UN65J6300 Sometimes Refuses To Show Video - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 06-30-2016, 08:06 PM - Thread Starter
Liked: 0
Question UN65J6300 Sometimes Refuses To Show Video
Not sure if this is the place to ask this kind of question, but I will give it a try. I am having an issue with my Samsung UN65J6300 that I can only describe as - it sometimes does not want to show video of any kind. This has been an issue since I purchased the TV about a year ago, but has become much more frequent recently. It is sort of hard to explain, but hopefully this is a known issue with a known fix.
Basically, what happens is, I turn on the TV which should default to my antenna input. I can tell that the input is set to antenna (according to input selector and channel info), but the screen just remains black. Then I can try to change input to a SmartHub app like YouTube, and it will load the app and I can select a video to play, the the video will not play. Then I try to exit the app and try to play a video from the connected USB drive, and it will say something like 'unsupported format'. So no matter the source is, the TV just doesn't want to show video. I turn it off and on again, I plug and unplug, and that doesn't seem to consistently fix it. It just seems to magically start working eventually.
Any ideas at all?
rrm74001 is offline
Reply LCD Flat Panel Displays
