OFFICIAL Samsung 4k HU8550 and HU9000 thread - Page 94 - AVS Forum | Home Theater Discussions And Reviews
 4679Likes
post #2791 of 22068 Old 07-12-2014, 08:52 PM
DELTAsnake's Avatar
Quoted: 46 Post(s)
Is it possible they are in a ramp up phase and some panels are 10 bit but not all of them? After all it is called the Samsung Panel Lottery for a reason.
Samsung UA55HU9000, Samsung HW-J7500, Xbox One, PS4, Wii U. Plus a bunch of old consoles.
XBL: DELTAprime, PSN: DELTAsnake, Wii U: DELTAprime
DELTAsnake is offline
post #2792 of 22068 Old 07-12-2014, 09:12 PM
Mrorange303's Avatar
Quoted: 1199 Post(s)
Liked: 355
I dont know. Ive googled. Cant.figure it out. Im not sending the email to ask. I don't even know where to start.
Mrorange303 is offline
post #2793 of 22068 Old 07-12-2014, 09:24 PM
Hisma's Avatar
Quoted: 550 Post(s)
Liked: 222
so, for anyone who wishes to use their 4K TV with an HTPC, I have done some extensive testing over the last few weeks with it.
It's been extremely frustrating, because I could never get the PQ or the motion handling (judder performance) to match my stand-alone cable box & blu-ray player. To top it off, there is literally no information on how to best optimize HTPC performance for 4K TVs. If you try to follow the current guides for 1080p sets, you will be very dissapointed with the performance.
Today I found the key to make it all work (and it sounds stupid simple, but it also somewhat defies logic). You have to run xbmc (or your favorite HTPC app) at native 4K resolution at 60 Hz for optimal video performance.
It defies logic, because for every other device, such as with receivers or oppos & the like, you are better off having the TV do all the upscaling, and disabling upscaling in the device, leaving the source content at it's native resolution. But this doesn't apply to HTPCs. I don't know why... I wish someone could come up with a technical explanation for it. But if you watch TV at 4K @ 60 Hz on your HTPC, the performance & PQ will be identical to a cable box. If you run it at 1080p or some other variant, you'll get bad judder, ghosting, and lower PQ.
Here's a thread I did on this subject in the HTPC section
Live TV PQ on my HTPC is inferior to PQ on my cable box
I don't think many other 8550/9000 owners are using a cablecard + hdhomerun setup for live TV like I am, but if you ever plan to, you'll find this info valuable.
Hisma is offline
post #2794 of 22068 Old 07-13-2014, 01:53 AM
seansingh7326's Avatar
Quoted: 29 Post(s)
Can any of the hu9000 owners tell me if your able to talk to the tv without using the remote? Like for example on the f8000 you can say hi tv and tell the tv what you want without using the remote. I wanted to know if the hu9000 had a wake on lan feature in which you can simply say hi tv power on or off and it comes on or off.
seansingh7326 is offline
post #2795 of 22068 Old 07-13-2014, 02:02 AM
Ahzari's Avatar
Quoted: 83 Post(s)
Liked: 56
I was hoping it did, but from everything I've read and tried on my set my understanding is you have to press the voice button on the remote before the recognition begins. Just saying a command wont do anything until the button is pressed.
Audio: Yamaha A-S3000/ Kef Reference 1/ JL Audio e112 (x2)
Video: LG 65E7P OLED/ Oppo BDP-205 UHD/ Apple TV (4G)
Analog: Pro-Ject RM5.1SE/ Pro-ject Speed Box II
Cables: Wireworld/ Pangea/ Blue Jeans Cables
Power: Furman PST-8 Power Conditioner
Ahzari is offline
post #2796 of 22068 Old 07-13-2014, 04:18 AM
DELTAsnake's Avatar
Quoted: 46 Post(s)
Yep thats my experience. I normally turn off those Kinect-like features in Samsung TV's but this time the voice part at least is built into the remote and you have to press the button on the remote to activate it.
post #2797 of 22068 Old 07-13-2014, 04:32 AM
Quoted: 20 Post(s)
Liked: 1
Hey guys would love some advice on which "budget" blu ray player I should buy
I've got the sony 6200, panasonic 360 and panasonic 460 (not sure what the differences are between the two panas) and the samsung h6500 all in the mix
Question is which one should I go for or am I missing any other players that should be in the mix in the same price range
All I care about is to get the best possible picture and audio
Not apps, features etc
Thanks in advance to anyone who could help out
JonyB is offline
post #2798 of 22068 Old 07-13-2014, 05:13 AM
rlb
rlb's Avatar
Quoted: 1787 Post(s)
Liked: 1458
Originally Posted by DELTAsnake View Post
I'm using UHD colour on my HU9000 no issues but I can't speak to the colour accuracy.
