Samsung LN40B530 (P7NXZA) Color Issue - AVS Forum
post #1 of 4 Old 08-26-2014, 10:38 AM - Thread Starter
JustinRizzo's Avatar
I have had this TV for 4-5 years, purchased new. I recently moved back to home to Indiana from Texas. This time during the move I left the TV on it's stand instead of placing it on a couch, as I have in the past. Upon plugging it in I noticed the colors were off (even on the menu's, so it's not an input failure). I figured a cable had come loose, so I took the back off and reseated every single cable, including the LVDS cable and the two flat ribbon cables coming off the T-Con board. I was unable to reseat the other end of those ribbon cables, as I would have to detach the entire metallic shell/frame. However, these attempts failed. I pushed, tapped and jiggled the LVDS cable with the TV on, and no luck. Most importantly, I have learned that after 10 to 30 minutes the colors will restore / revert back to normal. Now, I don't mind waiting 10 minutes, but 30 minutes is excessive.
At this point I am considering replacing the T-Con board and the LVDS cable. I can grab the board from a eBay seller in China for ~ $30 and a used LVDS cable for ~ $10. However, I was wondering if anyone else has had this issue or if anyone can advise me otherwise.
I have attached a photo displaying the color issues I have as well as how it looks after the TV has "adjusted" itself. I really appreciate any help that can be offered. I'd hate to waste money on new parts if it will not solve me problem.
JustinRizzo is offline
post #2 of 4 Old 08-26-2014, 05:07 PM
Super Moderator
DrDon's Avatar
Quoted: 56 Post(s)
Liked: 251
Please read the sticky notes before posting. Thanks.
Moved to proper section.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
post #3 of 4 Old 08-26-2014, 08:08 PM - Thread Starter
Thanks, and I apologize for that. Anyone have any ideas on this complication? At first I thought something in the TV was faulty and "corrected" itself after warming up. However, once the TV has adjusted, if I turn it off and immediately back on, the issue returns for another lengthy period
post #4 of 4 Old 08-27-2014, 04:01 PM - Thread Starter
Bump.
Reply LCD Flat Panel Displays
User Tag List
