**OFFICIAL** 2015 Samsung 4K SUHD JS8500 Series TV Thread - Page 723 - AVS Forum | Home Theater Discussions And Reviews
 8919Likes
Old 01-08-2017, 02:32 AM
ThePrisoner's Avatar
Quoted: 283 Post(s)
Liked: 195
How many of you owners use Movie mode for both SDR and HDR? At one point I used Movie mode, which was professionally calibrated to Rec.709 for 1080p. I would adjust some settings to accommodate 4k HDR. I than started to use Standard mode (all energy efficiency turned off) for all 4K UHD viewing with custom settings, Dynamic Contrast (Medium) and Gamma at (+2), all other settings are set to what Movie mode has. That way I did not have to keep going into the menu and making adjustments on what content I was viewing. My question is, is Standard mode ok to use as long as all energy efficient settings are turned off and pretty much all other settings are set correctly (color temp, picture controls)?
EDIT: Found an old post that says Standard mode will work fine with HDR.
TravisBean likes this.
ThePrisoner is offline
Old 01-08-2017, 06:42 AM
Quoted: 96 Post(s)
Liked: 7
Is there a way to confirm that the television is using HDR when playing a UHD Blu-ray or streaming from Amazon? Apologies if this has been covered earlier in the thread.
Jumpem is offline
Old 01-08-2017, 07:20 AM
poppagene's Avatar
Quoted: 653 Post(s)
Liked: 461
Among other things, backlight and contrast will switch to 100 and 20.
When you pause Amazon it should say UHD HDR towards the lower left of the screen near the timeline (or HD HDR if your internet connection isn't fast enough).
King Richard likes this.
UN48JS8500 UN55HU6950 w/SEK-3500U UN40HU6950 w/SEK-3500U UBD-K8500 UN37C5000
poppagene is offline
Old 01-08-2017, 08:41 AM
Quoted: 96 Post(s)
Liked: 7
Thanks. Amazon does show both HDR and Ultra HD.
Jumpem is offline
Old 01-08-2017, 09:21 AM
Quoted: 105 Post(s)
Liked: 54
Well, since it doesn't look like Samsung is going to offer an across the board series upgraded mini for our tv, do you think folks would take advantage of sending their box in to have it upgraded on a case by case basis if Samsung offered that service?
trailryder42 is offline
Old 01-08-2017, 12:36 PM
hail2030's Avatar
Originally Posted by desistyle3 View Post
Hi all - I'm posting in this thread because I have an issue that's plagued my JS8500 (flickering blue/red lines in game mode) and I'm uncertain as to the cause, as I now have been through multiple panels AND now I see the issue also appears to affect MANY Samsung models. Any folks out there that can chime in on the thread and add their perspective..that would be much appreciated!!!
Flickering line issue - problem with multiple Samsung TV's
I have that line issue in Game Mode as well. It doesn't always happen to me though. Also, it tends to occur when the image in the game is black, so I don't notice in some games.
desistyle3 and Jin66 like this.
hail2030 is offline
Old 01-09-2017, 05:17 AM
Quoted: 283 Post(s)
Liked: 195
I should be receiving my Oppo UDP-203 today. Looking forward to it paired with my JS8500!
Old 01-09-2017, 06:59 AM
swanlee's Avatar
Quoted: 409 Post(s)
Liked: 216
I thought the whole purpose of the mini connect break out box was so we could upgrade ports on our TV's without getting a new TV?
swanlee is offline
Old 01-09-2017, 07:11 AM
bp787's Avatar
Quoted: 723 Post(s)
Liked: 527
in theory, yes. It's also a way to remote the connections for some installations.
Sony xbr65x850c Side Blooming test clips:
https://dl.dropboxusercontent.com/u/...br65x850c.xlsx
bp787 is offline
Old 01-09-2017, 07:25 AM
swanlee's Avatar
Quoted: 409 Post(s)
Liked: 216
Well if Samsung isn't going to update our mini connect why'd they even bother with it?
thos19 and JaytheDreamer like this.
swanlee is offline
Old 01-09-2017, 08:23 AM
bp787's Avatar
Quoted: 723 Post(s)
Liked: 527
The second part of my comment: " It's also a way to remote the connections for some installations."
bp787 is offline
Old 01-09-2017, 09:11 AM
poppagene's Avatar
Quoted: 653 Post(s)
Liked: 461
The idea of the mini connect is to be able to update just the ports that connect a/v to the TV. There isn't any current need to replace the current set of ports.
Old 01-09-2017, 09:33 AM
weedeater's Avatar
With the new HDMI 2.1 spec just announced, this may change. But I doubt that Samsung will make this available.
IronWaffle and King Richard like this.
weedeater is offline
Old 01-09-2017, 09:40 AM
raidflex's Avatar
Quoted: 67 Post(s)
Liked: 33
The whole idea of the separate box in general didn't make much sense for just port upgrades. Usually by the time a new HDMI standard is actually out most people are replacing the TV. HDMI 1.4 was out for 4-5 years before 2.0 came along. The only time it would make sense is with the upgrade to a newer CPU/OS, but even then the upgrade would have to be cheap enough, since you could just buy a $60 Chromcast 4K.
