UN55HU8550 + Denon AVR-2112CI Audio Return Control - AVS | Home Theater Discussions And Reviews
post #1 of 10 Old 08-31-2014, 01:18 PM - Thread Starter
Liked: 0
I've been having difficulties with getting my new Samsung TV UN55HU8550 to work with my Denon AVR-2112CI using ARC. My goal is to be able to have the sound of the Samsung Smart TV apps to go through my Denon receiver.
Right now I have a brand new high speed HDMI cable connected from HDMI 4 on the Samung TV to the monitor out of the Denon receiver. Both of these ports are labelled ARC. I have also enabled HDMI control on the Denon receiver. Which after doing this I was able to select "receiver" as the TV sound output via the Samsung speaker settings.
Here are the HDMI settings I have on the receiver:
Audio Lip Sync: On
HDMI Audio Out: AMP
HDMI Control: Yes
Standby Source: Last
P. Off Control: All
and my Samsung speaker settings:
TV Sound Output: Receiver
While using the volume up/down on the Samsung remote I see on screen next to the speaker icon "AVR-2112". So it seems like some part of the audio return control is working.
I have even tried unplugging all the the HDMI inputs I have going into the receiver (i.e. cable box, bluray, apple tv) with no luck.
Using an optical cable going from the tv to receiver and that seems to work. However I really would prefer to get the audio return control working.
Is there anything else I can try? Is there something else I need to set on the receiver? Do I need to set the input selector on the receiver to a particular one?
I thought this was going to be easy but after spending a few hours on it I almost ready to admit defeat. I wonder if the issue is with the denon receiver.
thanks for any help,
Scott.
scottfwalter is offline
post #2 of 10 Old 08-31-2014, 03:03 PM
JChin's Avatar
Quoted: 177 Post(s)
Liked: 151
Hi scottfwalter, you didn't mention but enable the TV HDMI Control - Samsung AnyNet+ and ARC.
JChin is offline
post #3 of 10 Old 08-31-2014, 03:10 PM
HDMI Guy's Avatar
Quoted: 116 Post(s)
Liked: 31
Scott.
Yes
HDMI Guy is offline
post #4 of 10 Old 08-31-2014, 03:35 PM
JChin's Avatar
Quoted: 177 Post(s)
Liked: 151
Originally Posted by HDMI Guy View Post
Yes
Hi HDMI Guy, when ARC is enabled and working correctly, the Denon will automatically switch to "TV" source input, no need to manually switch input.
JChin is offline
post #5 of 10 Old 08-31-2014, 04:25 PM - Thread Starter
Liked: 0
I have AnyNet+ enabled. Is there anything specific I need to do enable ARC? I couldn't find anything related to ARC in the menus on the Samsung.
post #6 of 10 Old 08-31-2014, 06:31 PM
JChin's Avatar
Quoted: 177 Post(s)
Liked: 151
Maybe the newer Samsung is slightly different. I don't use Samsung ARC anymore but remember selecting the app (Netflix) first then opening the AnyNet+ menu which gave some option for audio.
JChin is offline
post #7 of 10 Old 08-31-2014, 08:45 PM
HDMI Guy's Avatar
Quoted: 116 Post(s)
Liked: 31
From owners manual
" Certain functions such as Smart Hub may not be available if the Source is set to HDMI and 3D Auto View is
set to On. If this is the case, set 3D Auto View or 3D Mode to Off."
HDMI Guy is offline
post #8 of 10 Old 09-01-2014, 05:34 AM
mikepier's Avatar
Quoted: 12 Post(s)
I find ARC more problematic, and while it works well on some devices, it does not on others. So I just simply use a dedicated optical cable from the TV to the amp. It is the net same result.
mikepier is offline
post #9 of 10 Old 12-28-2014, 10:01 PM
eaadams's Avatar
I was wondering if you ever solved this?
My issue: I have a Vizio 60" m602i-b3 connected to my Denon 2112 via HDMI (proper ports) and have got it to the point where if I hit the TV power button it turns of the Denon. However, I get no app audio from TV to the Denon. Also when I hit power 'on' to the Vizio it doesn't turn on the Denon.
eaadams is offline
post #10 of 10 Old 03-24-2015, 10:50 AM
SiegeX's Avatar
I have the 60" version of the HU8550 as well as a Denon 2112CI and I was able to get this to work. I had all the settings for the HDMI control as in the OP's first post. Going into the Samsung menu it then allowed me to select 'Receiver' for audio also as described. I think I might have needed to power down both units, then turn on the TV which then turned on the receiver proving the control is working.
For you to get audio from your Samsung Apps (like Netflix), the AVR *must* be set to the 'TV' input and as mentioned the TV automatically instructs the AVR to go to this input every time you power up for the first time. This is also pretty damn annoying if you intend to watch Sat/Cable upon power up. Thankfully my Harmony 900 remote has a work-around for this by allowing me to set the "warm up" delay to instruct the AVR to change imputs from the default of 1500ms (1.5 sec) to 20000ms (20 sec). My TV is wall mounted and it is a bitch and a half to run a new cable through the fireplace enclosure to the component cabinet some 6 or so feet away. Had I had the foresight to run an optical cable during construction I would have.
I have yet to play with the menu system yet on the Samsung, where is this option to turn off AnyNet+?
SiegeX is offline
Reply LCD Flat Panel Displays
Gear in this thread - UN55HU8550 by PriceGrabber.com
