"Official" 2014 Sony XBR-49X850B / XBR-55X850B / XBR-65X850B / XBR-70X850B Thread - Page 21 - AVS Forum | Home Theater Discussions And Reviews
 585Likes
post #601 of 5927 Old 08-06-2014, 03:46 PM
Mattopotamus's Avatar
Quoted: 1793 Post(s)
Liked: 1539
Originally Posted by *UFO* View Post
When referring to different models, please don't omit the x or w. The w900a and x900a are very different tv's.
He meant the x900a
Mattopotamus is offline
post #602 of 5927 Old 08-06-2014, 04:00 PM
Yamaki's Avatar
Did a bit more digging into the Sony HDMI handshake issue and got the Sony HDMI TV & Source HDMI reset. My pre-amp / processor is on its way back to me and was deemed to be working properly by the manufacturer. So, when it gets back I'll try this:
  • Make sure both the TVand other device are turned on.
  • While turned on, unplugthe power cords for the TV and device from the electrical outlet.
  • Disconnect the HDMIcables from the TV and other product.
  • Wait 60 seconds.
  • While the HDMI cablesare disconnected, plug the power cords back into the electrical outlet.
  • Turn on the TV.
  • Re-connect the HDMIcables to both the devices and the TV.
  • Turn on theHDMI-connected product.
Michael
Aerial Acoustic 8s/McIntosh D100 MC252s MC501s MR85 MX119/Oppo BDP-95/Sony 4K
Yamaki is offline
post #603 of 5927 Old 08-06-2014, 04:02 PM
biglen's Avatar
Quoted: 109 Post(s)
Originally Posted by Mattopotamus View Post
He meant the x900a
That's correct, thank you.
biglen is offline
post #604 of 5927 Old 08-06-2014, 04:35 PM
andy sullivan's Avatar
Quoted: 773 Post(s)
Liked: 406
  • Wait 60 seconds.
  • Turn on the TV.
That should do the trick. Good luck.
andy sullivan is offline
post #605 of 5927 Old 08-06-2014, 10:02 PM
TcdF22b2's Avatar
Well, I finally got mine mounted, but i still have a lot of work to do on the house as evidenced by the roll of carpet against the wall.... and one of the cats used my little temporary ps3/xbox shelf as a springboard Even as dark as the picture is you can see how dusty my Paradigm center is. Hopefully I will have everything done soon. Until then, the tv is actually spending most of its time off and wrapped in plastic. Now that I have had it for the better part of a month I simply couldnt be happier. It really is a phenomenal panel. A little annoyed that its now 300 cheaper at the Sony store, but w/e, i knew I was gonna pay top dollar even though I didnt actually pay sales tax.
edit - for those that don't want to scour the thread, mine is the 65x850b
TcdF22b2 is offline
post #606 of 5927 Old 08-06-2014, 10:11 PM
TcdF22b2's Avatar
Originally Posted by Videoz View Post
I originally paid $2299.99 on July 5th for the 55x850b and now the price is $1999.99. I called Crutchfield and they credited my account the $300.00 difference. I can always use an extra $300.00.
Although I certainly won't hold my breath, I wonder if Fry's would do that? But I did buy it with a CC, so maybe my bank will. I can only hope.
TcdF22b2 is offline
post #607 of 5927 Old 08-06-2014, 11:26 PM
magnusr's Avatar
Quoted: 33 Post(s)
Liked: 30
Originally Posted by sgbroimp View Post
On my Sony XBR6 using PC via HDMI, many settings are greyed out and thus rendered unadjustable....color level....sharp.... and I have to do them in the chip, which is Intel Graphics 2000 and confusing and a pain in the neck. Your AMD looks much easier and more logical.
Nothing is grayed out in the TV here
Sound: Dynaudio Xeo 4, TV: LG 55EF950V, HTPC: Intel i7-6700 with GTX 1070
magnusr is offline
post #608 of 5927 Old 08-07-2014, 06:11 AM
sgbroimp's Avatar
Quoted: 279 Post(s)
Liked: 37
Great news. Thanks!
sgbroimp is offline
post #609 of 5927 Old 08-07-2014, 07:37 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 3036 Post(s)
Liked: 3225
Now that is an interesting back light, really makes that picture pop !