Samsung JS8500 65in
Pioneer VSX-53
Mains: Ascend Acoustics CMT-340 SE
Center: Ascend Acoustics CMT-340 SE
Surrounds: Ascend Acoustics HTM-200 SE
Sub: HSU VTF-3 MK5 HP
raidflex is offline
Old 01-09-2017, 12:50 PM
Quoted: 20 Post(s)
Liked: 2
Netflix suddenly changed UI when pausing etc. Checked my version, but still no update to the app.. Weird?
Simon1994 is offline
Old 01-10-2017, 09:16 AM
dlbsyst's Avatar
Quoted: 153 Post(s)
Liked: 119
Gentlemen, there is a new firmware just posted to the U.S. site. The firmware version is 1467. I will be installing it shortly.
dlbsyst is offline
Old 01-10-2017, 10:41 AM
Quoted: 12 Post(s)
Liked: 3
Any patch notes or anything? I'm looking on the site now, and I see the firmware, but there are no notes or anything posted.
Robert Byrne is offline
Old 01-10-2017, 10:50 AM
tibimakai's Avatar
Quoted: 85 Post(s)
Liked: 34
If I click on the little question mark, our model # does not show up and they mention about the changes.
"- Model : JU650, JR6500, JU670, JU6700, JU6800, JU6900, JU7000, JU710, JU7100, JU750, JU7500, JU7700
- Version : 1467.0
- Improved usability 1. Improved browser performance 2. Improved app performance 3. Improved stability 4. Improved usability of input devices"
tibimakai is offline
Old 01-10-2017, 10:54 AM
dlbsyst's Avatar
Quoted: 153 Post(s)
Liked: 119
Unfortunately, Samsung never really says what is included in the firmware updates. They always say the same thing. "Improved usability 1. Improved browser performance 2. Improved app performance 3. Improved stability 4. Improved usability of input devices"
dlbsyst is offline
Old 01-10-2017, 11:12 AM
poppagene's Avatar
Quoted: 653 Post(s)
Liked: 461
1467 Netflix HDR
Old 01-10-2017, 11:24 AM
JaytheDreamer's Avatar
Quoted: 230 Post(s)
Liked: 234
1467 Netflix HDR
Could you please confirm it?
______________
Thanks, Jay
Spoiler!
JaytheDreamer is offline
Old 01-10-2017, 11:27 AM
dlbsyst's Avatar
Quoted: 153 Post(s)
Liked: 119
1467 Netflix HDR
Looks like poppagene beat me to the news. This is the big one guys. We now have HDR on Netflix. I just confirmed.
dlbsyst is offline
Old 01-10-2017, 11:29 AM
Quoted: 230 Post(s)
Liked: 234
Whoa! Cool cool. Kudos to Samsung for keeping the word.
dlbsyst or poppagene, could list couple of shows in HDR? Would like to test as soon as I get home.
fmedrano1977 and King Richard like this.
______________
Thanks, Jay
Spoiler!
poppagene's Avatar
Quoted: 653 Post(s)
Liked: 461
I played Jessica Jones and the HDR badge was displayed as well as the backlight and contrast going to 100 and 20
Old 01-10-2017, 11:30 AM
Quoted: 31 Post(s)
Wow!! A lot of the nonbelievers are going to be eating some crow!
Sent from my SM-G935P using Tapatalk
dlbsyst, bp787, denpom and 2 others like this.
thegoldenone is offline
Old 01-10-2017, 11:32 AM
poppagene's Avatar
Quoted: 653 Post(s)
Liked: 461
Luke Cage, Daredevil, Jessica Jones, Marco Polo for starters
JaytheDreamer likes this.
Old 01-10-2017, 11:33 AM
Quoted: 230 Post(s)
Liked: 234
My Oppo 203 just got delivered today (got UPS update). With that and now Netflix HDR, this is going to be an HDR week/weekend for me
dlbsyst, jfwilliams1 and mc_avs like this.
______________
Thanks, Jay
Spoiler!
Old 01-10-2017, 11:53 AM
Quoted: 20 Post(s)
Liked: 2
Cant wait for the update in Denmark ! Currently sitting on 1480
Old 01-10-2017, 11:56 AM
raidflex's Avatar
Quoted: 67 Post(s)
Liked: 33
Nice, I am guessing the YouTube app still does not do HDR? Hardware limitation if I remember correctly?
Samsung JS8500 65in
Pioneer VSX-53
raidflex is offline
Old 01-10-2017, 11:57 AM
tibimakai's Avatar
Quoted: 85 Post(s)
Liked: 34
Now a Tizen 2.0 update and we are set.
JS8500 , reflection , screen flashing black
