 38 Post(s)
Originally Posted by Phrawst View Post
Hey guys,
While playing the content from Netflix or other apps go into TV menu sounds and switch it to DD.
baddceo is offline
post #2648 of 22062 Old 07-08-2014, 10:33 AM
sikclown's Avatar
Quoted: 1408 Post(s)
Liked: 715
Worth noting , the 8550 Netflix and Hulu Plus apps only output stereo right now. No clue when it will get fixed but the work around is to choose PCM and then let your receiver fake surround with Dolby PLIIx or DTS Neo6 if you have them. As far as the cable box goes, make sure you have it set to output Dolby in its setting menu. If it is PCM, most set top boxes and TVs only output two channel PCM.
UN65F9000AFXZA + SEK3500u/za firmware version 1461
Denon AVR-X7200WA, Apple TV, UBD-K8500, PS4, Xbox One, Nvidia Sheild Pro, PC
(2) Klipsch RF-82IIs, (4)RS-52IIs,, (1)RP-450CA, (4) RP-140SA, (1) SVS PB12-Plus
Emotiva XPA-100, XPA-200, Emotiva A-700
UN55KS9000 firmware 1132,Denon x4200w, Apple TV, Panny BDT460, PC,
Nvidia Shield, Klipsch G-42,(2) R-3650-W-II,(4) RSL-C34E, SVS SB-1000, UPA-200
sikclown is offline
post #2649 of 22062 Old 07-08-2014, 10:45 AM
Phrawst's Avatar
Quoted: 126 Post(s)
Liked: 41
Yeah that's already set. There is another option about dolby compression with Line and RL as options. What is that about?
Phrawst is offline
post #2650 of 22062 Old 07-08-2014, 10:47 AM
Phrawst's Avatar
Quoted: 126 Post(s)
Liked: 41
Ah well that explains that. Hopefully those apps get patched in the near future.
Phrawst is offline
post #2651 of 22062 Old 07-08-2014, 11:09 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 2805 Post(s)
Liked: 3002
Originally Posted by Roberyu View Post
Sony extended the SXRD customer warranty coverage due to the light engine defect. I had Sony replace the light engine twice in my SXRD, at no cost to me, all substantially outside of the original warranty period.
I don't think your extended warranty paid a dime for those light engine replacements, and they likely got Sony to fix it as it was a well-known and well-documented product design defect.
The SXRD was a huge lemon, some many issues with that light engine.
Some visa and mastercards offer, price watch, where if there is a price drop they will reimburse you the difference. Damage protection, if it gets damaged in the first 90 days, many other benefits as well.......all for free
Cleveland Plasma is offline
post #2652 of 22062 Old 07-08-2014, 12:03 PM
DeanS's Avatar
Quoted: 28 Post(s)
I checked the back of the set and found out that my 65-inch UHD8550 panel number is TS01. Presumably this is the "good" panel that was manufactured by Samsung. That may account for why I haven't seen any picture-related flaws. But I need to spend much more time in front of the set before making a final evaluation.
The first night viewing programming on this set (HBO programming from DTV) was an engaging but somehow strange experience. Then I found in this forum reference to what has been referred to as the "soap opera effect." Bingo. That is what the programs I watched had in common. It felt like you were watching some kind of direct broadcast of a daytime soap. The over realism of the picture made you think about each scenes' setup, whether a microphone would intrude into the picture from above etc.!! For others experiencing this effect, its easy to turn off and that is what I did last night. Problem solved.
Just a couple of additional thoughts/questions:
  1. I'm delighted with the OTA reception capabilities of the set but less so when I bring up the channel guide for my OTA stations - its abysmally slow.
  2. What is this "guage" that appears sometimes in the lower right-hand corner of the set? It appears briefly and then disappears. Seems related to LED in some way....
  3. In adjusting the volume on this set, each volume change is accompanyed by an annoying "boink" sound. There must be some way to turn this off.
The A/V cabinet/credenza comes Friday. That's when I will connect up my AV components. Should be interesting to see how it all works. I did reprogram my Harmony Remote for this new set as it still has way more capabilities as a universal remote that can control all of my equipment than the one that Samsung provided, IMHO. Thanks
DeanS is offline
post #2653 of 22062 Old 07-08-2014, 01:08 PM
NickB123's Avatar
Quoted: 59 Post(s)
Liked: 26
To add on to your questions.
