70-75" 4K TV with 4:4:4 color resolution? - AVS Forum
post #1 of 3 Old 10-15-2014, 06:32 PM - Thread Starter
maxl's Avatar
I need a TV for slideshows, ideally 75" but 70" will work too. Given the content, 4K and full color resolution are important. I do not care if it can get full resolution via HDMI 2.0 (it seems none currently do) or via display port or another connection - any way will do. I was considering Visio P until I found out that it's not 4:4:4 on HDMI and has no other inputs (also no 75" but at least 70").
What other options I should look into? The budget is $6500 street price.
maxl is offline
post #2 of 3 Old 10-16-2014, 05:12 AM
westa6969's Avatar
Quoted: 201 Post(s)
Liked: 196
Problem be that no manufacturer I've ever seen advertises this capability in their spec's and it's certainly not part of the CEA 4K UHD minimum standards.
Thus if it's so important to you then you'll either have to await a pro review or examine every single spec sheet yourself. Not a mandate for UHD and not a bullet point.
Thus, here's a discussion on it here you may be able to decipher some helpful info.
http://hardforum.com/showthread.php?t=1837209
Samsung 65F8000, 60D8000, 40HU6350, Panasonic 50E60 LCD's
westa6969 is online now
post #3 of 3 Old 10-16-2014, 06:23 AM
Hisma's Avatar
Quoted: 342 Post(s)
Liked: 141
2014 4K LG sets are confirmed to work 4K 60 Hz @ 4:4:4 via HDMI 2.0.
So that means the 79UB9800 should do just fine for you.
retail price is around $6900, but street price should be cheaper. Check with forum sponsor @Cleveland Plasma .
Hisma is online now
Reply LCD Flat Panel Displays
User Tag List
