Samsung JS9500 owners thread - Page 44 - AVS Forum | Home Theater Discussions And Reviews
 5446Likes
post #1291 of 12449 Old 05-06-2015, 05:06 AM
rlb
rlb's Avatar
Quoted: 1787 Post(s)
Liked: 1458
Originally Posted by Micke_ View Post
I have just received my Samsung 88 inch (9500) first delivery in my country. Anyone knows what version of hdmi input? is there any hdmi Cable that has better version than 1.4? Just so I use the best Cable for the future
Samsung has HDMI 2.0. Use "high speed"/cat 2 cables. Standard cables are only other version. High speed/cat 2 have been required beginning with HDMI 1.4. http://www.hdmi.org/manufacturer/hdmi_2_0/index.aspx
rlb is offline
post #1292 of 12449 Old 05-06-2015, 05:37 AM
Quoted: 54 Post(s)
Originally Posted by OneStepAhead View Post
Originally Posted by shinepushpan View Post
No, I meant IR sensor doesn't cone free with the TV. You need to buy separate. My 8550 had an IR sensor with the TV
You're talking about an IR Blaster, not an IR Sensor, the later of which every TV made in the past few decades has
Yupp. You are right. I realized after posting it and I was already in bed. Thanks for correcting me
shinepushpan is offline
post #1293 of 12449 Old 05-06-2015, 06:56 AM
bjorg's Avatar
Quoted: 143 Post(s)
Liked: 77
Originally Posted by 3dprojector View Post
any ventilation at the back?
That's an excellent observation. There are gaps at the top and bottom that should facilitate airflow, but I forgot to put my hand behind the set to see how hot it got. If need be, I could install a couple of low flow fans to assist. Thanks for bringing it to my attention!
Abstract yourself!
bjorg is offline
post #1294 of 12449 Old 05-06-2015, 06:57 AM
bjorg's Avatar
Quoted: 143 Post(s)
Liked: 77
HDMI 3 supports HDCP 2.2. I was able to connect the Sony FMP-X10 to it and it works like a charm.
(DISCLAIMER: I haven't yet watched a full movie. So I can't say if there are any audio/video drops. But the shorter clips, up to 10mins worked great!).
Abstract yourself!
bjorg is offline
post #1295 of 12449 Old 05-06-2015, 06:59 AM
bjorg's Avatar
Quoted: 143 Post(s)
Liked: 77
Wow, the sizing is perfect! What size set is that?
That's the 88". The layout was originally designed for the 85" Sony with a bit extra margin, which turned out to be just enough for the Samsung!
Abstract yourself!
bjorg is offline
post #1296 of 12449 Old 05-06-2015, 07:05 AM
bjorg's Avatar
Quoted: 143 Post(s)
Liked: 77
Originally Posted by dsinger View Post
I hope you are keeping the Elite until you are certain you won't return the Samsung. Tried a 78" HU9000 for a month and returned it due to a serious defect in backlight that developed after ~100 hours use. MY 70" Elite went back in service since I chose not to replace the Samsung. Elite never looked better after it's 30 day "vacation".
Definitively! I made that mistake last year already with the Sony! Fortunately, it was just moved to the office where it was going to end its days as a conference display. Did I ever under appreciate what I had! Using the Elite in a that kind of setting is blasphemy!
Event now, I think the Samsung has more clouding when Smart LED is turned off, but nothing as bad as what the Sony had. With Smart LED is set to Low, uniformity becomes excellent. No dead pixels spotted so far either. For now, this set is a winner!
timc1475 and wicklow like this.
Abstract yourself!
bjorg is offline
post #1297 of 12449 Old 05-06-2015, 09:37 AM
Spidergames's Avatar
Quoted: 201 Post(s)
Liked: 38
i would like to know, when was js9500 release date?
Spidergames is offline
post #1298 of 12449 Old 05-06-2015, 10:33 AM
Aluminum's Avatar
Quoted: 22 Post(s)
Liked: 25
The screen itself seems to run quite cool, I can't really find any warm spots on the back even after a full evening on. Most of the grunt work seems to be done by the UCB which can get a bit toasty.
When I stopped caring about super quiet: E5 1680v2 @ 4.5Ghz, 980ti, i750 SSD - JS9500 & Dell P2715Q for dual 4k@60 because reasons
SAN shares over 56Gb infiniband, microcenter + fleabay = severe risks to my wallet
Aluminum is offline
post #1299 of 12449 Old 05-06-2015, 01:02 PM
Verbow's Avatar
Quoted: 73 Post(s)
Liked: 60
Was at my local Chicago Magnolia and they had a couple 78JS9500s at the store (not displayed). Like OneStepAhead experienced - $15,000 and I could take one home, no discount.
