Sony KDL-52V4100 ARC and Audio Output? - AVS Forum | Home Theater Discussions And Reviews
Old 07-21-2014, 09:40 AM - Thread Starter
Liked: 0
Does the Sony KDL-52V4100 support the audio return channel to be used with outputting TV broadcast audio?
Hyperspace is offline
Old 07-21-2014, 02:17 PM
Otto Pylot's Avatar
Quoted: 1360 Post(s)
Liked: 852
Yes. Both devices have to support ARC for it to work. If you are using the tv's built-in ATSC tuner or the SmartApps, if your tv is internet ready, you can use an optical cable from the tv to the receiver. That's what I do for OTA television. All you have to do is select the correct input and you're good to go. The only advantage of ARC is that it eliminates the use of an optical cable. Both are limited to 5.1 audio.
Otto Pylot is offline
