Official 2016 Sony X930D Owners Thread (no price talk) - AVS Forum | Home Theater Discussions And Reviews
 2384Likes
post #1 of 7202 Old 03-10-2016, 02:51 PM - Thread Starter
Viper32's Avatar
Quoted: 1266 Post(s)
Liked: 945
**Official** 2016 Sony X930D / X940D Owners Thread
Sony Product Information Page HERE
Sony Product Manulas HERE
Product Reviews
Rtings CLICK HERE
WHAT HI*FI CLICK HERE
FORBES CLICK HERE
Pictures:
Picture Quality
The 930D looked pretty good out of the box but to get a true and accurate look you will need to make some picture changes. Settings Posted in Post #2 here. Native 4K looks great and the sets upscaling and motion controls is second to none as all Sony's seem to be. HDR looks amazing on this set. Black levels trump any other edge lit set I have encountered including Samsungs JS8500 and JS9000.
Pros
Android OS capabilities and Apps
Cutting Edge picture quality
Motion Control is excellent
Color accuracy and Black Levels are as close to perfect as possible with LCD units
Cons
Expensive
Black Levels not on par with Fald Sets or OLED
Some Ghosting/Clouding and a little banding also artifacts from time to time
Backlight Uniformity
Viewing Angle (Make sure you do not have a bad angle or you will be sorry)
Conclusion
Overall, the Sony XBR930D is an exciting model for 2016 with Sony's New Grid Array Backlight System, but for 1500.00 cheaper and the great speakers you may want to go with the 930C since I did not see that many improvements from the previous years set. However I will say that this set outperformed the JS9000 and any other Samsung I have owned or viewed (JS9500 not included). I think this television would work well for most viewers but remember at the end of the day it is not Fald and will still have some of the issues that plaque Edge lit type units.
Ongoing Issues from some Owners
The 65X930D has issues with the frame of the TV being bent and deformed. If your unit exhibits this flaw please let Sony know on their Community forum.
https://www.community.sony.com/t5/4K...564326#U564326
The 65X930D has crippling issues with heavy crosstalk when watching 3D regardless of using Sony's own glasses (TDG-BT500A) or content source. If you have tested your unit and it exhibits this flaw please let Sony know on their Community forum.
https://www.community.sony.com/t5/4K...565811#U565811
Current Sets: Sony XBR75X940C, Sony XBR75X940D, Samsung UN65KS9800, UN55KS8500, UN49JS8500, TCL P-Series (55P607)
Previous Sets: Sony XBR65X930D, XBR65X900B, XBR49X830C, Samsung KS8000, KU6500, JS9000, JU7090, JU6500, JU6400, HU9000, HU7250, PN64F8500, Vizio P65, LG 65EF9500, LG 55EC9300, Hisense 55H8C
Viper32 is offline
post #2 of 7202 Old 03-10-2016, 02:51 PM - Thread Starter
Viper32's Avatar
Liked: 945
Originally Posted by 10k View Post
Calibration update and suggested settings (4/4/16)
This TV does something different with a 1080p60 rgb444 signal than it does with a 2160p60 rgb444 signal.
As it turns out, 1080p60 rgb444 gives almost perfect color accuracy with very little adjustment.
2160p60 rgb444 on the other hand is much more difficult to calibrate, and I am still unable to get pretty looking charts without use of 3dlut. 2160p ycc gives results similar to the 1080p measurements, but using ycc output from an htpc can introduce banding.
As far as I can tell, for 4k sources it is probably best to make sure your device is outputting in Ycc mode and not RGB
Calibrated Settings for HD and bluray (rec709 color space)
Spoiler!
uhd 4K HDR settings
There are no reliable standards/targets to calibrate towards. Using Amazon HDR as a reference, the overall best result I have gotten is to use the settings above for the "HDR" picture mode with the following changes:
Brightness - as high as you can handle
Local dimming - medium
Xdr - medium (grayed out)
Color space - auto or bt2020
Live color - off (or high, seems to depend on the content)
Calibration measurements
This section has a lot of measurements. For anyone unfamiliar with what the numbers and charts mean, this is an excellent result. Especially since I only did a 2pt white balance calibration. Given the results I may go back and do a full 10pt calibration for my own edification, but the difference in picture quality would probably not be observable. The color accuracy results are astounding for a TV with no color controls.
Spoiler!
Relation between brightness and light output & impact of Motionflow:Clear
Spoiler!
