DSE on LG LB7200 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-14-2014, 02:54 AM - Thread Starter
Liked: 0
DSE on LG LB7200
Hello Everyone,
I just purchased LG 55LB7200 less than a week now and i found out dark areas on the corners as well as near the vertical edges
This is my first LED tv as i used to have LG plasma
I was wondering if its a common issue for LED and i have to live with it, can it be fixed or i should return it and get another set or change the series or brand.
Thanks a lot
mosama is offline
post #2 of 3 Old 08-16-2014, 11:46 PM - Thread Starter
Liked: 0
Hello Everyone,
Just for update I've called customer service and the technical guy confirmed that my TV has some sort of Light Leakage (i'm not sure the technical terminology for that)
The good news is that they will replace it
Thanks everyone
mosama is offline
post #3 of 3 Old 08-17-2014, 10:59 AM
mrwiseguy85's Avatar
Quoted: 23 Post(s)
I know this video has been making the rounds for people inquiring about this model of TV on other sites:
There seems to be some concerns with build quality for that particular model this year. Hopefully your replacement is less noticeable and you can enjoy your new TV!
mrwiseguy85 is offline
Reply LCD Flat Panel Displays
dse , lg lb7200
