Samsung le40a756r1m lines on screen - AVS Forum
post #1 of 1 Old 01-18-2015, 09:45 AM - Thread Starter
Liked: 0
Hello everyone,
I was just wondering if there's anyone who could maybe give some advice as to what is possibly wrong with my tv and what might need fixing?
It's a Samsung le40a756r1m. The screen is covered with vertical lines all different colours. If I press the menu button and scroll along or press other buttons, the lines moves sideways as though the screen is still showing the commands but the picture has just been replaced by the lines. Sometimes if i press the menu button etc, the screen will fade to black still with faint lines around the edges and then the full lines appear again.
I have just let the tv warm up a bit and it is now showing a pictue but it's still made up of lines - almost as if the picture is fine and then there is a layer of now horizontal lines over the top.
If anyone can suggest what the problem could be I'd be very grateful, thank you.
emily3248 is offline
Reply LCD Flat Panel Displays