When I pull up the Guide (The Samsung not Cable) why does it start on channel 2 (CBS) as opposed to the channel I'm actually on? This kind of makes it useless as I'm not going to page down to 502 (CBS HD). Is there any way to have this start where i'm actually at?
NickB123 is offline
post #2654 of 22062 Old 07-08-2014, 03:38 PM
baddceo's Avatar
Quoted: 38 Post(s)
The led gauge is telling you about its power consumption. The higher the gauge the more power is consuming all the way up into the grey range which is the older TV versions I believe. I think its related to the auto dimming function.
baddceo is offline
post #2655 of 22062 Old 07-08-2014, 04:04 PM
seansingh7326's Avatar
Quoted: 29 Post(s)
When using auto motion plus set to custom are you able to put led clear motion on and set your blur and judder setting? I have a h8000 and when I try to use that feature judder reduction and blur are blanked out.
seansingh7326 is offline
post #2656 of 22062 Old 07-08-2014, 05:12 PM
doctorwizz's Avatar
Quoted: 740 Post(s)
Liked: 236
I can't. Blur and judder are grayed out when turning on LED CM.
doctorwizz is online now
post #2657 of 22062 Old 07-08-2014, 06:38 PM
Quoted: 20 Post(s)
Liked: 1
Hey guys
Don't know who else to ask
What blu ray players do u guys recommended to get the best out of the 4k tv (8550)
Are there any under $200-300
Thank you
JonyB is offline
post #2658 of 22062 Old 07-08-2014, 06:55 PM
Bassplayer6's Avatar
Quoted: 418 Post(s)
Liked: 110
Originally Posted by JonyB View Post
Hey guys
Thank you
Oppo 103
Bassplayer6 is offline
post #2659 of 22062 Old 07-08-2014, 06:59 PM
sikclown's Avatar
Liked: 715
Hey guys
Thank you
I picked up a Sony BDP-S6200 for 179.00 from Amazon and love it. I don't use the 4K upscaling because the TV does a great job of that on it's own. It isn't as good as the Oppo 103 but the Oppo is 499.00.
sikclown is offline
post #2660 of 22062 Old 07-08-2014, 07:27 PM
Liked: 355
Hey guys
Thank you
The Panasonic bdt360 is $140 and has a picture above both the sony and samsung according to reviews. It has a better picture then both my ps4 and xbox 1.
I do not upscale. The tv is one of the best up scaler you have bought. Ever.
post #2661 of 22062 Old 07-08-2014, 07:48 PM
Janibrewski's Avatar
Quoted: 59 Post(s)
Liked: 41
Personally I hated the curve at 65", didn't mind it at 78". For me, the bigger the tv, the less the curve bothers me.
Janibrewski is offline
post #2662 of 22062 Old 07-08-2014, 09:52 PM
Quoted: 20 Post(s)
Liked: 1
Thanks for the suggestions so far regarding the blu ray players
Still not sure which one to get
I'm getting the vibe that most of them that say they have 4k upscalling have a setting in which you can choose to have 4k upscalling either on or off
Are you saying to have it off on the blu ray player and that the hu8550 will do a great job (better job) than the blu ray player
Including on reg DVDs also
And would it harm the picture to have it on aswell as the tv upscaling
Thanks for all the advice so far
JonyB is offline
post #2663 of 22062 Old 07-08-2014, 10:05 PM
sikclown's Avatar
Liked: 715
Well if you have the player upscale it the source will be 4k (essentially) so the TV won't further upscale it. There is no way to turn the TVs upscaling on and off, it is automatic on all sources lower than 4k.
sikclown is offline
post #2664 of 22062 Old 07-08-2014, 10:30 PM
Quoted: 20 Post(s)
Liked: 1
Thanks sikclown for the info
Yeah I had read that the tv upscalling doesn't t turn on and off and that it is perminantly on
I guess what I'm asking is it
A- better to get a blu ray player that doesn't even have 4k upscalling
B- better to get a blu ray player that has 4k upscalling and turn the upscalling off because the tv does a better job
C- better to get blu ray player with 4k upscalling and turn it on (guessing not this one from what u r saying)
Thanks to anyone who locks in an answer
JonyB is offline
post #2665 of 22062 Old 07-09-2014, 08:05 AM
smacrae's Avatar
I've got a TH01 panel on my HU8550...is that the same as a TS01??
