SONY KDL60R510A Discussion Thread
48K views 122 replies 42 participants last post by  Chase Payne
#1 · (Edited)
This TV has been showing up in the usual places, does anyone have any comments, advise or reviews about it?
Product Specifications
  • Audio
    • Audio Power Output : 10W + 10W
    • Speaker Configuration : 2ch, Full Range x 2
    • Speaker Position : Down Firing
  • Audio Features
    • Alternate Audio (Digital) : Yes
    • Digital Out Format : Dolby Digital, PCM
    • Auto Mute (on no signal) : Yes
    • Sound Mode : Standard; Music; Cinema; Game; Sports
    • Sound Booster : Yes
    • Stereo System : MTS (AUTO SAP)
    • Audio Out : Fixed / Variable
    • Dolby® : MS10 (Dolby Digital Plus, Dolby Pulse)
    • 5.1 Channel Audio Out : Yes
    • SteadySound® Automatic Volume Control : Yes
  • Convenience Features
    • Picture Adjustments Lock : Yes
    • On/Off Timer : Yes
    • Auto Shut-off : Yes
    • On-Screen Display for External Input : Yes
    • Info Banner : Yes
    • Parental Control : Yes
    • Channel Block (with password) : Analog & Digital
    • BRAVIA® Sync™ : Yes
    • Twin Picture : Extended PIP & PAP
    • USB Play (Contents) : MPEG1 / MPEG2TS / MPEG2PS / MPEG4 Visual / MPEG4AVC / H.264 / WMV / Xvid / MP3 / AAC / HE-AAC / DolbyDigitalAC3 / WMA / Jpeg
    • Scene Select : General; Music; Cinema; Game; Graphics; Sports; Auto
    • Show/Hide Channels : Yes
    • Photo Frame Mode : Yes
    • USB Super Multi-Format Play : Yes
    • Favorites (Simple UI) : Yes
    • Label Inputs : Yes
    • USB Play : Yes (USB viewer supports FAT16, FAT32 and NTFS file systems.)
    • Channel Jump : Yes
    • On-Screen Clock : Yes
    • Edit Channel Labels : Yes
    • Channel Surf : Yes
    • Multiple Language Display : English; Spanish; French
    • Sleep Timer : Yes
    • Input Skip : Yes
  • Design Features
    • Stand Design : Plastic
  • Display
    • Screen Size (measured diagonally) : 60" (60")
    • Refresh Rate : 120Hz
    • Display Resolution : Full HD
    • Viewing Angle (Up/Down) : 88/88 degree
    • Aspect Ratio : 16:9
    • Screen Size (cm) : 152.7 cm
    • Dynamic Contrast Ratio : Over 1 million
    • Viewing Angle (Right/Left) : 88/88 degree
  • Display Features
    • Display Device : LCD
    • Dimming Type : Frame Dimming
  • Energy Saving & Efficiency
    • Power Saving Modes : Yes
    • Energy Star® compliant : Yes, V6
    • Dynamic Backlight Control : Yes
    • Backlight Off Mode : Yes
  • General Features
    • Hotel Mode Menu : Yes
    • Closed Captions (CC) : Analog; Digital
    • Demo Mode : Yes
    • Finish (Surface Color) : Black
    • Start Up Sony Logo Display : Yes
    • Audio Return Channel : Yes
  • Inputs and Outputs
    • Analog Audio Input(s) (Total) : 1 (Rear)
    • Component Video (Y/Pb/Pr) Input(s) : 1 (Rear Hybrid w/ Composite)
    • Audio Out : 1 (Rear)
    • USB 2.0 : 1 (Side)
    • Composite Video Input(s) : 1 (Rear Hybrid w/ Component)
    • AC Power Input : 1 (Rear)
    • HDMI™ Connection(s) (Total) : 3 (2 Rear / 1 Side)
    • Ethernet Connection(s) : 1 (Rear)
    • HDCP : HDCP 1.4
    • MHL : Yes, 2.0
    • RF Connection Input(s) : 1 (Rear)
    • HDMI PC Input Format : 640x480@60Hz; 800x600@60Hz; 1280x768@60Hz-R; 1280x768@60Hz; 1360x768@60Hz; 1024x768@60Hz; 1280x1024@60Hz; 1920x1080@60Hz
    • Digital Audio Output(s) : 1 (Rear)
    • HDMI™ PC Input : Yes
  • Network Features
    • Wi-Fi Standard : b/g/n
    • Wi-Fi Frequency : 2.4GHz
    • TV Tweet : Yes (Opera)
    • DLNA Content : JPG / MP3 / WMA / MPEG1 / MPEG2PS / MPEG2TS / AVCHD / MP4 / WMV
    • Sony Entertainment Network : Yes
    • Wireless LAN : Integrated
    • Opera Apps (System) : Yes
    • Wi-Fi Certified : Yes
    • Internet Browser : Yes (Opera)
  • Power
    • Power Requirements (frequency) : 60Hz for UL cUL 50/60Hz for other
    • Power Requirements (voltage) : AC120V for UL cUL AC110-240V for other
  • Regulation and Standards Compliance
    • VESA® Hole Spacing Compatible : Yes
  • Service and Warranty Information
    • Limited Warranty Term : 12 months
  • TV System
    • TV System (Analog) : M
    • Number of Tuners (Terrestrial/Cable) : 1 (Digital / Analog)
    • Channel Coverage (Analog) : VHF: 2-13 / UHF: 14-69 / CATV: 1-135
    • Channel Coverage (Digital Terrestrial) : VHF: 2-13 / UHF: 14-69
    • TV System (Digital Terrestrial) : ATSC
    • TV System (Digital Cable) : Clear QAM
    • Channel Coverage (Digital Cable) : CATV: 1-135
    • Color System : NTSC
  • Video
