**Official Samsung UHD Curved UNxxHU9000 Owners Thread ** - Page 39 - AVS Forum | Home Theater Discussions And Reviews
 3043Likes
post #1141 of 10247 Old 07-03-2014, 04:22 PM
Hisma's Avatar
Quoted: 525 Post(s)
Liked: 205
Oh, also the active 3D on the 9000 is excellent as well, if you're into that kind of thing (I sure am )
Mrorange303 likes this.
Hisma is offline
post #1142 of 10247 Old 07-03-2014, 04:34 PM
Liked: 0
Originally Posted by Bob_Houston View Post
I've experimented with using both the optical audio output and HDMI ARC to my receiver from my 65HU9000.
They both appear to output the same audio.
The only quirkiness with the sound I've encountered is that after I switch between optical or HDMI, I have to periodically go back into the sound settings on the TV and force the audio back to Dolby Digital - which appears to provide 5.1 surround sound.
Other than that, it seems to be working great.
If you connect a sound source to the One Connect box, and the source supports one of the HD audio formats, there doesn't appear to be any way to pass that through the TV to the receiver. So if you want HD audio, the source will have to be connected to the receiver - and send the video to the TV.
The other issue that I've encountered is that if you are using a source on the receiver and you're using HDMI ARC from the TV, after the TV first turns on (about 15 seconds), the TV sends a signal to the receiver - and if the receiver is set to automatically switch to the HDMI ARC audio upon getting TV audio, then you have to re-select the correct source on the receiver, which I've been able to do by adding a 20 second delay in the universal remote.
Thanks Bob. I was having issues when trying to play audio out of the tv speakers, no receiver, just blu ray connected directly to the tv - I can only hear background audio but no dialogue. I know most people would be using external speakers but I just thought it was odd that the tv couldn't receive 5.1, convert to 2.0 and then play out of the tv speakers
Jumperoo is offline
post #1143 of 10247 Old 07-03-2014, 04:38 PM
Hisma's Avatar
Quoted: 525 Post(s)
Liked: 205
katz review also spoke very highly of HU9000's motion handling, which for some reason people seem to talk bad about. It's damn good, even without SOE.
Wondering if a FW update can fix the flicker with LED clear motion. It drives me nuts so I don't bother using it.
Also, anyone use standard picture mode? Anyone care to share some calibration settings in standard mode? Apparently it's the only mode that uses auto depth enhancer.
Hisma is offline
post #1144 of 10247 Old 07-03-2014, 04:53 PM
R0CK632's Avatar
Quoted: 43 Post(s)
Tontondavid posted some calibration which Iam currently using back on page 28..Looks great.
R0CK632 is offline
post #1145 of 10247 Old 07-03-2014, 04:56 PM
Mrorange303's Avatar
Quoted: 1199 Post(s)
Liked: 355
Come on guys. I posted several settings and have told you guys this is how I get my pictures.
Everytime I post settings the are for standard.
Standard has always been the full resolution setting on a sammy.
Again go back to my post. All pics have always been from standard mode. Al settings ive posted too.
Mrorange303 is offline
post #1146 of 10247 Old 07-03-2014, 05:09 PM
DRaven72's Avatar
Quoted: 63 Post(s)
Liked: 80
Originally Posted by Sammie2980 View Post
Heads up for those interested CNET just posted review of this display
http://www.cnet.com/products/samsung-un78hu9000/
Ummm... Wasn't that the 65" he reviewed? Looked a little small to be a 78" TV.(Looked quite small compared to my 73") He does this crap based on just the series of TV. Give us an actual 78" after calibration review.
Cool Beans.
DRaven72 is offline
post #1147 of 10247 Old 07-03-2014, 05:33 PM
rlb
rlb's Avatar
Quoted: 1701 Post(s)
Liked: 1355
Originally Posted by Latinoheat View Post
Ofcourse if your box has a native output resolution for the appropriate incoming resolution for that channel, it's best to set it that way but most boxes only allow you to choose 480p/720p or 1080i. Everybody's tv is different but I find on mine 1080i is best, as most channels are 1080i anyways. The less up conversion, the best your tv will look. Unless a Darbee is used.
Makes total sense to me, except that I thought most allow for the "native" output. I know that all DTV receivers have supported "native" for more than the last 10 years.
Regarding Darbee, I even stopped using it and went to "native" output on my OPPO 103D as soon as I got the 2014 UHD kit for updating my F9000. I now believe the upconversion with the 2014 box provides a better picture than when using Darbee with upconversion on the 103D. I realize that's subjective; but my wife definitely agrees and that's the confirmation that matters.
rlb is offline
post #1148 of 10247 Old 07-03-2014, 05:38 PM
Citivas's Avatar
Quoted: 317 Post(s)
Liked: 191
They review what the manufactures give them free for testing (which most do, expect Consumer Reports).
