**OFFICIAL** 2015 Samsung 4K SUHD JS8500 Series TV Thread - Page 759 - AVS Forum | Home Theater Discussions And Reviews
 9116Likes
post #22741 of 22806 Old 09-19-2017, 10:30 AM
fjerina's Avatar
Quoted: 278 Post(s)
Liked: 69
I will be getting the new 4K Apple TV this Friday. I am excited in getting this new product and play 4K content through it. I understand that the new Apple TV will...
"When you first connect your Apple TV 4K to a 4K television capable of HDR10 or Dolby Vision, you may be prompted to run a short display test for these formats. Follow the onscreen instructions to run the test, and confirm that you have a clear picture. If Apple TV 4K is unable to confirm that your television can display Dolby Vision or HDR10, it will automatically revert back to the mode it was previously using."
I believe the Samsung support HDR10 (not Dolby Vision), correct? Also, is there a particular setting I should make on my Samsung JS8500 so that the HDR is activated on my TV?
I have been playing 4K content on my TV via the built-in apps on my TV (i.e. Netflix, Amazon). Looks great. But now (along with my 4K BluRay player) I will be submitting a 4K source to my TV externally.
Any advice?
fjerina is offline
post #22742 of 22806 Old 09-19-2017, 11:41 AM
JaytheDreamer's Avatar
Quoted: 237 Post(s)
Liked: 241
Any advice?
Make sure the "HDMI UHD Color" is ON on the HDMI port # you are connecting any device which is 4K HDR. When you play an HDR clip or show,check the back light and contrast (if it is HDR they will shoot to maximum automatically by TV and that is the only way to tell HDR is enabled).
This set is HDR10 and really good for what it is.
______________
Thanks, Jay
Spoiler!
JaytheDreamer is offline
post #22743 of 22806 Old 09-19-2017, 11:42 AM
Quoted: 237 Post(s)
Liked: 241
Originally Posted by esrever View Post
Would there be any downside to leaving the UHD Color enabled all the time even when not using a 4K/HDR source, like DirecTV for example? Would this possibly produce color banding or anything of the sort?
Mine is set to on all the time for the ARC port and the ARC port is I use mainly for AVR/Cable/Oppo etc. I don't have a problem regardless of what I am playing (a 4K HDR disc or just plain cable).
______________
Thanks, Jay
Spoiler!
post #22744 of 22806 Old 09-20-2017, 12:27 PM
Quoted: 237 Post(s)
Liked: 241
Favorite apps on Smarthub startup
Is there a way to delete Favorite Apps shortcut from smarthub startup list (I know there is a pin and a delete button, but even after I delete an app or HDMI port shortcut, it re-appears). I need Amazon first (done with pin, stays there) and Netflix second (that fails because other apps and HDMI ports shortcuts comes in between as we watch various sources).
I almost created a Harmony/Google Home/Smartthings event and this random order is killing it.
______________
Thanks, Jay
Spoiler!
post #22745 of 22806 Old 09-21-2017, 08:26 AM
TravisBean's Avatar
Quoted: 174 Post(s)
Liked: 213
And what it is, is the last of the top tier sets that provides support for both HDR and active 3d (unless you want to spend $5k on the Sony Z9 model).
Guard it with your life.
TravisBean is offline
post #22746 of 22806 Old 09-21-2017, 08:30 AM
TravisBean's Avatar
Quoted: 174 Post(s)
Liked: 213
Please report back on the results of that test.
Should be very interesting.
(thanks in advance)
thos19 likes this.
post #22747 of 22806 Old 09-21-2017, 08:44 AM
fjerina's Avatar
Quoted: 278 Post(s)
Liked: 69
(thanks in advance)
Will do. I will get to check it out to tomorrow when I get my unit delivered.
fjerina is offline
post #22748 of 22806 Old 09-21-2017, 08:47 AM
dojoman's Avatar
Quoted: 313 Post(s)
Liked: 91
Wait what is the point of running the test? For JS8500 set right? Just to confirm Apple TV recognizes this set as HDR capable? We all know it does but..
dojoman is offline
post #22749 of 22806 Old 09-22-2017, 09:42 AM
Liked: 0
New to the forum, though have been following for awhile. A few things that I'm a little unclear on still, and also in need of some advice.
