AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   LCD Flat Panel Displays (http://www.avsforum.com/forum/166-lcd-flat-panel-displays/)
-   -   LG 55LN5400 - How to tell if it is an IPS PANEL or NOT (http://www.avsforum.com/forum/166-lcd-flat-panel-displays/1566905-lg-55ln5400-how-tell-if-ips-panel-not.html)
sat.there 06-14-2014 11:42 PM
What do you look for in the Serial Number to tell if the 55LN5400 has an IPS panel or not ?
sat.there 06-16-2014 09:03 AM
bump
dcsr23 06-16-2014 02:44 PM
Tap the screen gently... IPS you will only notice a slight mark where you tapped, LED will flicker in a greater area. I think LG typically uses IPS anyway.
sat.there 06-16-2014 04:06 PM
no, I meant by the letters in the Serial Number
Dr.Shankenstein 06-17-2014 04:52 AM
LG displays are generally entirely of the IPS variety.
sat.there 06-17-2014 10:07 PM
Even the ones at Walmart ?
Dr.Shankenstein 06-17-2014 10:12 PM
Yes,there are a variety of IPS panels available. The LN5400 would be considered a low-mid range display,so I wouldn't count on one of the higher caliber IPS panels.
sat.there 06-18-2014 10:03 PM
which of the below do you think it would be ?
Horizontal IPS
Enhanced IPS
Professional IPS
Advanced High Performance IPS
I pick the 5400 OR new 6000 series because there is no INTERNET CRAP built into it
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
