How do I remove a scratch someone put into the rim of a TV? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By olyteddy
post #1 of 6 Old 04-12-2016, 04:39 PM - Thread Starter
Dan55's Avatar
Ok so my friend has a homestay buisness going on at her home, today she noticed one of the people that stayed over carved their name in the TV in the guest room, how can you get this out? It looks very ugly and we are shocked that someone would do this staying as a guest.
Dan55 is offline
post #2 of 6 Old 04-12-2016, 07:29 PM
sytech's Avatar
Quoted: 2104 Post(s)
Liked: 1519
If they are deep, noting will get them out. You could try a liquid rubbing compound for cars. I use a product by Kit called Scratch-Out that works great on light paint scratches. Protect the screen and put some on a cloth and start rubbing in circular motion. If you have a variable low speed buffer you could try that, but be super careful of the screen.
sytech is offline
post #3 of 6 Old 04-12-2016, 07:32 PM
jjackkrash's Avatar
Quoted: 1189 Post(s)
Liked: 1023
If you feel like bold action, tape the screen, sand the bezel, and hit it with Krylon Fusion for plastic, or research some other paint or coating for plastic.
http://www.amazon.com/s/?ie=UTF8&key...l_5y1i0vxs86_b
jjackkrash is offline
post #4 of 6 Old 04-12-2016, 07:34 PM
jjackkrash's Avatar
Liked: 1023
FYI, you can get sandpaper to 10k grit now. Start with 150 or so and work your way on up the ladder.
http://www.amazon.com/SANDING-SHEETS...10000+grit+kit
post #5 of 6 Old 04-12-2016, 08:43 PM
olyteddy's Avatar
Quoted: 536 Post(s)
Liked: 941
Track the visitors down and make them pay. If they won't pay carve your initials in something of theirs, like their forehead...
MerrlinT likes this.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #6 of 6 Old 04-13-2016, 10:25 AM
uniquepattern's Avatar
Quoted: 735 Post(s)
Liked: 735
That sucks, sadly it is very difficult to re-finish plastic...
Best course of action would be to invoice the guest for the replacement cost....
uniquepattern is offline
Reply LCD Flat Panel Displays
