LG 55LW6400 Sno Globe Disaster - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-13-2014, 06:27 PM - Thread Starter
Old AV Buff's Avatar
I was moving my center channel speaker around on the mantel behind my LG 55" LED TV. There was a snow globe left there from Christmas. It fell over, busted and some water went into the back of the TV. The video went nuts and went out and I shut it down. 3 months later I finally took the back off. I could see the water missed the circuit boards. The video input board has 2 ribbon cables running to the bottom of the screen. One has a small burnt spot at the connector. It split the ribbon about a quarter inch up from the slot. If i clean the slot and replace the ribbon cable (about $20 for an LG cable, might I get my video back? the TV powers up no problem. The panel responds but no video with the burnt cable. Or might there be more damage that I just don't see?
Old AV Buff is offline
post #2 of 4 Old 06-13-2014, 06:40 PM
bac522's Avatar
Quoted: 134 Post(s)
Liked: 96
This strikes me as one of those "what do you have to lose for trying" post...there is a chance that extra current was sent down the shorted ribbon cable to sensitive circuits and blew them...I admit I'd be a bit surprise if that didn't happen...but no easy way of knowing that until you replace the bad ribbon cable.
bac522 is online now
post #3 of 4 Old 06-14-2014, 04:05 AM - Thread Starter
What amazed me was the 2 small circuit boards and that was pretty much it. We have come a long way from the old CRT TV's.
post #4 of 4 Old 06-25-2014, 08:02 PM - Thread Starter
Well, had to order both ribbon cables. the other also had a few burnt spots That I did not see until I un-hooked it. Plugged it in tonight and...Voila! We have video. Very happy.
Reply LCD Flat Panel Displays
