Problem with input signal - LG 46LD550 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-06-2014, 01:39 PM - Thread Starter
Liked: 0
Question HELP please! Problem with input signal - LG 46LD550
I have an LG 46LD550 that was working great up until a few weeks ago. The HDMI inputs are not working anymore, so playing Playstation and streaming Netflix is not currently possible. I bought a new main computer board and installed that, tested it one night by watching Netflix (streamed through Playstation), and then the next morning it no longer worked. The tv doesnt recognize HDMI inputs from my laptop, either.
What could be wrong and how do I fix it?
CoffeeCup33 is offline
post #2 of 6 Old 08-07-2014, 06:48 AM - Thread Starter
Liked: 0
bump for help.
post #3 of 6 Old 08-07-2014, 07:10 AM
hammerdwn's Avatar
Quoted: 173 Post(s)
Liked: 53
So all your testing involves a Playstation and a laptop. If you have replaced the Main board in the Tv then start looking external at the hdmi cables and devices. Factory Reset the Playstation. Get a hold of a bluray player to plug in to it. Attempting to connect with a laptop can be tricky on a working Tv, so trying in a diagnosis situation may not be helpful.
XBR-65Z9D | AVR-X2200W | UBD-K8500 | JRMC HTPC w/9 cable tuners | Fluance SV 7.1 + eD A3-300
hammerdwn is offline
post #4 of 6 Old 08-07-2014, 01:58 PM - Thread Starter
Liked: 0
Thanks for the ideas. Ill find a new cable and another device, as you suggested.
post #5 of 6 Old 08-12-2014, 10:48 AM - Thread Starter
Liked: 0
I connected a Roku 1 with a new HDMI cable and kept the PS3 connected with its original cable. Both were able to connect/be usable but usually only after sitting on the "no input" screen for a few minutes.
Would that suggest that it is not the input board but is instead one of the wires leading from the input board to...wherever it goes to? Should I look at something else?
post #6 of 6 Old 08-12-2014, 04:57 PM
hammerdwn's Avatar
Quoted: 173 Post(s)
Liked: 53
only thing inside tv that could cause this is the main board
Reply LCD Flat Panel Displays
46ld550
