First i wanna say hi to the forum as this is my first post
Now, i have one problem with my brand new Samsung 55" 3D tv. When i recived it from the store after one week i noticed one black stain in the middle of the screen. I went back to the store and told them about the problem. They said its the panel issue and they will replace the panel since they dont have any other same tv's on stock. So after one week i recived my tv back with no black or white stains at all. But then i realized that when i'm playing 3d movies i simply cannot get sharp image at all perspectives. If the front object is sharp the back objects are blury with shadows. If i use the option 3d perspective in 3d menu i can make back object sharp but then are front ones blurry with shadows. What is the problem? Is this panes with fault ? I must say that before i gave it back to repair the 3d picture was perfect withouth any bluriness or shadows?
Thanks in advance!
Thanks in advance!
