Hiesense TV 50k360G Sound and backlight but no picture - AVS Forum
post #1 of 3 Old 07-13-2014, 07:44 PM - Thread Starter
Liked: 0
I have a tv that suddenly stopped displaying the picture. The backlight lights, but the LCD is not displaying anything.
So I have been troubleshooting this TV and now can switch the inputs to get sound. The backlight lights, but there is no response from the panel. I have ordered and installed a tcon board that came from a 'bad panel' tv on ebay, but it didn't change anything.
I don't understand how to tell if the panel itself is bad or if the tcon boards are both bad (including the one from ebay). The tcon boards both have good fuses, and the processing chip heats up when the TV is on. I have checked the connections from the panel boards (two of them in this case) to the panel itself. And I did not feel that any of the pressure glued ribbons were loose. However, there are a few resistors and such on the panel boards, could these be the problem.
Is there anything else in the panel that would keep it from showing anything at all. I would like to know for sure if I should just give up, or buy another tcon board.
Thanks for the expertise.
Brant Peery is offline
post #2 of 3 Old 09-26-2014, 07:11 AM
Liked: 0
I'm having the exact same issue with the same model.
Any updates on this?
Brandon Demko is offline
post #3 of 3 Old 10-06-2014, 07:07 PM
jstiene's Avatar
Hisense 50K360G
Hello. I also have a 50K360G with only a backlight. No picture and cant seem to get sound. Turns on with remote and keypad with no problem. Did anyone determine the problem with your set?
jstiene is offline
Reply LCD Flat Panel Displays