"UHD color" is applicable only to HDMI input of 4K/60 with 4:4:4 or 4:4:2 color. Don't believe there is anything capable at the moment of providing this via HDMI. When new PC video boards come out with HDMI 2.0, that will probably be the first source. Using it on anything else (if you can do it) would give you incorrect color.
rlb is offline
post #2799 of 22068 Old 07-13-2014, 06:41 AM
Liked: 355
All are good. Your only getting the 3d. Otherwise no gain I. Picture quality if you use 4k upscaling.
I have the panasonic bdt 360. I believe the 460 is the euro model for the 360 in the usa. Same player.
3d is better than 1080p bluray.
I also reccommend buyi m g some cheap batterys for your 3d glasses off of amazon. After you a 3d movie on this thing you will start buying those 3d copies.
Thank goodness I always tried to. I have a lot of 3d films.
So good.
post #2800 of 22068 Old 07-13-2014, 10:23 AM
sikclown's Avatar
Quoted: 1476 Post(s)
Liked: 734
So good.
The 360 and 460 are both on Panny's US website as well as on BestBuy.com. I have no idea what the main differences are but they are both available here.
LG OLED 65C7P, Denon AVR-X7200WA, Apple TV, Oppo UDP-203, PS4, Xbox One
Nvidia Sheild Pro, HTPC, (2) Klipsch RF-82IIs, (4)RS-52IIs,, (1)RP-450CA,
(4) RP-140SA, SVS PB12-Plus, Emotiva XPA-100, XPA-200, Emotiva A-700
UN55KS9000, Denon x4200w, Apple TV, Panny BDT460, HTPC,
Nvidia Shield, Klipsch G-42,(2) R-3650-W-II,(4) RSL-C34E, SVS SB-1000, UPA-200
sikclown is offline
post #2801 of 22068 Old 07-13-2014, 11:12 AM
Liked: 355
Isn't one just got more Hdmi inputs or something like that. Sorry when I bought my panny the 460 was not out yet. Only the 360.
However Europe had the 460 showing in stock. It did have more inputs but that was all from what I could tell.
I got my panny from bestbuy.
Simply the worst place for info.
I just looked. The 460 doesn't show for sale in the USA anywhere.
It is on the website for sure.
post #2802 of 22068 Old 07-13-2014, 11:20 AM
sikclown's Avatar
Liked: 734
BestBuy is the absolute worst for info. Hmmm an extra HDMI output on the 460 would make sense but if that is the only difference than the 360 is a crazy good deal (which it is anyway).
sikclown is offline
post #2803 of 22068 Old 07-13-2014, 11:25 AM
sikclown's Avatar
Liked: 734
http://www.bestbuy.com/site/panasoni...&skuId=5260151
BestBuy has it in stock and it does have 2 output, looks to be the only difference.
sikclown is offline
post #2804 of 22068 Old 07-13-2014, 12:08 PM
chris6878's Avatar
Quoted: 16 Post(s)
Samsung UN55HU8550
OK So the wife purchased this from her cousin last month brand new in box. the 55 inch. THe TV worked fine until today. I turned it on and I got a black and white screen split in two. I can hear the sound from the tv, but we get no picture.
I always buy my stuff from a store with ext warranty, but because this was a tv I was just gonna use to replace and old dlp in the kitchen, I didnt mind taking a chance on it. Plus it was priced right.
So now we have a Brand new TV with no picture. Im not really mad Cause My Panny Plasma is my main TV. WIfe IS mad cause she uses it, and she feels her cousin should do more to rectify the situation. Im not getting into it. But he knows thats the last thing we will ever buy from him, and Ill make sure he loses many more customers. Ive attached a pic. Any Ideas on fixing would be appreciated. Thanks
chris6878 is offline
post #2805 of 22068 Old 07-13-2014, 12:34 PM
sikclown's Avatar
Liked: 734
Originally Posted by chris6878 View Post
Samsung UN55HU8550
Is he an authorized Samsung dealer? You are still well within your warranty period. Try completely unplugging it from power completely. Also try hitting the 3D button on the remote, I don't think that will do anything but it might.
sikclown is offline
post #2806 of 22068 Old 07-13-2014, 12:38 PM
chris6878's Avatar
Quoted: 16 Post(s)
Naw he is not at all. He is the hood dealer. TV was probably stolen from a store. I knew I was taking a big chance
post #2807 of 22068 Old 07-13-2014, 12:40 PM
sikclown's Avatar
Liked: 734
Ahh gotcha. That sucks.
sikclown is offline
post #2808 of 22068 Old 07-13-2014, 01:10 PM
Liked: 355
Good find. Yeah not worth 50 more for sure.
post #2809 of 22068 Old 07-13-2014, 01:14 PM
sikclown's Avatar
Liked: 734
From a review on Techradar it also says it is the only Panny that handles 4K JPEG and it has an SD card reader. Does the 360? I went ahead and spend the extra on the 460 and ordered one so we can compare (I have a bunch of BestBuy credits to use up). I need a new Bluray for my bedroom UN55HU8550. I will hook up my Sony BDP-6200 and the 460 to it and compare.
sikclown is offline
post #2810 of 22068 Old 07-13-2014, 01:27 PM
Liked: 355
awesome. Yeah I know the bdt360 is the best player in the house and produces 3d super clean.
