Vertical lines on Samsung LED TV (UN55SD8000) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-05-2014, 02:34 PM - Thread Starter
Liked: 0
Unhappy Vertical lines on Samsung LED TV (UN55SD8000)
Hi,
I have a Samsung UN55SD8000 TV. It is over 2 years old. I have lot of vertical thin blue lines on my screen. Lot of them on the left edge and some on the right and many across the middle of the TV. I have attached two picture showing the problem. I called Samsung and they did the remote display diagnostic test. He just gave me number of repair guy. Did not really tell me what is wrong. I would think they could tell if screen is bad or some xyz part may not be replaced.
Any ideas on the problem? Will this require replacing my screen or just cleaning the connector to the screen? Trying to see if worth calling TV repair guy or not.
Rajat
ID:	149442   Click image for larger version
rajat2014 is offline
post #2 of 6 Old 08-12-2014, 10:33 PM
Liked: 0
Hey I'm having a similar issue with my Samsung LED TV - were you able to fix it?
kazed is offline
post #3 of 6 Old 08-13-2014, 06:08 AM
Cabby's Avatar
Quoted: 57 Post(s)
Liked: 34
This seems to be a lot like the issue in this thread:
Samsung LCD TV colored vertical lines - issue resolved - loose connector - save yourself $1237 (my model LN55C650)
I get this as well still, about once a week. If I reach behind the TV and tap/push the HDMI cable, the lines go away and the TV's perfect again for anywhere between a couple days and a couple months. Hope that helps.
Cabby is offline
post #4 of 6 Old 08-13-2014, 08:52 AM
Liked: 0
Thanks - I tried that a couple days ago without any luck. May need to open it up again and take another look.
Did you only see the lines when certain colors were displayed? Thats my issue. The lines are in fixed positions but they only fill out if a green color or random bright color is displayed.
This video is the same issue I'm having. Is it similar to what you had?
kazed is offline
post #5 of 6 Old 08-31-2014, 05:36 PM
Cabby's Avatar
Quoted: 57 Post(s)
Liked: 34
https://www.youtube.com/watch?v=AzpFNRXsKjw
Not not at all, the whole screen has lines everywhere, it seems like it just happens over time, like the connectors aren't soldered to the board completely, and it starts to pull off ever so slightly over weeks and months until not all the contacts are touching.
Cabby is offline
post #6 of 6 Old 09-01-2014, 05:11 AM
Liked: 0
great, like the connectors aren't soldered to the board completely, and it starts to pull off ever so slightly over weeks and months until not all the contacts are touching.[IMG]http://*******/Wdbwyv[/IMG]thanks
bingfters is offline
Reply LCD Flat Panel Displays