1. I downloaded the Korean version of the firmware update last night, but wanted to double check as I've only seen one person chime back in as to whether it is a universal update and wont all of a sudden force me to start using a translator for menus, etc.
2. I too am waiting for my Apple TV 4k to arrive, though in the meantime, I've been using my Roku Premiere. Picture has been great on that, though Netflix will not stream in 4K through the Roku, only when I use the native Samsung SmartHub app. My internet speed is 100mpbs, so there shouldn't be any issue, but the Roku will only register around 21-22mbps and based on what I'm reading you need at least 25mpbs to stream in 4k. Hoping the Apple TV 4k does not have this problem. Please let me know if anyone has a workaround.
3. I switched the HDMI UHD Color setting to 'on' for the HDMI port that's connected to my Roku to see if it would do anything for Netflix/Amazon Prime. I didn't see any difference on the menu items, though when I played a show through Amazon Prime, the color was all screwed up - greens and oranges and very pixelated. Not sure why this happened. It went away when I reset the HDMI UDH Color setting to 'off'. Any ideas? Did I do something wrong?
Appreciate any input/thoughts and happy to join the threat.
theyonan is offline
post #22750 of 22806 Old 09-22-2017, 10:38 AM
dojoman's Avatar
Quoted: 313 Post(s)
Liked: 91
Originally Posted by theyonan View Post
2. I too am waiting for my Apple TV 4k to arrive, though in the meantime, I've been using my Roku Premiere. Picture has been great on that, though Netflix will not stream in 4K through the Roku, only when I use the native Samsung SmartHub app. My internet speed is 100mpbs, so there shouldn't be any issue, but the Roku will only register around 21-22mbps and based on what I'm reading you need at least 25mpbs to stream in 4k. Hoping the Apple TV 4k does not have this problem. Please let me know if anyone has a workaround.!
You don't need 20+ mbps for Netflix 4K to work. My speed is around 14-16 mbps and I can get Netflix HDR 4K without any issues, I also have Roku Premiere+. You do need to turn on UHD Color for HDMI on your TV.
You mentioned Roku Premiere it looks like that box cannot do HDR only Premiere+ does.
dojoman is offline
post #22751 of 22806 Old 09-22-2017, 10:49 AM
Liked: 0
Apologies, I misspoke. I have a Roku Ultra. So I agree, it should work. Doesn't explain the weird coloring when I attempted to turn on UHD Color when watching Amazon video tho. Strange stuff.
theyonan is offline
post #22752 of 22806 Old 09-23-2017, 11:11 AM
bp787's Avatar
Quoted: 757 Post(s)
Liked: 545
1. why do you "need" the korean update? as pointed out multiple times in this thread, it's not intended for other countries sets. It MIGHT work and it MIGHT be fine. Or not.
JaytheDreamer likes this.
Sony xbr65x850c Side Blooming test clips:
https://dl.dropboxusercontent.com/u/...br65x850c.xlsx
bp787 is offline
post #22753 of 22806 Old 09-23-2017, 11:11 AM
tibimakai's Avatar
Quoted: 99 Post(s)
Liked: 41
Anybody found a good use for the camera, that was for Skype?
tibimakai is offline
post #22754 of 22806 Old 09-23-2017, 02:02 PM
MiamiC70's Avatar
Quoted: 26 Post(s)
Just got the new Apple TV 4K but cand seem to run chroma at 4:2:2 only 4:2:0. Samsung TV goes black and then Apple TV 4K resets to 4:2:0 when I try.