Black uniformity -
Gray uniformity / dse test -
Local dimming test -
Viper32 (POP Settings, if you like a more vivid picture)
Picture Adjustments
Picture Mode: Standard
Auto Picture Mode: Off
Brightness: 30
Color: 52
Light Sensor: Off
Advanced Settings
Brightness
Brightness: 30
Contrast: 90
Gamma: -2
Black Level: 47
Black Adjust: Off
Adv. Contrast Enhancer: Off
Auto Local Dimming: Medium
Extended Dynamic Range: Low
Color
Color: 52
Hue: R1
Color Temp: Cool1
Color Space: Auto
Live Color: Low
Advanced Color Temperature
Basic
R-Gain: -6
G-Gain: -5
B-Gain: Max
R-Bias: 0
G-Bias: 0
B-Bias: 0
Multipoint (10P)
Color Gamma Adjustment Points: 1
R-Offset: 4
G-Offset: 3
B-Offset: 4
Clarity
Sharpness: 20
Reality Creation: Off
Mastered in 4K: Off
Random Noise: Off
Digital Noise: Off
Motion
Motionflow: Smooth
Cinemotion: Off
Latest Software Update Refinements:
UPDATE System Software Update Release Date 4/07/2016 Version PKG3.395.1015NAB File Size 1.19 GB HERE
File Description
Sony has designed the BRAVIA® Televisions software update process to be customer friendly. This software update (version PKG3.395.0105NAB) provides the following benefits:
Improvements over version PKG3.307.0101NAB:
Improves the Netflix software quality. (4K HDR model)
Improves general software quality of the TV.
Benefits provided by previous updates and included in version PKG3.395.0105NAB:
Improves RVU support
Adds Twin Picture (PAP function) support
Resolves a condition where a black picture may occur after performing a remote Off/On (KDL-75W850C)
Improves general performance of the TV
Supports PlayMemories Online service
Supports PlayStation™ Now service
Improves Wi-Fi connectivity of the TV
Improves picture quality (dynamic range, noise reduction, sharpness)
Supports Netflix® streaming service (4K Models)
Improves Lip Sync for HDMI input
Improves performance and stability of the USB video playback features
Resolves a condition where a black screen and no sound may occur when an input changes from YouTube® to another input
Resolves a condition where a black screen may occur during USB video playback
Supports Internet based EPG (Electronic program guide)
Supports Netflix streaming service (2K Models)
Supports Amazon®, Pandora®, and Crackle™ applications
Supports Force Reboot by holding down the Power key on the BT or IR remote controller
Improves performance and stability of overall UI operation
Improves performance and stability of the Action Menu
Last edited by Viper32; 04-09-2016 at 03:06 AM. Reason: It is here at home now, will start setting up shortly and post thoughts.
Viper32 is offline
post #3 of 7202 Old 03-10-2016, 05:34 PM
alexanderg823's Avatar
Quoted: 2410 Post(s)
Liked: 1929
Alright alright alright
We're going to need blooming impressions such as on a credit screen or anything with darks and whites, such as nighttime shots over a city. And if you could get a zone count. Hook up pc if you can and just move a mouse cursor over a full screen black image.
For this test best to turn xtended dynamic range up high with local dimming on high as this will simulate hdr blooming.
The thing most people are waiting on is how the Slim Backlight Drive works in practice and if the blocky grid blooming still exists. Don't be afraid to crank the backlight up to test this out.
WOLVERNOLE and jasyn like this.
alexanderg823 is online now
post #4 of 7202 Old 03-10-2016, 05:35 PM
adam355's Avatar
Quoted: 156 Post(s)
Liked: 118
Originally Posted by Viper32 View Post
I will post my impressions etc. soon as I get it setup and dialed in.
If you have any questions ask away and I will try my best to answer.
If you could please go to the playstore and download the system info app aida64
https://play.google.com/store/apps/d...nalwire.aida64
I am looking to find out a few things from inside this app...
Please get what it says for the
- system/cpu/soc model,
- Any information on the cores,
- Total Installed Ram
- GPU model
Also any impressions you could give on general performance navigating the OS if possible but the specs would be great!
robert9674 and jasyn like this.
adam355 is offline
post #5 of 7202 Old 03-10-2016, 05:36 PM - Thread Starter
Viper32's Avatar
Liked: 945
Ok will do getting little one situated and then I will setup and try to get as much info as possible.
Viper32 is offline
post #6 of 7202 Old 03-10-2016, 05:43 PM
Quoted: 283 Post(s)
Liked: 97
your sig says 940D =P .. congrats on the purchase
1. all the usual stuff (blooming, blacks, greys, gaming performance, HDR)
2. thoughts on the android OS now. first gen was very buggy & slow.
