1st, is there a way to roll back to a previous firmware of TV, before one installs newer and is screwed when it does not work?
2nd, why does the little blurb say, "Samsung not responsible for putting this firmware on TV" (blue box prior to downloading onto usb stick. Christ sakes, firmware can screw a tv up forever. They created the damn software, why not take responsibility for it?
3. I have my tv set so my smart hub always auto login's. As of late, it does not. Last time this happened, one of the main boards went kaput. Technician claimed it was due to undue firmware upgrades. He said just disable the update feature and the tv will be fine. Well, it won't be fine if some other app, say Netflix doesn't work with the TV's firmware. THat's where all this trouble begins. All a bunch of BS.
4. How do I disable the smart hub from taking auto updates? I have searched throughout. I need step by step because this does not just jump out at anyone.
5. Does a "real" Samsung support forum exist, other that the crappy "go Sammy" thing found on Cnet? Stupid and not friendly.
Thx, Greg
Thx, Greg
