AX900 and Display Port Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-16-2014, 11:31 AM - Thread Starter
tjcinnamon's Avatar
Quoted: 928 Post(s)
Liked: 228
If I'm going from an HTPC via displayport presumably I'd bypass the receiver. If I bypass the receiver then what medium would I use to pass audio to the receiver (optical?) If optical then won't I run into bandwidth issues transporting super high def (Atmos) audio?
JOe K.
tjcinnamon is offline
post #2 of 6 Old 07-16-2014, 03:23 PM - Thread Starter
tjcinnamon's Avatar
Quoted: 928 Post(s)
Liked: 228
is this in the wrong section of the forum? If so, could I mod move it to the correct section?
post #3 of 6 Old 07-16-2014, 10:33 PM
dfs88801's Avatar
Quoted: 42 Post(s)
http://www.amazon.com/Xtrempro-Displ...ort+cable+1.2a
IN MY R9 290 THE Display Port Better from HDMI
dfs88801 is offline
post #4 of 6 Old 07-18-2014, 10:29 AM - Thread Starter
tjcinnamon's Avatar
Quoted: 928 Post(s)
Liked: 228
so then how do you transmit audio to an external receiver? And in what format?
post #5 of 6 Old 07-29-2014, 04:31 AM
dfs88801's Avatar
Quoted: 42 Post(s)
AC3 / DTS AND MORE
BUT NOT HD Sound
dfs88801 is offline
post #6 of 6 Old 07-29-2014, 12:57 PM
Dr.Savage's Avatar
Quoted: 22 Post(s)
Liked: 25
you may be able to run displayport from pc to TV, and run HDMI from PC to receiver (only for sound).
However, depending on Video card or sound card, I am not sure what sound you will get. As DFS mentions you may be at the AC3/DTS levels.
Does your video card have hdmi and display port? I do something similar for Xbox one: I use a splitter for HDMIs (one for Projector and the other HMDA for sound to receiver). Good luck!
Dr.Savage is offline
Reply LCD Flat Panel Displays
atmos , ax900 , bandwidth , displayport
