Setting up the Samsung UN60F6350AF - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 03-30-2014, 12:10 PM - Thread Starter
lawnboy246's Avatar
Just purchased the Samsung UN60F6350AF from Costco and trying to determine the best picture setting. Any suggestions from other users would be appreciated.
Also Comcast supplied the 4 component cables which I have had to set the source to Component. The HDMI source shows Comcast associated, but do I need to purchase a separate HDMI to coaxial cable to take advantage of this and avoid using the Comcast remote to solely use the Samsung remote?
lawnboy246 is offline
post #2 of 9 Old 04-02-2014, 03:47 AM - Thread Starter
lawnboy246's Avatar
Any suggestions?
post #3 of 9 Old 04-02-2014, 02:41 PM
RogRacer's Avatar
FYI..there is an entire lengthy thread dedicated to the 6300 series...it might be better to ask your question there. I do not understand what you mean by a "HDMI to coaxial" cable. The best connection is an HDMI cable running from the cable box to the set. The first step is to go look and see if you have such a cable.
RogRacer is offline
post #4 of 9 Old 04-05-2014, 05:07 AM - Thread Starter
lawnboy246's Avatar
Tried looking and posting there, but didn't receive any related reply so thought I would start a new thread.
post #5 of 9 Old 04-05-2014, 06:48 AM
vid33nyc1's Avatar
Try CNET settings for the Sammy 6300.It is the same TV.I'm thinking of getting that TV.How much was it at Costco?
vid33nyc1 is offline
post #6 of 9 Old 04-06-2014, 06:05 AM - Thread Starter
lawnboy246's Avatar
So you think these settings? http://forums.cnet.com/7723-19410_102-601640/samsung-un55f6300-picture-settings/
If I follow it correctly they recommend movie mode which seems rather dark.
post #7 of 9 Old 04-06-2014, 09:38 AM
vid33nyc1's Avatar
Yes those settings.They seem fine to me but you can start there and make your own adjustments to your liking.
post #8 of 9 Old 04-06-2014, 09:39 AM
vid33nyc1's Avatar
And checkout the official thread for the 6300 for more info.
post #9 of 9 Old 04-06-2014, 10:58 AM - Thread Starter
lawnboy246's Avatar
Looked there first and couldn't find any actual settings which is why created this thread. If you know of any, please post here. Thanks!
Reply LCD Flat Panel Displays