    • Video Signal : 1080/24p (HDMI™ only); 1080/60i; 1080/60p (HDMI™ / Component); 480/60i; 480/60p; 720/60p; 1080/30p (HDMI™ only); 720/30p (HDMI™ only); 720/24p (HDMI™ only)
  • Video Features
    • 3D Comb Filter : Yes
    • MPEG Noise Reduction : Yes
    • Blinking Type : Frame Blinking
    • Wide Mode : Full; Normal; Wide Zoom; Zoom; Normal / Full1 / Full2 for PC timing
    • 4:3 Default : Yes
    • Digital Noise Reduction : Yes
    • Picture Mode : Vivid; Standard; Custom; Cinema; Graphics
    • 24p True Cinema™ Technology : Yes
    • Auto Wide : Yes
    • CineMotion® Reverse 3:2 Pulldown Technology : Yes
    • Live Color™ Technology : Yes
    • Advanced Contrast Enhancer (ACE) : Yes
    • Motionflow™ Technology : Motionflow XR 240
    • LED Motion Mode : Yes
    • Clear Resolution Enhancer : Yes
  • Weights and Measurements
    • Packaging (Approx.) : Carton dimensions: 62 5/8 x 34 5/8 x 6 7/8 in (1590 x 878 x 172 mm) Carton weight: 57.3 lbs (26.0 kg)
See less See more
#120 ·
I got this TV in on Monday 3/2. I am waiting to mount this bad boy until I have everything I need on hand to hide the wires and what not. In the mean time I have been testing the picture using an antenna. I can see this set having great potential and looks very solid after my own tweaking, but I still have some minor issues I would love if someone could help me fix.
Blotchy/Grainy black and dark content. (This is only noticeable in SOME black or dark content, other times the darker sections look deep and seamless)
Consistent color transitions. (For example, light red fading to dark red shows "sections of fade" rather than being a smooth color transition, again only sometimes)
Some color bleeding (Skin and other similar content can be over taken by a redish hue, again only sometimes)
How can I make the colors seem a touch more vibrant without creating color bleed. (In comparing to my 46" Sharp from 09, the Sharp handles more vibrant colors without color bleed. Setting the Sony to not have any color bleed leaves it feeling a bit drab)
I know it sounds like a lot of issues, but they are all minor in nature. It would just be nice to have these areas perfected.
Here are my settings:
Picture Mode: Standard
Backlight: 5
Picture: 90
Brightness: 20
Color: 62
Hue: 0
Sharpness: 10
Color Temperature: Neutral
Noise Reduction: Off
MPEG Noise Reduction: Off
Motionflow: Off
CineMotion: Off
Adv. Contrast Enhancer: Off
Black Corrector: Off
Gamma: +1
Clear White: Off
Live Color: Off
LED Motion Mode: Off
Thanks in advance!
#122 ·
Hello everyone, I must say this TV is amazing! I noticed everyone here has their own personalized profile, but it seems to exaggerate way too much on colors! A wonder tool that some people may have are the new iPad airs, which have very close to accurate color fxphd.com/blog/just-how-good-is-the-ipads-color
The biggest issue with this TV is the reds, they are slightly off. Because of that, the best image to calibrate your screen, is this one below:
mrshustle.files.wordpress.com/2012/09/desktop10.jpg
Take your iPad and compare that image to your TV, you may notice it's completely off! Here are the settings I used to get the display as close as possible to accuracy of brightness and contract, to colors similar to the iPad on full brightness. You can test it out before changing your settings, simply change the Picture mode from anything you want other than the current one you are using... all of the settings are saved on the picture mode itself.
Backlight: I keep this at 3, but some may want it at at-least 5.
Picture:80
Brightness:70
COlor:46
Hue:G3
SHarpness:2
Color Temperature: Nuetral
Gamma -3
This TV has way too much gamma, so you should keep it at -3. If you look at lagom.nl/lcd-test/gamma_calibration.phpgamma -3 at these settings makes it close as possible to perfect Gamma as 2.1 is almost fully blended.
If you are using a PC, it is very important to change your color range from limited to full as the reds will not look very accurate if left on limited.
Now, change your picture mode from whatever you just set it to, then back to whatever you had. You should see a much more noticeable difference between the two.
Every TV is different, so my settings may not work as well for you.
#123 ·
Sorry, I don't see an edit button on my post.
But one thing I should point out, my settings may looks less colorful. But you'll notice in the comparison of the red lipstick model, when you have a more colorful settings you're losing a lot of detail; this is because you're using an over-saturated setting that is not true color.
