Tell me if this TV is good - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 07-28-2014, 11:27 AM - Thread Starter
Liked: 0
Hey guys, so i decided to upgrade the TV I'm using, i have a tv with no brand that says its 1080p but its probably 20p. Went around shops, most intriguing tv i've found in my budget is
Samsung UA48H6400 .
I'll be using it mostly for gaming and movies. Don't worry about the distance since there's a fairly big distance from where i'm playing / watching ( Using controllers, not mouse and keyboard )
Is there any reason i shouldn't get this ? ( I'll be hooking it up to my pc via hdmi )
I was told it's 400hz, 3d, smart, and basically a top tier TV .
Found another slightly cheaper ( 100$ cheaper only ) TV with similar Specs. LG 47LB6520 .
Any reason to get the LG over the Samsung?
Input much appreciated!
Zaidrockso is offline
Reply LCD Flat Panel Displays