Citivas is offline
post #1149 of 10247 Old 07-03-2014, 05:40 PM
Citivas's Avatar
Quoted: 317 Post(s)
Liked: 191
So you prefer Active 3D over Passive 3D even when both are doing true 1080P Full HD resolution? Why?
Citivas is offline
post #1150 of 10247 Old 07-03-2014, 05:42 PM
tontondavid's Avatar
Quoted: 90 Post(s)
Liked: 26
OK im having optical digital 5.1 issues again, this after the new firmware. It seemed to work fine before but now I only get dolby 2.0 from anything other than built in apps like Netflix. Which means that bluray and ps4 are back to 2.0. I tried to reset the TV multiple times with no success.
Is there a way to do a full factory reset other than the one through self diagnosis Menu??
Help....
tontondavid is offline
post #1151 of 10247 Old 07-03-2014, 05:52 PM
sikclown's Avatar
Quoted: 1377 Post(s)
Liked: 691
Help....
If you have your TV audio output set to PCM it will only output 2 channel audio. Choose Dolby or DTS and you will get 5.1, it is a problem with the majority of TVs on the market.
UN65F9000AFXZA + SEK3500u/za firmware version 1461
Denon AVR-X7200WA, Apple TV, UBD-K8500, PS4, Xbox One, Nvidia Sheild Pro, PC
(2) Klipsch RF-82IIs, (4)RS-52IIs,, (1)RP-450CA, (4) RP-140SA, (1) SVS PB12-Plus
Emotiva XPA-100, XPA-200, Emotiva A-700
UN55KS9000 firmware 1132,Denon x4200w, Apple TV, Panny BDT460, PC,
Nvidia Shield, Klipsch G-42,(2) R-3650-W-II,(4) RSL-C34E, SVS SB-1000, UPA-200
sikclown is online now
post #1152 of 10247 Old 07-03-2014, 05:53 PM
R0CK632's Avatar
Quoted: 43 Post(s)
Help.hk300...
Iam having the opossite issue..getting dolby from tv and ps3 but only 2.0 in netflix app. I cant selcect dolbys its grayed out...how can I fix it..
R0CK632 is offline
post #1153 of 10247 Old 07-03-2014, 06:13 PM
Hisma's Avatar
Quoted: 525 Post(s)
Liked: 205
Of course not, if it's full 1080p.
But the Sony is active 3d just like the samsung, and the Sony 3d is inferior to samsung. The 79" 900B is passive though.
Hisma is offline
post #1154 of 10247 Old 07-03-2014, 06:15 PM
Latinoheat's Avatar
Quoted: 1077 Post(s)
Liked: 825
Is this for cable/sat or Bluray? Or both? Whatever looks best to your eyes is what matters. Darbee doesn't work with 4k anyways, it's for 720p/1080i/1080p content, that explains why the native pass through looks better.
Media room- LG 4K OLED EG9600, Pioneer Elite VSX-90, Samsung 4K K8500, Klipsch Gallery G28's, Klipsch Sub 12, Klipsch RS-52 II, Optik HD cable
Living room- Sony 4K 79XBRX900B, Onkyo RC-360,HTPC, Klipsch Reference R-62II, Rc52II,PS4
Gaming room -Panasonic ST60, PS3, Wii
Latinoheat is offline
post #1155 of 10247 Old 07-03-2014, 06:20 PM
Citivas's Avatar
Quoted: 317 Post(s)
Liked: 191
Ok. I'm in the market for the 79" set, so yeah to me the active 3d is a con compared to some of the competition like the Sony. I don't see why any of brands wasted the potential of a 4K panel on Active 3D.
Citivas is offline
post #1156 of 10247 Old 07-03-2014, 06:24 PM
Hisma's Avatar
Quoted: 525 Post(s)
Liked: 205
To my knowledge nobody has done a proper review of the 79" 900B yet. It's passive 3D because it's IPS, which will almost certainly reduce effective contrast. But perhaps Sony can pull it off. Hopefully we get a review soon enough.
Hisma is offline
post #1157 of 10247 Old 07-03-2014, 07:18 PM
Citivas's Avatar
Quoted: 317 Post(s)
Liked: 191
I agree. Definitely not making any assumptions about the Sony until I've seen it, and read calibrated results.
Citivas is offline
post #1158 of 10247 Old 07-03-2014, 07:53 PM
Liked: 355
Well I waited a year to buy the x900a because of its passive 3d. I've had a friend throwing it in my face for a year. I love my active 3d. He hates my set. Makes him feel the cross talk is much better for my set.
It is. Lines are smooth. Pictures are bluray clear. But in 3d.
