[Urgent]Mounting TV - Can spacer be used the opposite way? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-27-2014, 07:27 PM - Thread Starter
Liked: 0
Can the spacer be used the opposite way in this photo? The spacer would be on the outside rather than be between the tv and mounting bracket.
a_minimalist is offline
post #2 of 5 Old 07-27-2014, 07:47 PM
sgayres's Avatar
One reason for the spacer is to elevate the mount from the rear cover of the TV. I've been sent to correct "buzzing speaker" issues and the problem turned out to be audible vibration between the mount and the rear cover at certain frequencies. But repairing many sets, I've seen many with the spacer on the outside.
sgayres is offline
post #3 of 5 Old 07-27-2014, 07:52 PM
robshdtv's Avatar
Yes you can. I assume you're doing this so you can still use the longer bolt. Just make sure you will have enough space to pass your cables, power, hdmi, etc... Last thing you want to do is hoist a tv up and realize you can't plug anything in.
robshdtv is offline
post #4 of 5 Old 07-27-2014, 08:13 PM - Thread Starter
Liked: 0
Thanks guys. I just ended up going to get a slightly shorter screw. Question for you sgayres though. Is the reason for the audible vibration from the spacer? Should I expect that since I have to use one?
post #5 of 5 Old 07-27-2014, 09:59 PM
sgayres's Avatar
No - the vibrations that I've seen were caused by no spacer where the vertical mounting bar was directly contacting the rear cover of the TV. End users complained that when their sets were turned up loud on a movie or music program, certain frequencies would cause the buzzing noise. The first time I ran into one of these, it took a while to figure out that the back of the TV was vibrating against the mount. Because of this possibility, I always isolate the TV and mount with plastic or rubber spacers.
sgayres is offline
Reply LCD Flat Panel Displays
