Sharp LC-70LE650U ghosting watching sports - AVS Forum
post #1 of 4 Old 07-29-2014, 11:34 AM - Thread Starter
Liked: 0
hey guys, just got this tv and noticed some ghosting around the player while watching sports. Does anyone know a way to get rid of it? Or is the 120hz refresh rate not fast enough? Thanks for your input.
tkc324 is offline
post #2 of 4 Old 07-29-2014, 12:20 PM
johnfull's Avatar
Quoted: 149 Post(s)
Liked: 61
Sharp gives you a couple of options -- use backlight strobing (AquoMotion, etc.)
or use frame interpolation (Film Mode). The 120 frame rate is probably ok,
but it is compounded by frame rate and by LED flicker. One or both may help.
johnfull is offline
post #3 of 4 Old 07-29-2014, 05:50 PM - Thread Starter
Liked: 0
John... thank you for your reply. I will definitely give it a shot. Would the ghosting be completely eliminated had this been the 240hz model? I think sports is the only genre giving this tv issue right now.
tkc324 is offline
post #4 of 4 Old 07-30-2014, 01:57 AM
johnfull's Avatar
Quoted: 149 Post(s)
Liked: 61
The panel refresh rate is only one of three factors that can effect motion.
I had a 120 refresh rate TV for 2 years and they replaced it with a new 240 refresh
rate TV on a warranty claim. Both have the same features as regards frame rate
and backlight strobe. Without any extra features on, the backlight strobing is the
most obnoxious to my eyes -- leaving a trail of individual images when there is motion
or when the eyes themselves move too fast. Turn on the level of backlight strobe that
you can live with -- the highest one causes the picture to dim, so avoid that one.
If you watch anything that is filmed, the frame rate will make objects jerk as they move
sideways across the screen -- just as they do in the movie theatre, by the way.
The Film Mode will fix that -- not usually needed for live sporting events, though.
The actual LCD panel refresh rate is fast enough these days to leave very minor smears.
I think what you are seeing is backlight strobe effect. Try 240 Low first and work up from there.
tkc324 likes this.
johnfull is offline
Reply LCD Flat Panel Displays
Gear in this thread - LC-70LE650U by PriceGrabber.com