3. can you still side load apps?
jasyn is offline
post #7 of 7202 Old 03-10-2016, 05:44 PM
xlostnspacex's Avatar
Quoted: 73 Post(s)
Liked: 107
Congrats on your purchase! I look forward to your posts!!!
xlostnspacex is offline
post #8 of 7202 Old 03-10-2016, 05:49 PM
csrini1's Avatar
Quoted: 225 Post(s)
Liked: 78
Did you get it from bestbuy for 5000?
blatz8 likes this.
csrini1 is offline
post #9 of 7202 Old 03-10-2016, 06:33 PM
davehale's Avatar
Location: US, Earth, Milky Way Galaxy, Virgo SuperCluster
Quoted: 376 Post(s)
Liked: 339
What is your zip code as I could call up for a baby sitter and the local CVS for No Doze. Someone else can help out with the Pizza
WOLVERNOLE and blatz8 like this.
Sony 65Z9D (10k Settings) still no DV, OPPO 203 (DV) Source Direct, Denon X4300H (DV), 7.1 setup
TCL P605 (DV), BJC Prem-Cert. 6/9 ft cables, EVGA 1080ti, Star Citizen,
Ethernet everything, AT&T 24Mbps
davehale is online now
post #10 of 7202 Old 03-10-2016, 06:37 PM - Thread Starter
Viper32's Avatar
Liked: 945
Lol, I will say this they packed this thing like I have never seen. They treat must be worried about breakage. I got it on the stand and powered up working on setup now.
Sent from my SM-G900V using Tapatalk
WOLVERNOLE, brickyardz and dr0z77 like this.
Viper32 is offline
post #11 of 7202 Old 03-10-2016, 06:41 PM - Thread Starter
Viper32's Avatar
Liked: 945
Attachment 1306161Attachment 1306169
ID:	1306561   Click image for larger version
aaronwt, iatacs19, Kadath and 4 others like this.
Viper32 is offline
post #12 of 7202 Old 03-10-2016, 06:46 PM
Liked: 1929
Alright time to turn the lights out andere dig into the blacks and dimming tech! Almost there!!!
post #13 of 7202 Old 03-10-2016, 06:48 PM
GeneWildersHair's Avatar
Quoted: 441 Post(s)
Liked: 382
An exciting time to be shopping around for a new tv myself... All these new sets is making this so exciting! Can't wait to hear your thoughts on this set Viper!
GeneWildersHair is offline
post #14 of 7202 Old 03-10-2016, 07:15 PM - Thread Starter
Viper32's Avatar
Liked: 945
OK I am sorry but not allot I can get done tonight. I have not got setup to my liking as of yet but my initial thoughts are below.
Blacks are good but not OLED like
A little blooming in the corners
Colors are great
Motion is as good or better than any thing I have seen
Local Dimming set to high and still see some blooming but I still do not have everything setup like I like and I am sure some things will be better when I finish setting up.
Any suggestions for starting settings let me know, as I want have to put meter on it until late weekend if then.
nu02wrx and xlostnspacex like this.
Viper32 is offline
post #15 of 7202 Old 03-10-2016, 07:18 PM
adam355's Avatar
Quoted: 156 Post(s)
Liked: 118
[iurl="http://www.avsforum.com/forum/attachment.php?attachmentid=1306161&d=1457664059"][/iurl][iurl="http://www.avsforum.com/forum/attachment.php?attachmentid=1306169&d=1457664095"][/iurl]
Thanks for the pics! Enjoy your new set!
adam355 is offline
post #16 of 7202 Old 03-10-2016, 07:21 PM
ray0414's Avatar
Quoted: 10141 Post(s)
Liked: 9086
Colors are great
Local dimming on high for both sony and samsung cranks up highlight brightness and can make blooming worse, so you may want to lower it.
ray0414 is offline
post #17 of 7202 Old 03-10-2016, 07:26 PM
Quoted: 441 Post(s)
Liked: 382
Any light bleed that you can detect?
post #18 of 7202 Old 03-10-2016, 07:35 PM
GARRIGA's Avatar
Quoted: 181 Post(s)
Liked: 78
Finally someone pulls the trigger. Congrats and looking forward to your impressions.
GARRIGA is offline
post #19 of 7202 Old 03-10-2016, 07:35 PM - Thread Starter
Viper32's Avatar
Liked: 945
Yes a little in one corner.
Colors are amazing as always with Sony.
brickyardz and Samckaz like this.
Viper32 is offline
post #20 of 7202 Old 03-10-2016, 07:39 PM
GARRIGA's Avatar
Quoted: 181 Post(s)
Liked: 78
I see from screen shots it's 32 bit but why 2015? Isn't that odd?
dr0z77 and blatz8 like this.
