Mantlemount / Dynamic Mounting / Other... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-25-2014, 06:37 AM - Thread Starter
jbchi's Avatar
I'm stuck with the TV over a fireplace situation, which I know isn't ideal but the reality is if I want a TV, thats where it has to go. I have a 46" LCD above the 48" high mantle right now. It works ok, but I know that the top of a 60-65" model will be far too high, even if it is just resting on the mantle itself.
Has anyone been using either the Mantlemount or Down and Out mount for at least 6, 12, or more months? Do you still like it? Does it still work? How hard was it to install? How big of a TV do you have mounted (I'm looking between 50 and 75lbs).
I know the Down and Out model is stupid expensive, but the Mantlemount is apparently forever out of stock.
http://mantelmount.com/
http://dynamicmounting.com/
jbchi is offline
post #2 of 5 Old 07-01-2014, 02:38 PM - Thread Starter
jbchi's Avatar
I'll give this one bump to see if there are any opinions.
jbchi is offline
post #3 of 5 Old 07-13-2014, 09:20 AM
LSUfaramir's Avatar
Unhappy mantlemount dead?
I have the same issue. I tried calling the number from mantle mount, and it is out-of-service Did they go out of business?
I did not want to have to spend $500 on a mount.
Anyone find any alternatives?
LSUfaramir is offline
post #4 of 5 Old 07-15-2014, 01:53 PM - Thread Starter
jbchi's Avatar
These were the only two I knew of, and it looks like it might be down to one.
jbchi is offline
post #5 of 5 Old 08-03-2014, 10:13 PM
LSUfaramir's Avatar
Mantle mount's website is back up, and they are taking orders this month. It will be $199 until they run out of stock on their first order.
Reply LCD Flat Panel Displays
