Toshiba 37AV502R Settings - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-15-2014, 07:42 AM - Thread Starter
vincentfam's Avatar
Liked: 24
Greetings Colleagues,
This is an old television that I updated using AVS Forum HD 709 Disk, APL Clipping Pattern, which is the 2nd pattern that comes after the Black Clipping Pattern, and is described as an APL for use in a "typical viewing environment." As recommended, the brightness was adjusted where bar 19 was barely visible. Calibration patterns used were full field patterns from the Gamut Calibration Disk from this forum.
Contrast was reduced to 88 to eliminate tinting at higher settings. Primary adjustments were to blue drive, green drive and gamma setting. Used color temperature setting of medium.
For your consideration, I have attached graphs of gamma curve, rgb levels, and temperature. No changes were made in service menu. Settings are close to D65, but average gamma levels out around 1.9 which may be designed that way.
I searched the forum but did not find any other settings thread for this tv.
toshibagammagraph.jpg 99k .jpg file
toshibargbgraph.jpg 100k .jpg file
toshibatemperaturegraph.jpg 80k .jpg file
HDMI
contrast 88 (lower to this number due to tinting)
backlight 70 (change to 84 for 60ftL maximum light output)
dynalight off
brightness 59
color 39
tint 1
sharpness 6 (changed to 8 due to my seating distance)
Advanced
dynamic contrast off
static gamma -5
color temperature medium, B drive 2, G drive -7
Your colleague in picture quality,
Vincentfam
ID:	76535   Click image for larger version
ID:	76536   Click image for larger version
vincentfam is online now
post #2 of 4 Old 03-15-2014, 09:41 AM - Thread Starter
vincentfam's Avatar
Liked: 24
Updated Settings with Minor Service Menu Adjustments:
Settings were adjusted to increase color temperature to 8000K for appearance of whiter whites, with minor adjustments in service menu. Target rgb colors still in white space of CIE graph.
HDMI
red gain 118
green gain 100
blue gain 73
User Menu Adjustments
contrast 88
dynalight off
brightness 61
color 39
tint 1
Advanced:
static gamma -5
color temperature medium, B drive 12, g drive -7
Vincentfam
post #3 of 4 Old 03-17-2014, 04:37 AM - Thread Starter
vincentfam's Avatar
Liked: 24
Readjusted Settings Using 21% Red Color Method:
Settings were readjusted using 21% Red method which showed that the color red was slightly over saturated. Previous method used blue filter method. Also, backlight reduced to 74 (50 ftL maximum light output) due to wife complaining about the picture being too bright in dark viewing environment. Changes are in bold.
HDMI
red gain 118
green gain 100
blue gain 73
contrast 88
backlight 74 (- Readjusted to 79, Wife settled on 55 ftL maximum light output)
dynalight off
brightness 61
color 35
tint -2 [1 initial setting using blue filter may look better]
Advanced:
static gamma -5
Vincentfam
post #4 of 4 Unread Today, 06:20 AM - Thread Starter
vincentfam's Avatar
Liked: 24
Standard Mode for Day Viewing, Gamma @ 2.0
I have adjusted the settings for day viewing with color temperature @ 8000K and the gamma level set at 2.0 @ 0% ire window, see gamma graph below (as recommended by some members in this forum). To achieve this level I had to ignore the usual brightness calibration patterns and adjust the brightness setting to where gamma is measured at 2.0 @ 0% ire using field patterns. The contrast setting was lowered to remove blue tinting from the grey scale white pattern. Backlight was then adjusted for 50 ftL @ 100% ire field window pattern. Service menu also had to be slightly adjusted to obtain the 8000K color temperature.
Standard Mode day viewing with gamma level at 2.0 @ 0% ire.
Service Menu Adjustment Cool
red gain 94
green gain 76
blue gain 178
contrast 58 (lower to this number due to tinting)
backlight 94
dynalight off
brightness 68
color 31
tint 1
sharpness 4
Advanced:
static gamma -5
color temperature cool B drive 8, g drive -3
The Vincentfam
Name:	Toshiba Gamma Update.jpg
Reply LCD Flat Panel Displays