Cleveland Plasma is online now
post #610 of 5927 Old 08-07-2014, 09:23 AM
twin2turbo's Avatar
Quoted: 14 Post(s)
I have had my 65X850b for a little over week now. I picture is just unbelievably, except for the graying around edges. When i should be seeing black, I get grays around the edges. The affect is the same with lights on or off, but more noticeable with the light off. We mainly watch movies in the dark, so it is kinda of annoying. Can this be fixed with adjustments or should I talk to Sony about a replacement TV?
twin2turbo is offline
post #611 of 5927 Old 08-07-2014, 11:21 AM
Quoted: 773 Post(s)
Liked: 406
You're not giving us much to go on. What are your settings? Here are my settings. Go to the preference area and choose the GENERAl setting. Go to the ECO area and turn everything OFF except Auto Shut Off. Then go to Picture Settings and choose a Setting Memory of COMMON. My go to setting is in the CUSTOM catagory. Back Light-10, Picture -MAX, Brightness-45, Color-30, Color Temp-Neutral, Hue-0, Sharpness-70, MPEG-MED, NR-AUTO, Reality-AUTO, SG-LOW, MF-Smooth, CM-Auto, Black Correct-(-2). You can play around with these settings to your liking. To do your final adjustments, especially for color, I recommend going to ESPN in the afternoon recording and then pausing "Pardon the Interruption". This show uses high quality HD cameras and the set has a lot of brilliant color to fine tune your picture. To evaluate your black levels wait till you can pause on any dark scene. I like to pause when they are going to or coming back from a commercial because there is usually a momentary black screen then. When you have it pause, and you can see the light bleed, go back to the setting area and switch to VIVID and turn the back light down to 7 or 8. See if that makes your blacks blacker. If you like it better then you have do decide between Custom and Vivid. If you're like me you'll change your mind a hundred times and still not be sure. Kind of depends on what you're watching.
post #612 of 5927 Old 08-07-2014, 12:47 PM
SL600's Avatar
Quoted: 146 Post(s)
Liked: 74
a) The XBR-70X850B sells for about $2K more than the XBR-65X850B. Do you guys think it's worth $2K for the extra 5 inches?
b) Is the picture quality of the 70" better than the 65"?
c) Any professional reviews of the 70" yet?
d) Finally, does anyone have a copy of the cutsheet for the XBR-70X850B?
SL600 is offline
post #613 of 5927 Old 08-07-2014, 02:04 PM
Quoted: 773 Post(s)
Liked: 406
I set my 70x850b up Tuesday and even though I like it there is no way it's worth $2K more than the 65x850b unless you want the extra 5 inches really bad. I'll post a more detailed review later this week but in a nutshell I feel that compared to the 70w850b which the X replaced, the X gives maybe a 10% bump in PQ from broadcast TV and blu-ray viewing. Even the X shows a bit of radial banding and clouding but not as bad as the W. The 65 inch is a sweet deal compared to the 70 inch.
SL600 likes this.
post #614 of 5927 Old 08-08-2014, 07:26 AM
Yukichon's Avatar
Quoted: 146 Post(s)
Liked: 60
I am seriously considering taking advantage of the X850b that's currently at $1999 at BB. Will this price be sustained or will it go back up?
Yukichon is offline
post #615 of 5927 Old 08-08-2014, 08:18 AM
twin2turbo's Avatar
Quoted: 14 Post(s)
My neighbor is a home theater installer, he did a gray scale adjustment for me. I was crushing black and white. Adjustments helped, but he thinks the problem is the edge lighting. It is like leaking out. I don't know how else to describe it. Does anyone else have this problem?
post #616 of 5927 Old 08-08-2014, 09:54 AM
Quoted: 773 Post(s)
Liked: 406
Originally Posted by twin2turbo View Post
My neighbor is a home theater installer, he did a gray scale adjustment for me. I was crushing black and white. Adjustments helped, but he thinks the problem is the edging lighting. It is like leaking out. I don't know how else to describe it. Does anyone else have this problem?
Light bleed along the edges is a by-product of the edge lit technology. Some panels are better than others and I would expect the Sony 70x850b to be using one of the better panels. Using my custom or vivid settings produce very little bleed. For the most part I consider my PQ to be excellent. This is my 5th big Sony in the last10 months and I'm finally happy. If yours is a problem you should have Sony replace it. From my limited experience I think the Sony's incorporating the X-Realty Pro engine are quite good out of the box but can be lmproved with a few tweaks.
post #617 of 5927 Old 08-08-2014, 11:51 AM
SL600's Avatar
Quoted: 146 Post(s)
Liked: 74
How is the picture quality compared to the 65x850b, especially black-level detail? Is the 70" panel more or less reflective than the 65"? Finally, is the viewing angle better or worse than the 65"?
