service-secret menu - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Otto Pylot
post #1 of 3 Old 07-24-2015, 03:05 PM - Thread Starter
Liked: 0
Unhappy service-secret menu
Hello
I did mixup in service menu and i need your help. The samsung center don´t help me with this.
Can you please take a picture of the values in your service menu, mainly the white calibration values.
The TV model is samsung le37m87bd.
I really appreciate if someone can help me.
Thank you
Pedro Ferreira is offline
post #2 of 3 Old 07-24-2015, 05:07 PM
sumguy91's Avatar
Quoted: 96 Post(s)
Liked: 34
Perhaps downloading the service manual will help?
http://www.nodevice.com/manual/newma.../get70791.html
By the way, it looks like in order to receive the service manual, you'll need to pay for it. You can do a google search to see if there is a free copy elsewhere?
I can't be certain this will solve your issue, but it can't hurt to try?
sumguy91 is offline
post #3 of 3 Old 07-24-2015, 05:30 PM
Otto Pylot's Avatar
Quoted: 1667 Post(s)
Liked: 1042
Samsung, or any tv mfr for that matter will not help you if you entered the SM because in most cases, that will void your warranty because the "damage" was caused by you and thus not a failure of the tv. The SM is not meant for the user to access.
The values found in the SM are quite often model and build specific so even if you find a tv of the exact same model, region, and build the SM values may not be exactly the same because the firmware versions may be different. Using values and instructions that you find online is a very dangerous thing to do for the reasons I just gave. Entering the SM is one of the quickest ways to brick a tv.
A service manual may help but again, the values are not always universal. Good luck.
steve1971 likes this.
Otto Pylot is online now
Reply LCD Flat Panel Displays
