Any True FALD 70" and Up - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-31-2014, 01:20 AM - Thread Starter
latreche34's Avatar
Quoted: 140 Post(s)
Liked: 64
Are there any true full array LED TV's 70" and up with active 3D in the market now, I see a lot of edge lit ones but cannot find full array at least in my local stores.
latreche34 is offline
post #2 of 3 Old 07-31-2014, 06:52 AM
westa6969's Avatar
Quoted: 398 Post(s)
Liked: 418
Cool
What's the reasoning behind ACTIVE 3D needs? The passive reviews are usually the best that I've read. Vizio ended 3D so their new models have FALD "M" soon to be released "P" but they no longer include 3D. LG 79" I believe is FALD but passive 3D and Panasonic AX900 may be using LG Glass and likely passive.
Sony x950B giant may have both FALD and Active but likely is priced around $25K. Ouch!
If you want something that will BEST FALD with 4K and passive 3D the LG 65" OLED to be released in the next couple of months will be likely the best of all worlds unless you have a budget for a $20K 77" model. Good Luck!
Samsung 75HU8550w/SEK-3500-UHDVideoPk, 65F8000, 60D8000, 40HU6350, Philips Folio Soundbar
XBoxOne/360, FPS's Borderlands 1/2, EDF 2017/2025, Halo's
westa6969 is offline
post #3 of 3 Old 07-31-2014, 12:09 PM - Thread Starter
latreche34's Avatar
Quoted: 140 Post(s)
Liked: 64
If you want something that will BEST FALD with 4K and passive 3D the LG 65" OLED to be released in the next couple of months at about $6K price tag will be likely the best of all worlds unless you have a budget for a $20K 77" model. Good Luck!
My budget is arround $5k, I would like 70" and up based on the distance where I sit away from the wall, I like active 3D better I've had flickering problems with my old passive 3D set, although active is darker a little bit but that's not a problem with my dark living room, I'm aware that with 4K panels active vs passive is not a problem any more, but if 3D goes 4K than we go back to the same argument with HD panels before interlaced 3D (540 lines Passive) vs progressive 3D (1080 lines Active), Thanks for pointing out that LG is going 4K OLED I can wait for that to go down to my budget limit I don't mind 5" less which translates to about 2" less on width and height.
Reply LCD Flat Panel Displays
