60" LCD or 55" OLED? - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By Latinoheat
  • 2 Post By Latinoheat
post #1 of 9 Old Yesterday, 06:09 PM - Thread Starter
mc4saints's Avatar
Quoted: 32 Post(s)
Home has a built in that max size is a 60". It would fit about perfect. Leave about an inch left and right of TV. I sit about 11' back from TV. Room is not super bright and lights are dim for most viewing. Slightly off angle seating right of TV but not extreme.
As you know, 60" TV is a dying size. Best tv's available are the Samsung KS8000 and LGUH8500. It's either one of those or an LG B or C6.
I don't think I am a videophile but OLED does look great in store. I currently have a 55" Sony XBR850c that I am happy with. Honestly, If they made the 850c equivalent in a 60" I would probably just buy one. Is that extra 5" worth the supposed sacrifice in picture quality?
On a side note.... C6 curve or B6 not curved? WebOS work as well as Android TV? My old harmony remote going to be able to jump from option to option since it will not have pointer option?
Thanks in advance for all replies and opinions.
mc4saints is offline
post #2 of 9 Old Yesterday, 07:53 PM
Latinoheat's Avatar
Quoted: 1081 Post(s)
Liked: 829
Why upgrade if your happy with your Sony 850c?
EscapeVelocity likes this.
Media room- LG 4K OLED EG9600, Pioneer Elite VSX-90, Samsung 4K K8500, Klipsch Gallery G28's, Klipsch Sub 12, Klipsch RS-52 II, Optik HD cable
Living room- Sony 4K 79XBRX900B, Onkyo RC-360,HTPC, Klipsch Reference R-62II, Rc52II,PS4
Gaming room -Panasonic ST60, PS3, Wii
Latinoheat is online now
post #3 of 9 Old Yesterday, 08:28 PM - Thread Starter
mc4saints's Avatar
Quoted: 32 Post(s)
Fair question and I may just stick with the 850c but I am tempted by a larger TV and OLED.
Sent from my SM-G935T using Tapatalk
post #4 of 9 Old Yesterday, 09:46 PM
Latinoheat's Avatar
Liked: 829
If you want to upgrade, I would upgrade in pic quality instead. Going from a 55"-60" isn't a huge difference in my opinion. Going Oled makes more sense as the picture would be an upgrade.
EscapeVelocity and jra2k1 like this.
post #5 of 9 Old Today, 08:12 AM
jra2k1's Avatar
Quoted: 37 Post(s)
I say go with OLED unless you you are tempted by 65" or larger then it's harder in my opinion.
jra2k1 is offline
post #6 of 9 Unread Today, 11:09 AM - Thread Starter
mc4saints's Avatar
Quoted: 32 Post(s)
Thanks. I cannot fit a 65" without major construction on the built in.
post #7 of 9 Unread Today, 11:19 AM
Liked: 0
Too far to see much difference between Full HD and Ultra HD
If you are sitting 11' away from screen then Ultra HD / 4k won't look any better than Full HD / 1080p until you get to 85" plus diagonal screen size. Rtings.com has a good explanation of the physics of this.
I have a Samsung KS8000 and like it but off-axis viewing degrades quickly. Again, Rtings.com KS8000 review shows picture quality off-axis so you can judge for yourself.
If you can't sit closer or get bigger then I would improve the sound or buy more software instead of upgrading TV.
TheScottSwanson is offline
post #8 of 9 Unread Today, 02:35 PM - Thread Starter
mc4saints's Avatar
Quoted: 32 Post(s)
Thanks. Not even the better contrast or better blacks of OLED is going to be noticeable from 11'?
post #9 of 9 Unread Today, 02:53 PM
audacious nick's Avatar
Quoted: 148 Post(s)
Liked: 130
Depends on how dark your room is. If you have the lights on while viewing, the light control weakness of an edge-lit LCD are not easily visible. If you're in a dark room, it's blatantly obvious that the OLED has much better blacks and much better light control.
65" KS9000 and 49" KS8000
Infinity Overture 3
Definitive BP-2000
Denon AVR-2307ci
SVS PB-2000
audacious nick is online now
Reply LCD Flat Panel Displays