Fortunately the Sony 75x940C is due to arrive in the warehouse May19 and stores the week after. I know this is a JS9500 thread, but a lot of would-be early adopters will be walking out the door with Sonys if Samsung doesn't get their head screwed on straight with pricing for the 78"...
Verbow is offline
post #1300 of 12449 Old 05-06-2015, 01:06 PM
wicklow's Avatar
Quoted: 327 Post(s)
Liked: 277
Verbow - were you at the bucktown location or in the burbs?
wicklow is offline
post #1301 of 12449 Old 05-06-2015, 01:07 PM
Verbow's Avatar
Quoted: 73 Post(s)
Liked: 60
Bucktown
Verbow is offline
post #1302 of 12449 Old 05-06-2015, 01:10 PM
wicklow's Avatar
Quoted: 327 Post(s)
Liked: 277
Bucktown
Thx.
wicklow is offline
post #1303 of 12449 Old 05-06-2015, 01:13 PM
Verbow's Avatar
Quoted: 73 Post(s)
Liked: 60
Originally Posted by wicklow View Post
Thx.
I was hoping you were going to say you were on your way to pick it up and I could check it out this evening😄
You're getting the 88" though, correct?
Verbow is offline
post #1304 of 12449 Old 05-06-2015, 01:30 PM
wicklow's Avatar
Quoted: 327 Post(s)
Liked: 277
Yeah, was just curious who had them in. I am in the western burbs and was told May 15th for arrival in the warehouse...
wicklow is offline
post #1305 of 12449 Old 05-06-2015, 07:12 PM
timc1475's Avatar
Quoted: 890 Post(s)
Liked: 755
No need to panic. There is an IR sensor on the bottom right of the TV! One of the little flyers that came with the set had a hint to its location.
Ok, everything is installed and it's working! Control4 is in charge of the whole thing now.
Check out the attached pic to see how tight it was, but it looks awesome! Now, let the tweaking begin!!
Very classy & tasteful bjorg, I like it. When can I move in btw?
If you always do what you always did, you'll always get what you always got.
timc1475 is offline
post #1306 of 12449 Old 05-06-2015, 07:21 PM
timc1475's Avatar
Quoted: 890 Post(s)
Liked: 755
Wow the 88" beast! Congads Micke! AFAIK the below cables will do the job and is what I will be getting soon. I am also going to get a new Cat6 Ethernet cable for optimum streaming. I will list that as well fyi.
HDMI 2.0 18Gb Link: http://www.amazon.com/Solid-Cordz%C2...+cable+4k+60hz
CAT 7 Ethernet Link: http://www.amazon.com/gp/product/B00...A2FI1E57JSSMJ2
Now go and enjoy that beauty! I wish it was me, but I am happy for you! lol
timc1475 is offline
post #1307 of 12449 Old 05-06-2015, 08:30 PM
slowcarboost's Avatar
Quoted: 397 Post(s)
Liked: 293
Just come back quick with lots of hands on impressions! I was at Best Buy again today checking it out(65 inch). I'm semi close to pulling the trigger. They had the LG OLED set up in Magnolia too...looks amazing but I don't see that price coming down to earth anytime soon. When will the 65 inch OLED drop to 5 grand you think? I figure it's at 9 now. The flat model might be 8500. When could we see $5000?
slowcarboost is offline
post #1308 of 12449 Old 05-06-2015, 08:49 PM
ray0414's Avatar
Quoted: 10137 Post(s)
Liked: 9084
3 years
ray0414 is online now
post #1309 of 12449 Old 05-06-2015, 11:00 PM
bekindrewind's Avatar
Quoted: 132 Post(s)
Liked: 58
I'm using Monoprice RedMere 18Gbps cables. Nice thing about these thin cables is they don't put any strain on the HDMI ports.
https://www.youtube.com/watch?t=33&v=m7xj3NsNxKc
PRO-70X5FD, McIntosh MC205, Marrantz MM8077, Marantz AV7702MKII (7.1.4), Oppo UDP-203, Oppo BDP-93, JL Audio f113, B&W Nautilus, Richard Gray 400S, Harmony One
bekindrewind is offline
post #1310 of 12449 Old 05-07-2015, 10:41 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 2933 Post(s)
Liked: 3102
So where are the pictures Box pictures would be nice as well, congrads .......
Cleveland Plasma is offline
post #1311 of 12449 Old 05-07-2015, 01:54 PM
dmercer3's Avatar
Quoted: 748 Post(s)
Liked: 412
screw those prices! go to monoprice
dmercer3 is offline
post #1312 of 12449 Old 05-07-2015, 01:55 PM
dmercer3's Avatar
Quoted: 748 Post(s)
Liked: 412
i know we all worked hard for our money and we all have our budgets.. but g*dd*mn do you guys make me jealous! (88" FALD!!!!)
