How bad did I break my vizio E551D-A0 - AVS | Home Theater Discussions And Reviews
post #1 of 11 Old 04-08-2015, 04:59 PM - Thread Starter
mopar4u's Avatar
Tv is about 1.5 years old. Used very little, maybe 50 hours on it. Was watching it the other day and I saw what looked like dead pixels. After a little time I realized it was debris between the panel and light. My ocd wasn't gonna let that fly. I took the tv apart to clean, sure enough there was contamination that I cleaned out. I didn't pull the panel out or unhook any cables, just tilted the panel back and cleaned. Put it back together and had sound with a lot of pretty colored vertical lines, no picture. I stepped away for 24 hours and dug back into this. I messed with the cables and shifted the panel and now I have a picture with sound. Problem is left half of tv is noticeably darker than right side and on the extreme left side any moving objects leave a blur or slow motion like affect. I tried messing with all the tabs to see if the screen would change, didn't help. Tried messing with the tconn ribbons, didn't help.
Did I mess up my panel or maybe the tconn board??
mopar4u is online now
post #2 of 11 Old 04-09-2015, 03:44 PM - Thread Starter
mopar4u's Avatar
Anyone have thoughts on this?
post #3 of 11 Old 04-09-2015, 04:50 PM
Liked: 0
Could you upload a photo of the screen?
BleedRed is offline
post #4 of 11 Old 04-09-2015, 05:12 PM - Thread Starter
mopar4u's Avatar
Blurry and dark on left
post #5 of 11 Old 04-09-2015, 05:13 PM - Thread Starter
mopar4u's Avatar
Turned my tv off, then on now it's back to the colored vertical lines. I didn't touch anything!
post #6 of 11 Old 04-09-2015, 05:16 PM - Thread Starter
mopar4u's Avatar
Sorry for the tractors but it's all I could find with constant motion. Any idea what's going on?
post #7 of 11 Old 04-09-2015, 05:41 PM
Liked: 0
Hmm. That's weird. When you first mentioned one half of the screen being dark I assumed something with the back light was affected. It's obviously not an issue with the panel if it's coming and going (at least not likely). A component issue of some kind. A vague answer I know but that blur effect on only one section of the panel is just strange to me. I would say it wouldn't be a terrible idea to contact the manufacturer and have them diagnose the issue. I wouldn't mention you opened it up, obviously.
BleedRed is offline
post #8 of 11 Old 04-09-2015, 07:30 PM - Thread Starter
mopar4u's Avatar
When you say component do you mean something like the tconn board?
post #9 of 11 Old 04-10-2015, 04:54 AM - Thread Starter
mopar4u's Avatar
Mfgr will tell me to have a service tech look at it
post #10 of 11 Old Yesterday, 03:37 PM - Thread Starter
mopar4u's Avatar
Any other opinions?
post #11 of 11 Old Today, 07:04 PM - Thread Starter
mopar4u's Avatar
Reply LCD Flat Panel Displays