SL600 is offline
post #618 of 5927 Old 08-08-2014, 12:17 PM
Quoted: 773 Post(s)
Liked: 406
I only know that the 65x850b received a very good review and as of yet I have not seen a review on the 70x850b. The 70x has a decidedly more reflective screen than the 70w so the viewing angles for the x should be a little more restrictive. I think the 65x uses a IPS screen and the 70x looks to me like a VA screen. So far I'm noticing some radial banding as I watch the PGA today. Like the 70w this radial banding on the 70x did not show up until day 3 of operation. The 65w850b that I had showed no sign of radial banding (arching curved bands, like the outside rings of a target, always worse on the right side of the screen). Especially visible as a camera pans on a solid colored surface like ice hocky, golf, baseball field.
post #619 of 5927 Old 08-08-2014, 12:25 PM
Videoz's Avatar
Quoted: 62 Post(s)
Liked: 30
If you mean the 55x850b, the $1999.99 price is good until September 6th. If you mean the 49x850b $1999.99 is the regular price
Bob (Retired)
__________________
Samsung UN55H8000 TS02
Dish VIP-211K
Sony BDP-S6200
Videoz is offline
post #620 of 5927 Old 08-08-2014, 12:46 PM
Liked: 1539
Funny b.c the x900a and B both have some banding and both use VA panels.
This is why I was willing to take a 850b over the 900b replacement I was offered. I have been able to see banding on every single VA panel in sonys 4k lineup.
post #621 of 5927 Old 08-08-2014, 01:04 PM
Quoted: 773 Post(s)
Liked: 406
It's funny but the 65w850a uses a Samsung S-PVA panel and it had no banding but pretty bad clouding. I'm just going to accept it with the 70x850b. Tired of exchanging. I would really like to hear from some technical person (Tubetwister hint hint) as to why the banding issue is happening. I'm sure the obvious answer is because of the edge lit LED's but with the last 70w850b and this 70x850b I checked very closely when I set the TV's up and really really scrutinized the panels looking for the slightest sign of any hint of banding. Both panels were absolutely clean for the first two days then bang, there is was. I switched out all of my HDMI cables to no avail. Keep in mind the 65w850a never ever developed banding of any kind. And it has the TRILUMINUS color filter like the 70x850b while the 70w850b does not. It seems that I can't find a common denominator.
post #622 of 5927 Old 08-08-2014, 01:16 PM
BriS2K's Avatar
I like the design of the x850, it is perfect. I like the glossy edgelit dimming X900 but the speakers take up too much space.
I'm hoping Sony get's it right in 2015 for a 70" model.
Sony 75W850C 1080p LED
Pioneer Kuro 5010FD 1080p plasma
BriS2K is offline
post #623 of 5927 Old 08-08-2014, 01:42 PM
Liked: 1539
I wonder if it is just the AUO VA panels. The Samsung's are very uniform like you said. I went through 4 900A's hoping to avoid banding. I just watch too many sports to have banding. If I just watched movies, I would probably never see it.
post #624 of 5927 Old 08-08-2014, 01:54 PM
Quoted: 773 Post(s)
Liked: 406
From what little I've heard about the AUO panels that little has been pretty good. Who knows in this day of panel lottery. If Sony calls and offers me a 1080P 80" of my choice I'd take it.
post #625 of 5927 Old 08-08-2014, 02:00 PM
Liked: 1539
The AUOs offer amazing contrast and blacks.
post #626 of 5927 Old 08-08-2014, 03:29 PM
Quoted: 773 Post(s)
Liked: 406
I imagine AOU builds AV and IPS panels so it would be interesting to compare the attributes of each side by side. I've checked numerous places and can't find any information on the panels used in the 70w850b and the 70x850b. The x does have the reflective properties of a AV panel while the w seemed more matted. But who knows? Maybe they are made by RCA or GE.
post #627 of 5927 Old 08-08-2014, 04:55 PM
Quoted: 44 Post(s)
Liked: 9
I believe AUO has spent a good deal of $ on A-MVA. I don't think they would invest the capital to produce two different displays, especially if they've been pushing a competing technology. I could be wrong though.
Duke02 is offline
post #628 of 5927 Old 08-08-2014, 05:01 PM
Quoted: 773 Post(s)
Liked: 406
Yea, who knows. I didn't think Samsung made 70 inch panels but I guess they do. I'm sure Auo is in stiff compitition witn Innilux and who knows who else.
post #629 of 5927 Old 08-08-2014, 09:10 PM
Quoted: 44 Post(s)
Liked: 9
Like Matt said, the AUO panel in my x850a has pretty stunning blacks although I came from a 7 year old xbr2....
Duke02 is offline
post #630 of 5927 Old 08-08-2014, 10:48 PM
radewagon's Avatar
Liked: 1
In case anyone's curious, I picked up the 55inch x850b because of the sale price and absolutely love the 3D performance. Is it perfect? No. But then, I don't think 3D is perfect in general. I do think, however, that it is better than what I usually experience in the theaters. I've only watched two movies so far (Tron Legacy and The Great Gatsby on 3D Bluray) but both of them had moments that were absolutely stunning on this new set of mine.
I'm no expert and I feel the need to say that my impression thus far is that of a casual viewer (certainly not a videophile), but I thought I'd leave my impressions for anyone who might be wondering about the performance of 3D Blurays via the X850B.
radewagon is offline
Reply LCD Flat Panel Displays
radical banding , XBR-49X850B , XBR-70X850B