AVmanic likes this.
dmercer3 is offline
post #1313 of 12449 Old 05-07-2015, 11:05 PM
Micke_'s Avatar
Quoted: 26 Post(s)
Thanks, I bougth Supra 4K Cables.
It is still in the box but waiting installation next week
Micke_ is offline
post #1314 of 12449 Old 05-08-2015, 03:47 AM
OneStepAhead's Avatar
Quoted: 386 Post(s)
Liked: 230
When your shelling out this much for a TV i suppose the cost of cables is moot. I used to be a big fan of monoprice but lately Ive had so many of their cables stop working or fall apart. I've now moved to Amazon for cables and prime shipping.
Sony XBR-75Z9D + Samsung 78JS9500 + LG 65OLEDC6P + 55EC9300 + 55EA8800 OLED
Denon X5200W + Integral + Oppo BDP-103D
MartinLogan Motion 60XT/50XT/FX/FX2/4 + Seaton Submersive HP+
Denon X6300h + Oppo BDP-103D + Xbox One S
Monitor Audio Silver 10's + Silver Center + CP-CT380's + 2x HSU ULS-15 MK2
3.1 MartinLogan Motion 40/30 + Rhythmik FV15HP + Yamaha RX-A3000 + Oppo BDP-103D
OneStepAhead is offline
post #1315 of 12449 Old 05-08-2015, 04:15 AM
dmercer3's Avatar
Quoted: 748 Post(s)
Liked: 412
I too default to amazon whenever the price is close, however, when the price is not close and there is no evidence of higher quality; then at that point you're just supporting higher profit margins and in effect not helping other consumers control the market.
I think of it like going one more block to get gas .01 cents a gallon cheaper. I know its not going to make a real difference in my families operating budget, but at least I am being a responsible capitalist. Its that mentality got me a 75JU7500 for under $3000.
dmercer3 is offline
post #1316 of 12449 Old 05-08-2015, 04:43 AM
wicklow's Avatar
Quoted: 327 Post(s)
Liked: 277
When I ordered my display the sales guy tried to get me to buy an $1,800 hdmi cable lol. People will try anything if they think you will bite.
wicklow is offline
post #1317 of 12449 Old 05-08-2015, 04:52 AM
AVmanic's Avatar
Quoted: 471 Post(s)
Liked: 532
Wow an $1,800 HDMI cable. I think I would have laughed in his or her face. Then ask if they have been drug tested as of late.
AVmanic is offline
post #1318 of 12449 Old 05-08-2015, 05:52 AM
westa6969's Avatar
Quoted: 398 Post(s)
Liked: 418
What I find truly shocking is that you would give your Business to ANYONE that would even suggest a thing after they were garnering an enormous profit from a $23K TV he was looking to put his hands in your wallet for an obscene amount MORE. For God's sake you can buy a dedicated PTP T1 Line for less than that versus a $10 cable? Insane!
Having been a Professional Purchasing Manager spending Millions during my Career on Technology/Communications and other goods/services that Vendor would have been immediately cancelled and black listed as a Vendor PERIOD and privately an F YOU Buddy.
Vendors are a dime a dozen but you never want to deal with someone looking to STEAL from you! This isn't like adding a pair of socks or a tie to an outfit. This is obscene and should never be enabled and pandered to.
Enjoy your TV though but I would never deal with such a Vendor in my work or Home - I was mandated to have at least three competitive bids on everything I purchased and were anything like this attempted they'd be disqualified and blacklisted PERIOD!
davehale likes this.
Samsung 75HU8550w/SEK-3500-UHDVideoPk, 65F8000, 60D8000, 40HU6350, Philips Folio Soundbar
XBoxOne/360, FPS's Borderlands 1/2, EDF 2017/2025, Halo's
westa6969 is offline
post #1319 of 12449 Old 05-08-2015, 06:41 AM
Vinnie S's Avatar
Quoted: 56 Post(s)
Liked: 29
Tell us how you really feel..............
Vinnie S is offline
post #1320 of 12449 Old 05-08-2015, 06:46 AM
wicklow's Avatar
Quoted: 327 Post(s)
Liked: 277
Yes, I found it amusing to say the least. He knows not try that again but I honestly can't blame him for giving it a shot in the first place as we had not interacted until I placed my order over the phone which was when he suggested it. Pretty funny though when I asked him how much the carbon whatever cable was and he told me.
http://www.bestbuy.com/site/audioque...&skuId=9892876
wicklow is offline
Reply LCD Flat Panel Displays
js9000 , js9500 , suhd
