Vizio M-Series(2014) vs Samsung Plasma(2013) - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Makaveli6103
Old 07-13-2014, 09:08 PM - Thread Starter
Liked: 0
This may seem like a ridiculous question to some of you, and I am about 90% decided that I will go for the plasma, but I was just wondering if there were ANY reasons at all to go for a Vizio M-Series 2014 LED model over a Samsung plasma 2013 model (PN51F5300AFXZA).
Are there any significant improvements in Vizio's 2014 M-Series that would put it above a 2013 Samsung plasma? Smart features and 3D are not a concern for me. I can deal with glare & reflections one way or another. My main concern is picture quality and longevity.
rededaf is offline
Old 07-13-2014, 09:11 PM
Makaveli6103's Avatar
Quoted: 20 Post(s)
No way the Vizio can compete with the Samsung Plasma. Is this a rhetorical question?
StinDaWg likes this.
Makaveli6103 is offline
Old 07-13-2014, 09:12 PM
TahoeDust's Avatar
Quoted: 41 Post(s)
With that being the case, for me it would be an easy choice. The plasma.
The only advantage I could think of for the the Vizio would be if you were going to be spending most of your time viewing the TV in a very bright environment.
Samsung PN60E7000
Sony HT-CT770
Custom HTPC - 3.2GHz/8TB/8GB/HD5670
TahoeDust is offline
Old 07-13-2014, 09:20 PM
fafrd's Avatar
Quoted: 14 Post(s)
Liked: 1905
I agree, daytime viewing performance would be the single biggest advantage of the LED/LCD over the plasma. The 2014 Vizio M Series is getting some pretty positive reviews as being one of the best LED/LCDs at its pricepoint: http://www.soundandvision.com/conten...b3-lcdled-hdtv
I don't know anything about the PN51F5300AFXZA, but LCDs also have the advantage over many/most plasmas of not requiring any break-in time or the use of color slides prior to calibration in order to get the best PQ.
fafrd is offline
Old 07-13-2014, 09:31 PM - Thread Starter
Liked: 0
Thanks for the quick replies!
I would be viewing it mostly in a bright environment (sunlight coming in at a side angle) and that is one of the main reasons why I am a bit hesitant on the plasma, but if it comes down to it, I will probably just get some nice black-out curtains.. but if I do that, it will get VERY hot in here as I do not have A/C and it gets over 100 degrees here in summer. I have read that this particular model produces a lot of heat, and would really like to know if this will be a problem for the longevity of the plasma.
rededaf is offline
Old 07-19-2014, 01:00 AM
jack54's Avatar
Quoted: 73 Post(s)
I had the 60" Samsung Plasma and really liked it. It did put out way more heat, than the 70" Sony 3D LED HDTV I just got. So you have the window blocked and the Plasma generating heat, I bet your room goes up 15-20 degrees. I can feel the heat from the plasma when I'm 2-3 feet from it, but not where I'm sitting 8 feet away, however by then the heat rises to the ceiling. That said, I'd go with the led one, I'm glad I did. Vizio has a good reputation... you can't go wrong. I was after one, but since they didn't have them in stock, I went with the Sony.
jack54 is offline
Old 07-19-2014, 08:35 AM
Eternitay's Avatar
Originally Posted by kbeam418 View Post
There are LG plasma TVS at the restaurant that I work at and they're bright enough so I doubt a plasma wouldn't be bright enough in a house.
Not all plasmas are created equal, the F5300 is known to have poor performance in a bright room.
http://www.rtings.com/reviews/tv/plasma/samsung/f5300
Eternitay is offline
Old 07-19-2014, 08:59 AM
Eternitay's Avatar
Black levels and contrast will appear better on the Vizio M than the samsung when the lights are on or the blinds are open.
If possible you should try to buy from somewhere with a good return policy that offers both models, try the cheaper one first, and if you end up not liking it then return it for the other. If that isn't a option, my vote would go for the Vizio, but only because the majority of my viewing is during the day in a room with windows off to the side.
Old 07-20-2014, 09:15 PM
kbeam418's Avatar
Location: 41.7080574, -83.5911255 N41° 42.4834', W083° 35.4675'
Liked: 47
Yep just like all LCD TV are not created equal, my Samsung LCD has a great picture and no flash lighting issue, just depends on the brand. With that being said I wouldn't buy a plasma for day time but I had to have my backilght on max when I lived in a bedroom with a window, I love my basement
"Then one day you find ten years have got behind you no one told when to run you missed the starting gun."
kbeam418 is offline
taboola here