GARRIGA is offline
post #21 of 7202 Old 03-10-2016, 07:41 PM
Quoted: 441 Post(s)
Liked: 382
Yes I've always preferred their colors to everyone else's, (I owned a 950b a short time and loved the triluminous display) . I just sent my ef9500 OLED back to Lg for a refund because the near black issues were a deal breaker for me, and am looking at buying an LED set, because I don't think OLED is ready yet. This 930d is one I'm looking at. May I ask why you got rid of your Js9000? I remember seeing your early impressions and remembering you liked that set?
blatz8 likes this.
post #22 of 7202 Old 03-10-2016, 07:44 PM - Thread Starter
Viper32's Avatar
Liked: 945
No clue just used the app that was posted and it gave information.
Viper32 is offline
post #23 of 7202 Old 03-10-2016, 08:00 PM - Thread Starter
Viper32's Avatar
Liked: 945
I could not get passed the Samsung motion and the colors just was not as good as Sony. That was just a few items, Sony just looks better to me at the end of the day.
WOLVERNOLE likes this.
Viper32 is offline
post #24 of 7202 Old 03-10-2016, 08:14 PM
adam355's Avatar
Quoted: 156 Post(s)
Liked: 118
I have the same specs in my X850D. I also side loaded Antutu and it says the exact same thing as well. I am emailing the app developer of AIDI64 to find out if things are out of date. Its that or Sony shipped these TVs with last years SOC. The new SOC (MT5596) may not have been ready since it was only announced in January.
blatz8 and jasyn like this.
adam355 is offline
post #25 of 7202 Old 03-10-2016, 08:15 PM
twennywonn's Avatar
Quoted: 54 Post(s)
Liked: 36
I have had the TV since Saturday and although I like it coming from a Panasonic ST60 not everything is perfect. For example blooming is very noticeable mostly when changing the channel the white lines that appear on the screen are difficult for the local dimming to get right. I will say I cannot remember seeing any blooming in real content only when putting up a black screen and putting something white on the background.
This is my first LCD and if I turn off auto dimming all together there is some flashlighting in the corners that go away if I change my position in the room. But even if Im dead on in a dark room I can see the corners are brighter. This issue has also been undetected with real content so far. Is this normal?
I have linked 3 pics the one with the cloudy corners is with local dimming turned off in a pitch black room.
http://imgur.com/a/2Oat7
jasyn likes this.
twennywonn is offline
post #26 of 7202 Old 03-10-2016, 08:20 PM
Quoted: 441 Post(s)
Liked: 382
Understood. I had a 75hu8550 that looked good, but I didn't care for it being having poor edge lighting, and it definitely didn't have the pop in colors that Sony gives you. Most of all, it had some lip sync issues that I couldn't defeat no matter what audio delay I added in its sound menu. I still have an old XBR 4 in the bedroom that I still love, and have no issues with after so many years.
VirTERM likes this.
post #27 of 7202 Old 03-10-2016, 08:26 PM
robert9674's Avatar
Quoted: 1071 Post(s)
Liked: 682
wow that is bad. But I'm not surprised. Edge lit TVs are not HDR friendly . Sony knows this but they wan to save money instead of giving us a 65 inch FALD tv.
robert9674 is offline
post #28 of 7202 Old 03-10-2016, 08:30 PM
twennywonn's Avatar
Quoted: 54 Post(s)
Liked: 36
But is it to be expected or should it be more even? I would like the other person that has one to post a black screen with local dimming turned off. I was impressed with how the vegas shot looked the blacks we well done.
post #29 of 7202 Old 03-10-2016, 08:32 PM
Quoted: 441 Post(s)
Liked: 382
It only looks bad in the second picture with LD off... With real content (like the other two pics) it looks great. Why even bring up HDR when that wasn't even part of the discussion?besides a good edge lit set can do HDR just fine.
post #30 of 7202 Old 03-10-2016, 08:34 PM
Quoted: 283 Post(s)
Liked: 97
Black uniformity is bad, but that is expected on an edge-lit, however the photo's you've provided of actual viewing content looks pretty darn good assuming you haven't calibrated your set.
My problem with the X850C when I got it last year was that there were noticeable edge bleed from both left and right side, more so on the left (granted this model is technically 1 up -- but it's still edge-lit).
I'm impressed.
Who stares at a complete black screen and watches credits all day right?
Egan and mdbrown like this.
jasyn is offline
Reply LCD Flat Panel Displays
x930d
