Avera Eqx10 Service Menu Settings? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-22-2017, 02:04 PM - Thread Starter
Quoted: 121 Post(s)
The 40" version of this set makes for a nice low lag gaming monitor, but a lot of the settings I change in the service menu default back when the input is changed. I disabled "VIP", which seems to control local dimming, and I also disabled dynamic contrast, I set the pwm frequency from 25000 (whatever that's supposed to do), to a more reasonable 240 or 480 for decent motion performance, but it doesn't save the vip setting nor the pwm frequency. It's a shame really because those seem to be the most important settings for incredibly low lag and good motion performance with backlight strobing/flickering. Has anyone got this set figured out/dialed in and saved? This could have been such a nice displays if it had been properly factory calibrated and more options were available in the user menu.
AVMB is offline
post #2 of 2 Old 09-22-2017, 05:18 PM
BruZZi's Avatar
Quoted: 61 Post(s)
Liked: 123
I have tons of service menu access codes for so many different brands. A bunch of them have detailed info on how to navigate and save settings. Unfortunately I don't have a single one for Avera. Tried some sources for the service manual with no luck. Hopefully someone will post that info for you.
BruZZi is offline
Reply LCD Flat Panel Displays