I do own a sony player thats a few years old and of course ps4 and xbox one.
But the panny is the best picture wise.
post #2811 of 22068 Old 07-13-2014, 01:38 PM
sikclown's Avatar
Liked: 734
The Panny will replace my 6200 in my living room if that is the case, which is absolutely possible as Panasonic and great image quality have always gone hand in hand in my experience. Sony's are more of a mixed bag but the 6200 is excellent.
sikclown is offline
post #2812 of 22068 Old 07-13-2014, 01:43 PM
al210's Avatar
Quoted: 221 Post(s)
Liked: 103
Interesting.
I'm using my 2 year old HTPC - Win 7 media center - Verizon FIOS cablecard with Ceton interface card. i3 processor with built in Intel HD graphics.
My picture is great and slightly sharper than my old plasma set it was previously hooked up to. Color is perfect and motion/ judder is fine.
LG 65EF9500 OLED -- Samsung K8500 4K Blu-Ray Player
Denon X4200W AVR & Rogue Audio Atlas Tube Amp
Vienna Acoustics Mozart Grand SE Speakers--B&W HTM62 Center--Axiom QS4 surrounds
PSB Imagine XA Atmos Speaker Addons -- SVS PB-1000 SUBWOOFER
Sony XBR43X800E 4K LCD - bedroom tv
al210 is offline
post #2813 of 22068 Old 07-13-2014, 02:03 PM
joeyvaz's Avatar
Quoted: 73 Post(s)
Liked: 30
Smart Hub has been working great all week. Today, I launch Smart Hub and go down to an app, and all I get is a black screen. The apps never launch. I tried resetting the Smart hub twice, but I am still having the same problem. Any thoughts?
joeyvaz is offline
post #2814 of 22068 Old 07-13-2014, 02:11 PM
traumadisaster's Avatar
Quoted: 91 Post(s)
I'm confused on the 8550 vs 9000 is that the same tv? It is $200 cheaper than the sony 50 inch 4k. I mostly use it to pc game at 4k. I dont care for the lg 4k and seiki i have. Any reason to spend 200 more for the sony? I'm looking at the best buy sale on the 8550 for $1800
traumadisaster is offline
post #2815 of 22068 Old 07-13-2014, 02:19 PM
joeyvaz's Avatar
Quoted: 73 Post(s)
Liked: 30
I reset the entire television and the Smart Hub is working again. I hope this is just a fluke and not something I or other will have ongoing problems with.
joeyvaz is offline
post #2816 of 22068 Old 07-13-2014, 02:27 PM
sikclown's Avatar
Liked: 734
That is what I was going to suggest doing. Hopefully it was just an App that got hung up and this doesn't happen again. Fingers crossed for you.
joeyvaz likes this.
sikclown is offline
post #2817 of 22068 Old 07-13-2014, 02:30 PM
sikclown's Avatar
Liked: 734
The HU8550 and HU9000 are not the same TV although many would argue that the only difference is the curve. The HU9000 is the Flagship model whereas the HU8550 is just a small step down, still a great TV. Which Sony model are you looking at? Where Sony wins most of the time is on Input lag which is not a strength of Samsung. Being a gamer, that may be important to you.
sikclown is offline
post #2818 of 22068 Old 07-13-2014, 02:46 PM
Quoted: 91 Post(s)
http://www.bestbuy.com/site/49-class...1001&cp=1&lp=4
Input lag is probably not worth $200 more for me. According to this the Sammy's http://www.rtings.com/info/input-lag-tvs input lag is worst in class but I thought I saw a post that the lag improved after an update, can anybody confirm what the 8850 input lag is now? http://www.bestbuy.com/site/50-class...1001&cp=1&lp=3
post #2819 of 22068 Old 07-13-2014, 03:00 PM
Liked: 355
Sometimes my screen goes black. Takes a couple minutes to run through whatever its hung up on.
But it usually comes back after a little while.
post #2820 of 22068 Old 07-13-2014, 03:03 PM
Liked: 355
I have no issues playing battlefield or killzone. Or call of duty.
Infamous 2 looks fn tastik and forza is sometimes real looking.
Im very happy.
Reply LCD Flat Panel Displays
samsung u8550 , Samsung Un55c8000 55 Inch 1080p 240 Hz 3d Led Hdtv
