Samsung 7100 How do I skip the smart hub on startup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-20-2014, 10:56 AM - Thread Starter
ckijora's Avatar
I love my new TV but I want to use a universal harmony remote and the machine always starts at the smart hub requiring me to use the samsung touch pad to enter.  Also, THe dang remote switches my sony receiver to tv sound anstead of cable-sat tv, any ideas how to fix that little issue.
Thanks in advance!
ckijora is offline
post #2 of 2 Old 03-20-2014, 08:38 PM
evanengisch's Avatar
Liked: 24
In the TV's settings menu under the "Smart" section, there's a setting for "auto-start". Factory settings have this on so that the Smart Hub always shows up, but you can change that setting to "off" and it will simply start on whatever input it was last left on.
Young C likes this.
evanengisch is offline
Reply LCD Flat Panel Displays
Samsung Un60f7100 60 Inch 3d Ultra Slim Smart Led Hdtv
