Is my TV dead? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-08-2014, 07:30 AM - Thread Starter
Liked: 0
Is my TV dead?
I've attached a picture of my several year old Philips TV. Is it dead? Can I rescue it? It is worth the trouble? It just suddenly happened while it was on. Did not drop it or anything.
dougouolo is offline
post #2 of 4 Old 07-08-2014, 11:03 AM
topr's Avatar
Probably the T-con board (timing control board). Depending on the size of your display it's probably just as cost effective to replace the set.
topr is offline
post #3 of 4 Old 07-13-2014, 07:07 AM - Thread Starter
Liked: 0
post #4 of 4 Old 07-13-2014, 08:21 AM
BarrettF77's Avatar
Quoted: 61 Post(s)
Liked: 36
Had a Samsung LCD years back do the same thing. You can bang on the back of the TV set or let it warm up sometimes and it will go away until the next restart. But yes, it is likely cheaper and more effective to replace the set.
BarrettF77 is offline
Reply LCD Flat Panel Displays
