Media Wall - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 05-16-2014, 02:24 AM - Thread Starter
mkswanson's Avatar
I'm looking to add displays to a conference room wall. I need 100" + minimum size. I also need crisp, visible picture in full light, which means most projectors I've looked at aren't a good option.
I'm on a shoestring budget, but need top-shelf performance (please don't laugh).
I've considered adding 4 residential-grade tv panels, but don't want huge bezels in the middle.
I'm willing to consider a dedicated hardware controller to split the image, but, since the input is coming from a dedicated PC, I was thinking a direct connection to the PC made sense.
Any suggestions on the best plan of attack?
mkswanson is offline
Reply LCD Flat Panel Displays
