Samsung F8000 Turn On By Itself - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-03-2014, 06:51 AM - Thread Starter
Quoted: 18 Post(s)
Liked: 1
I have Samsung Model # UN60F8000. As I was walking past my tv last night, all of a sudden the red led light turned off and the bottom middle white light over the Samsung emblem on the tv powered on, which usually happens when you turn on the tv. The screen never actually turned on and then after a couple of seconds it turned off and the off red led light went back on(which means the tv is turned off). This has only happened once so not too concerned about it, but considering I just bought the tv, I'm somewhat worrisome. I figured post here to ask if this is a issue...I'll keep a close eye on it. Thanks.
johnnyboy1988 is offline
post #2 of 6 Old 07-03-2014, 01:18 PM
homerging's Avatar
Quoted: 31 Post(s)
I'd guess a brownout or something wrong with the power supply board.
homerging is offline
post #3 of 6 Old 07-03-2014, 02:31 PM - Thread Starter
Quoted: 18 Post(s)
Liked: 1
Not sure, but I'm trying to keep an eye out for anything.
post #4 of 6 Old 01-05-2015, 12:11 AM
nikon5400's Avatar
Quoted: 75 Post(s)
Liked: 24
just got the exact same issue tv turned on screen remained black
have you had this happen again? if you had this fixed what was the fix?
nikon5400 is offline
post #5 of 6 Old 02-06-2015, 12:40 AM
Liked: 1
Any update by anyone how this issue can be fixed?
rayofhope is offline
post #6 of 6 Old 02-06-2015, 10:24 AM
Jon S's Avatar
Quoted: 758 Post(s)
Liked: 242
After firmware 1060 on my 8550, my TV has been exhibiting this problem... It will turn itself on or off... My wife thinks it is haunted...
If it's not a BIG screen, it's not a theater...
Jon S is offline
Reply LCD Flat Panel Displays