MiamiC70 is offline
post #22755 of 22806 Old 09-23-2017, 04:45 PM
Quoted: 237 Post(s)
Liked: 241
Without HDMI UHD Color ON you can't get 4K-HDR. Not sure why your colors are off but like bp787 mentioned I am not sure why would you update a FW which is not intended for your region. FW for these TVs usually includes so many settings for apps based on regions too. This thread advised against it many times.
______________
Thanks, Jay
Spoiler!
post #22756 of 22806 Old 09-23-2017, 07:18 PM
poppagene's Avatar
Quoted: 705 Post(s)
Liked: 522
Don't listen to these posters who aren't knowledgeable about the Korean or Canadian firmware and this tv. This TV will not let you update the firmware with a file that wasn't meant for it.
I'm not sure why you would use anything other that the smarthub apps for Amazon Prime and Netflix UHD HDR.
TravisBean likes this.
UN48JS8500 UN55HU6950 w/SEK-3500U UN40HU6950 w/SEK-3500U UBD-K8500 UN37C5000
poppagene is online now
post #22757 of 22806 Old 09-24-2017, 03:43 PM
Liked: 0
Hmm interesting. I'm able to run either chroma, but if I pick 4:2:2 i can see visible banding on the icons on the home screen, as if it's set to a lower color depth so it looks "dithered", if you know what I mean. I don't notice that when watching a Netflix (HDR) video though. But I haven't done enough comparisons to see if it's improved for that.
Maybe try another HDMI 2.0 cable and see if you're able to get video in both modes?
webowires is offline
post #22758 of 22806 Old 09-25-2017, 07:01 AM
bp787's Avatar
Quoted: 757 Post(s)
Liked: 545
oh wise poppagene, i'm glad you know so much about software. For a living, I write and deploy software to different regions and to different systems.
We have firmware and applications that appear similar, but are, in fact, different. A system allowing an update doesn't mean it's the correct update for it. It only means that it passed some type of basic validation.
As stated previously, you just DO NOT KNOW what is in a firmware package destined for a different country. Why is there this need to risk your set just because there's some update for another country, especially when you don't really know what's actually IN these updates? not like samsung ever really states what it does.
Just because it works for one person, doesn't mean you should tell every person who visits here to do it.
pilotart and JaytheDreamer like this.
bp787 is offline
post #22759 of 22806 Old 09-25-2017, 02:18 PM
poppagene's Avatar
Quoted: 705 Post(s)
Liked: 522
Is that what I posted?
post #22760 of 22806 Old 09-26-2017, 10:49 AM
MALICIOUS ONE's Avatar
Quoted: 20 Post(s)
Liked: 26
I use my Samsung UBD-K8500 Blu-Ray player because it can do Dolby Digital Plus 5.1. It has a higher bit rate than the Dolby Digital 5.1 that the TV smarthub only outputs.
poppagene and TravisBean like this.
Samsung UN65JS8500/Samsung UBD-K8500/Onkyo TX-SR608 using 7.1/Xbox One S w/Kinect
XBL Gamertag: MALICIOUS ONE
My Twitter
My Rock Band/Guitar Hero DLC
MALICIOUS ONE is offline
post #22761 of 22806 Old 09-27-2017, 04:19 PM
sfumat0's Avatar
Quoted: 47 Post(s)
Liked: 26
Need some advice. Ive had my TV almost 3 years now. Had some pink bars start to show on top and bottom. Luckily I bought the replacement plan from BestBuy. I called the tech, he asked to see pics , it took him 5 seconds to decide over the phone that the panel is bad.
Here is my issue, they dont make the TV anymore so they are going to do an exchange based on SPECS. ie.. a better or equal tv in all regards.
Now if you were I how would you do that, what new model would be equal to this tv? Will I be able to really pin them down on specs? Am I going to get shafted?