Yes that's obvious, but the sony can't do it. Yet Another win for the hu9000.
post #1159 of 10247 Old 07-03-2014, 08:05 PM
rlb
rlb's Avatar
Liked: 1355
I used the OPPO only for upconverting Bluray. I used it for five months with Darbee while upconverting to 4k. Native is the only resolution where Darbee can't be used.
rlb is offline
post #1160 of 10247 Old 07-03-2014, 08:08 PM
zoro's Avatar
Quoted: 224 Post(s)
Liked: 41
They gave better rating to sony 950B
zoro is offline
post #1161 of 10247 Old 07-03-2014, 08:24 PM
Liked: 355
I have a few things to say.
1. the curve is not gimmick, I hope to never own a flat screen again. Just different sized curved screens. I feel as immersed in my movies as I do in a theater. Theaters worth a damn have curved screens. Don't buy into the bull that movies don't fit the screen. They look great.
2. I have tried even a ant in signal from comcast and it looks near DVD on this set. Katz ran over it like he was scared to go into how good it is. I think Katz is a plasma homer. I also think he tends to prefer sony as a brand. Just from his past reviews.
I don't care if you own a plasma, oled, projector, led projector. Any of them. There is not a single tv I feel jealous looking at. Not a damn one. Size doesn't count. Just set.
3. I've realized once the next external upgrade comes this tv will actually get better . I just can't imagine how. But man I'm sure it will rock. I also love how the set evolves and the picture quality can evolve and get better. That is a standout feature that people really need to take note of.
There is only one brand that is doing this. No need to open the panel. So good. Damn good.
post #1162 of 10247 Old 07-03-2014, 08:24 PM
Liked: 355
post #1163 of 10247 Old 07-03-2014, 10:38 PM
Hisma's Avatar
Quoted: 525 Post(s)
Liked: 205
Awesome. Those settings do rock, I'll stick with them. props Tontondavid.
Hisma is offline
post #1164 of 10247 Old 07-03-2014, 10:53 PM
Vespa's Avatar
Question
Hey all, my UN65HU9000F arrives tomorrow and something occurred to me: Can I use the native Samsung remote(s) to control my DirecTV receiver? This is my first new TV in about 5 years, so I was unsure if that was the case.
Thx
Edit: Just read the Samsung help docs...it looks like I can
Vespa is offline
post #1165 of 10247 Old 07-04-2014, 03:03 AM
Ahzari's Avatar
Quoted: 52 Post(s)
Liked: 50
Really though, majority of reviewers so far prefer the 900B, while acknowledging the HU9000 is very closely matched. I think it comes down to the superior contrast. I also think they test contrast with local dimming off, so of course sammy's contrast improves with smart LED on (I have mine set to "low").
From the reviews I've read both have been very close, with one brand having better areas in one area vs the other.. Its also important to note with the TVs being so closely matched the Samsung is currently selling for much less $4300 vs $5000 and design aside I think the one-connect box is a more killer feature than Sonys speaker system long term.
Audio: Yamaha A-S1000 Stereo Amp // Kef LS50s // Dual JL Audio e112
Analog:Pro-Ject RM5.1SE Turntable // Pro-Ject Tube Box II SE Phono Amp // Pro-ject Speed Box II
Video: Samsung 65' HU9000 UHD // Oppo BDP-105 // Apple TV (4G - 64gb)
Power: Furman PST-8 AC Power Conditioner
Ahzari is offline
post #1166 of 10247 Old 07-04-2014, 03:06 AM
R0CK632's Avatar
Quoted: 43 Post(s)
Has anyone figured out a way to get the netflix app in the smart hub to play dolby digital and not stereo?
Samsung UN65HU9000
Pioneer VSX -524 -K
Sony PS3
R0CK632 is offline
post #1167 of 10247 Old 07-04-2014, 04:45 AM
vddobrev's Avatar
Quoted: 83 Post(s)
Liked: 40
I also find the 3D of this set excellent.
vddobrev is offline
post #1168 of 10247 Old 07-04-2014, 05:38 AM
Bob_Houston's Avatar
Quoted: 70 Post(s)
Liked: 32
Noticed the other day that the Xfinity STB has 1080P On Demand movies - haven't tried one yet to verify though.
Bob_Houston is offline
post #1169 of 10247 Old 07-04-2014, 08:59 AM
ahro's Avatar
Quoted: 2033 Post(s)
Liked: 4130
You can get 1080p from your Sammy Vudu app, and, I think from HBO-GO. On demand can give you 1080p, but no STB I know of has the network channels in 1080p
korsjs likes this.
ahro is offline
post #1170 of 10247 Old 07-04-2014, 09:24 AM
Amadeuz's Avatar
Sony X900b over hu9000 anyday. Superior in all ways. Rich deep colors, black levels contrast, motion lag, much better gaming with that exellent low ms.
Speakers on that thing, nothing comes close. Keep on hating, and stay 'curvin' with your sammys lol.. We out here 'Sonying' yall
Amadeuz is offline
Reply LCD Flat Panel Displays
