Samsung UN75F7100 Rebooting Loop (VIDEO) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-16-2014, 02:18 PM - Thread Starter
moogs74's Avatar
Bought a Samsung UN75F7100 in December to replace a 55" 8000 from a few years ago. I never had any issues with that TV. Great TV. The issue I am having now is the following:
1. 2 weeks ago it rebooted on its own, seemed to be twice in a row. I thought hmm maybe a power surge, or a firmware reboot that was auto for some reason. Didn't think much about it.
2. A week ago the TV went into a reboot cycle again, this time it was consistent. I tried unplugging the TV and the receiver. It came back online after a couple minutes.
3. This morning the TV went into a reboot loop again, this time permanently. Rebooted the receiver, maybe it's a signal flopping, that wasn't it. TV kept the reboot cycle when disconnected from the receiver. Unplugged the TV and waited for 20 minutes then plugged it in again. I don't even hit the power on button. It goes straight into a reboot loop again.
4. Plugged the HDMI out from the receiver to my monitor and the TV signal is fine. Nothing like watching TV on a 27".
When I unplug the TV it still reboots about 5 times before, I guess the capacitors, are drained and stops. When I plug it in It's simply a red light that flashes twice, hear a click, logo flash then repeat, over and over and over again now.
Got a service ticket open and will likely get it repaired I guess. Sucks that a 4k TV is busted 4 months after you buy it.
Any other ideas?
moogs74 is online now
post #2 of 5 Old 03-16-2014, 02:49 PM - Thread Starter
moogs74's Avatar
post #3 of 5 Old 03-16-2014, 08:55 PM - Thread Starter
moogs74's Avatar
So I plugged the TV in and just let it roll through the cycle for about an hour while holding down buttons on the smart remote. It finally came on. I went straight to disable auto firmware update and then checked the version.
It's 1121 and they just released a 1120 on the 9th, 1 week ago, which fixed, most notably the first problem:
Release Date Mar 9, 2014
Upgrade File(USB type) (Firmware) (ver.1120.0)
This firmware is for TV Model(s): LED F5500/F6300/F6350/F6400/F6800/F7050/F7100/F7150, PDP F5500
The version is 1120.0
This firmware update will improve the following:
- Solves Auto Off-On Issue
- Solves the issue Smart Control does not work.
- Solves Network Connection Issue with Wireless Router.
- Improves Picture Quality.
- Solves the issue Screen Mirroring does not work.
- Solves the issue Digital Clean View does not work correctly.
All OS Mar 9, 2014 MULTI LANGUAGE 626.97
Odd that there's already a 1121 version? Oh well TV is back, for now.
post #4 of 5 Old 03-17-2014, 10:21 AM
bench2010's Avatar
I posted my rebooting issue in the 6300 forum and found your post.  My 6300 65" was doing a rebooting loop.  I've returned the TV.  It was a crappy issue to have.
bench2010 is offline
post #5 of 5 Unread Today, 02:35 PM - Thread Starter
moogs74's Avatar
Just an update to this in case someone crosses paths with this thread. I had to get Samsung tech over to replace essentially everything except the panel. He says it's common and has to do with a short in the MB. He replaced the PSU, board and a cable I believe. 3 parts. This was over a year ago now I think and it's never happened since.
Reply LCD Flat Panel Displays