Anyone with Bestbuy replacement experience? It was a no brainer with one of my xbox's, but this is different.
thank you
sfumat0 is offline
post #22762 of 22806 Old 09-27-2017, 04:54 PM
Rudy1's Avatar
Quoted: 1433 Post(s)
Liked: 2118
thank you
Since you're having to give up a feature (3D), I would suggest that the Samsung Q7F would be the ideal replacement. The lower series do not have Quantum Dots, so they wouldn't equal the basic specs of the JS8500. Check out the specs of the Q7F via the link below:
https://www.samsung.com/us/televisio...qn65q7famfxza/
MALICIOUS ONE likes this.
"I am not IN the business...I AM the business."
Rudy1 is online now
post #22763 of 22806 Old 09-27-2017, 05:49 PM
sfumat0's Avatar
Quoted: 47 Post(s)
Liked: 26
Thanks for the reply. I dont ever use 3d so thats not an issue for me, but as you pointed out a great "bargaining" point.
Im all about picture quality, movies and games. I just dont know how to do this, so many different words and specs. This was one of the best tvs out there, how do I decide? quad 4 processor? quantum dot? what are the most important ones?
sfumat0 is offline
post #22764 of 22806 Old 09-27-2017, 07:35 PM
Rudy1's Avatar
Liked: 2118
The specs on the Q7 are an improvement over those of the JS8500...but regardless of what they offer you, don't settle for anything less than a TV with Quantum Dot technology. It is essential for wide color gamut support and, along with the brighter screen of the 2017 models, will give improved HDR performance. I recommend that you print out the spec sheet for the old TV and for your desired replacement unit. Use that to bolster your case if they offer you an MU SERIES TV, as they do not use QD screens.
MALICIOUS ONE and sfumat0 like this.
Rudy1 is online now
post #22765 of 22806 Old 09-27-2017, 08:10 PM
sfumat0's Avatar
Quoted: 47 Post(s)
Liked: 26
Quick question, when the new models came out, what did people consider the "replacement" for our TV for 2016 and then 2017...or has everything changed so much it isnt relevant?
I love this TV, Im pretty bummed and I know Im going to be paranoid that Im not getting as good a TV. This TV was my replacement for my Plasma Samsung 8500 which I also hated parting with.
sfumat0 is offline
post #22766 of 22806 Old 09-28-2017, 12:50 AM
fmedrano1977's Avatar
Quoted: 354 Post(s)
Liked: 106
I purchased mine through Conn's, they replaced my panel around 3 or 4 months ago.
Sent from my HTC 10 using Tapatalk
fmedrano1977 is offline
post #22767 of 22806 Old 09-28-2017, 06:22 AM
Rudy1's Avatar
Liked: 2118
I believe in 2016 it was the KS8000, and this year probably the Q7F. But you're right...things have changed significantly in the last two years.
Rudy1 is online now
post #22768 of 22806 Old 09-28-2017, 06:29 AM
sfumat0's Avatar
Quoted: 47 Post(s)
Liked: 26
Thanks Rudy, as I sat there last night I started to think about how quickly he said he would replace it based on these pictures, less than a second, he almost said it was going to be a "replacement" before he looked at them.
Do they resell these units on a different market? This TV is pristine. The area of interest is the bottom 10 inch bar of pink and top bar of pink....and the white has looked kind of "dirty" for awhile around the edges.
Here are the pics.
ID:	2289324   Click image for larger version
sfumat0 is offline
post #22769 of 22806 Old 09-28-2017, 06:32 AM
sfumat0's Avatar
Quoted: 47 Post(s)
Liked: 26
I guess they have run out of them or Best Buy doesnt want to mess with it.....or they just want my TV lol. See pics in previous post.
sfumat0 is offline
post #22770 of 22806 Old 09-28-2017, 06:51 AM
Quoted: 354 Post(s)
Liked: 106
Yeah that looks terrible, mine was developing pinkish smudges, the tech saw them and said yup you need a new panel. I don't think anyone carries them anymore although I have seen them refurbished on Groupon from time to time.
Reply LCD Flat Panel Displays
JS8500 , reflection , screen flashing black
