Sammy JS9500 or 2016 Vizio P for gaming and netflix heavy use - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By ray0414
post #1 of 7 Old 04-14-2016, 11:14 AM - Thread Starter
MarkAELSU's Avatar
Quoted: 18 Post(s)
What if any woulD be the difference between the 2? The curved screen kind of has me worried
MarkAELSU is offline
post #2 of 7 Old 04-14-2016, 11:17 AM
Quoted: 1440 Post(s)
Liked: 1159
They're both very even to be honest, and I've extensively used both. Except the Vizio P is a hell of a lot cheaper. I went from JS9500 to Vizio P and haven't regretted it for a second.
alexanderg823 is offline
post #3 of 7 Old 04-14-2016, 12:03 PM
mpgxsvcd's Avatar
Quoted: 2473 Post(s)
Liked: 2221
Question
What did you do with the JS9500? Did you have to sell it?
mpgxsvcd is offline
post #4 of 7 Old 04-14-2016, 12:06 PM
mpgxsvcd's Avatar
Liked: 2221
Ones curved ones flat. Otherwise they have very similar specifications for Games on a console. For computers the Vizio P-series will do 4:4:4 but it will also do 1080p @ 120 FPS which none of the current "J" Series Samsung TVs can do.
mpgxsvcd is offline
post #5 of 7 Old 04-14-2016, 12:27 PM
ray0414's Avatar
Quoted: 9301 Post(s)
Liked: 7741
Returned within return period at 3 weeks. Had opportunity to save $$$
alexanderg823 likes this.
ray0414 is online now
post #6 of 7 Old 04-14-2016, 03:42 PM
GunmetalR56's Avatar
Quoted: 162 Post(s)
Liked: 215
That's a tough call. Samsung is curved with glossy panel... Vizio is flat with semi gloss panel.
Vizio has Dolby Vision and looks like it should have a bit better black level but the Samsung will probably be a little bolder with colors.
The Samsung may also be a bit better up scaling lower res sources.
The Vizio should have less input lag.
Good luck!
GunmetalR56 is online now
post #7 of 7 Old 04-14-2016, 03:48 PM
Eclipse01's Avatar
Quoted: 247 Post(s)
Liked: 105
For me it was between the LG Oled and JS9500, I chose the 9500 mostly due to the One Connect box (which is causing a bit of controversy at the moment). Upgrade or not its still a heck of a feature to have all your devices ran to an external device.
Samsung 65JS9500
Philips BDP7501 UHD Blu Ray player
PS4/WiiU
Apple TV4
Onkyo TX-SR606
Harmony Ultimate
Eclipse01 is offline
Reply LCD Flat Panel Displays
