Conference Room display for Autocad suggestions please - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-25-2017, 09:24 AM - Thread Starter
Super Moderator
markrubin's Avatar
Quoted: 1297 Post(s)
Liked: 2785
Looking to replace a really old Pioneer PDP-503 plasma display in a conference room used for Design Reviews using PowerPoint and Autocad 3D from a WIN 10 laptop
figure a 65-70 inch LCD display will do it: it must natively accept a PC resolution via HDMI
any suggestions?
The old Pioneer still works and has no burn in, but it is time for it to go
please take the high road in every post:do not respond to or quote a problematic post: report it
HDMI.org:what a mess this is a red flag issue
HDCP = Hollywood's Draconian Copy Protection system
Test Reports HDMI Cables that support 18GBPS&HDMI 2.0b
markrubin is offline
post #2 of 4 Old 09-26-2017, 09:45 AM
Quoted: 484 Post(s)
Liked: 149
Well, initial thoughts are an IPS panel if gamma shift and color shift over an angle are important, but stay away from any of the LG models under the SJ8500 as they use the WRGB pixel format and only have something like 2880 hprizontal pixels (while still having 2160 vertically). Are viewing angles a major concern? Also, is there a rough budget?
dkfan9 is online now
post #3 of 4 Old 09-26-2017, 09:49 AM - Thread Starter
Super Moderator
markrubin's Avatar
Liked: 2785
thanks for the response: viewing angle is not a concern
this one looks like it would work:
https://www.amazon.com/gp/product/B0...3P7C8THK&psc=1
post #4 of 4 Old 09-26-2017, 10:43 AM
Quoted: 484 Post(s)
Liked: 149
Yeah, I think either that or the Vizio E series are your best bets at 65", depending on your trade off between brightness and cost. At 70, it looks like it's probably the Vizio E (with the Sony X690E a little pricier with the same set of features and performance for the purpose).
Reply LCD Flat Panel Displays
