Which of these 65" TV would you get? - AVS Forum
post #1 of 5 Old 06-01-2014, 04:57 AM - Thread Starter
befrenchy's Avatar
I need some advice on selecting a new TV for basement family room. The room will be fairly dark and there is no concern with sunlight shining on the TV. Between the following 3 TVs which one do you think will provide better picture quality for Movies and Sports?
Vizio E650I-A2 65" LED $1199
Sharp Sharp LC65LE643U 65" LED $1199
Samsung PN64F5300 64" Plasma $1198
Thank you.
befrenchy is offline
post #2 of 5 Old 06-01-2014, 05:02 AM
Stereodude's Avatar
Quoted: 461 Post(s)
Liked: 507
If the room is dark like you say, most likely the plasma. That's not one with a pentile matrix subpixel arrangement is it? Those drive me nuts.
Stereodude is offline
post #3 of 5 Old 06-03-2014, 05:12 PM - Thread Starter
befrenchy's Avatar
Sorry, i'm not sure what you mean by "That's not one with a pentile matrix subpixel arrangement is it? "
post #4 of 5 Old 06-03-2014, 05:44 PM
fafrd's Avatar
Quoted: 14 Post(s)
Liked: 406
Thank you.
For $1200, I'd suggest you consider the 2014 E650i-B2: http://store.vizio.com/eseries/e650ib2.html
It is full array rather than edge lit for the same price as the 2013 E650I-A2 model, is available now, and has recently received a very positive review from CNET: http://www.cnet.com/products/vizio-e550i-b2/2/
fafrd is offline
post #5 of 5 Old 06-04-2014, 08:44 AM
Stereodude's Avatar
Quoted: 461 Post(s)
Liked: 507
Some plasma displays do not use a conventional RGB stripe subpixel arrangement. The use a different subpixel arrangement called a pentile matrix. To my eyes it does not look very good and is rather objectionable. However, I think only the 60" F5300 has this and the 64" does not.
Reply LCD Flat Panel Displays
User Tag List
