help with samsung syncmaster mp710 - AVS | Home Theater Discussions And Reviews
Old 09-22-2014, 10:36 PM - Thread Starter
Liked: 0
Question help with samsung syncmaster mp710
sorry if this is the wrong thread. i am new to this forum. i work at macys and the location i work in has 17" samsung syncmaster mp710 tvs in the fitting rooms. back when i started there, i made sure all the tvs were up and running. one of them in the mens department on the 1st floor power up just fine, but it acts like its barely getting a signal. it takes a while to get a good tune. after i reached the ladies department on the 2nd floor, i found almost all of them not working. i turned them on and the result? the little green light is very dim, it barely lights up. and there is no picture coming from the tvs. i try turning them off, but it stays on and does not respond at all. one of them does the same thing, but it makes a weird noise through the speakers. i unplugged it because im sure it annoyed the shoppers. i plugged it back in about a month later and it got louder and worse so i unplugged it once again and will definitely leave it unplugged. meanwhile, there is one that seems to power up fine with the green light fully lit, but the screen just cuts off about a few seconds. anybody have a solution to these problems?
thamikestab0y56 is offline
Old 09-27-2014, 01:46 PM - Thread Starter
Liked: 0
Really people? You dont wanna help me? How lazy of you... :P
