Thick Green lines on 55H6350 LED HDTV/Samsung. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-06-2014, 09:56 AM - Thread Starter
pabstdrinker's Avatar
I noticed that every once and a while my new 6350 I see a flash, more on the left side, of thick green lines.  I happened on live TV and DVR.  Also saw them while streaming Netflix as well.
I bought this TV the same day, from same place (Dell.com), as a friend.  He is having the same issue.  Has anyone else experienced this as I DO NOT want it to become a problem...  TV is not even 30 days old.
Thanks in advance.
pabstdrinker is offline
post #2 of 2 Old 06-08-2014, 03:18 AM
tubetwister's Avatar
Location: The Outer Limits....Don't trust any air I can't see ☺
Quoted: 1384 Post(s)
Liked: 622
quote name="pabstdrinker" url="/t/1534688/thick-green-lines-on-55h6350-led-hdtv-samsung#post_24799922"]I noticed that every once and a while my new 6350 I see a flash, more on the left side, of thick green lines.  I happened on live TV and DVR.  Also saw them while streaming Netflix as well.
Thanks in advance.
[/QUOTE]
it already is a problem not good could main board (TV video/tuner board ),bad LVDS cable or more likely a bad panel .
But first substitute a known good cable and unplug it for a minute or so so the CPU will re boot also see if you can force a firmware update/ re install
if these thing don't work get rid of it /exchange it , the xx6350 should b a good set maybe it's a batch problem.
tubetwister is offline
Reply LCD Flat Panel Displays