smacrae is offline
post #2666 of 22062 Old 07-09-2014, 08:23 AM
sikclown's Avatar
Liked: 715
Personally I feel like the best bluray players available have 4k upscaling and 3D because they are the higher end of "insert manufacturer here"s line. What I mean is the Sony BDP-S6200 is the flagship Sony player for the US and will have the best picture quality, speed, features, etc in comparison to the rest of it's line. Those features include 4k upscaling and 3d. Panasonic, Samsung, etc will all be similar in my opinion.
I think what it comes down to is what do you really want? A premium player that you will not upgrade for quite some time? Something to use for now while actual 4K players get ironed out along with HDCP 2.2, etc? I know I am not answering your question directly but these are all the things I think of when going to buy a new Bluray. I bought my BDP-S6200 for my living room because Sony has yet to add 3D capability to the PS4 and my old 3D player was so slow. I bought the best player available for the price (in my opinion) and I was going to grab one for my bedroom since I put a 4K Samsung in there as well. But I have a Sony BDP-S590 in the bedroom that works perfectly fine, albeit much slower than the 6200, so I am going to wait for the next crop of players hopefully with HDMI 2.0, etc.
The main reason I recommend the BDP-S6200 is the dual core processor and the speed. The 4k upscaling is average to good but the TV just does it better. I would compare it with the Panasonic and a few other models without 4k upscaling to see which appeals to you. I was very close to pulling the trigger on a Panasonic BDT-460 or a BDT-360 but I am waiting to see if the 700 comes to the States (which I doubt it will).
sikclown is offline
post #2667 of 22062 Old 07-09-2014, 10:14 AM
baddceo's Avatar
Quoted: 38 Post(s)
Some users have experienced or introduced degradation in image quality by upscaling twice. While in theory if you upscaled that the player the tv shouldnt have to do it but it does anyway and that appears to cause issues.
baddceo is offline
post #2668 of 22062 Old 07-09-2014, 10:26 AM
sikclown's Avatar
Liked: 715
I am just guessing on this but I would think the only way the TV would upscale a 4k signal is if it isn't identifying itself as a 4k signal or if it wasn't producing a full 4k image. Perhaps the degradation of the image is due to the processing of the external device? Or perhaps these users have a receiver connected that is capable of 4K upscaling and it is turned on without their knowledge? I have a UN65F9000 and a UN55HU8550 and I have never experienced degradation when I have either my bluray or my reciever do the upscaling with the exception of when I first set up my s6200. It had color banding and flashing across the screen on occasion, come to find out I had 4k upscaling turned on in my receiver on that port so upscaling was happening twice before the TV received it. The image was getting distorted and was essentially "stepped on" too many times.
sikclown is offline
post #2669 of 22062 Old 07-09-2014, 10:45 AM
Liked: 355
The thing is the tv has a better up scaler. I'm sure Sony would too.
But not all 4k tv's will be made equal this year. Hisense. Vizio. Even sharp. Others. May not have a quality upscale solution so these players do have a purpose.
post #2670 of 22062 Old 07-09-2014, 11:08 AM
Phrawst's Avatar
Quoted: 126 Post(s)
Liked: 41
Right now I just use my xbox one for blurays. What are the major benefits moving from that to a dedicated BR player of some kind?
TV: Samsung 75HU8550 / SEK-3500U/ZA
AVR: Onkyo TX-NR676
Speakers: KEF T205
Devices: Xbox One S (X Coming Soon!), Nvidia Shield TV, Wii U, Cable Box, NES Classic
PC: Intel Core i5-4670K, 8GB GTX 1070, 500GB Samsung EVO SSD, 16GB DDR3
Phrawst is offline
Reply LCD Flat Panel Displays
samsung u8550 , Samsung Un55c8000 55 Inch 1080p 240 Hz 3d Led Hdtv
