Any Syntax Olevia owners out there? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 865 Old 08-13-2004, 08:30 PM - Thread Starter
Ted Chase's Avatar
I recently began researching 26" - 30" LCD Flat Panels to replace my old second set, which finally died at the age of 20+. I started with the "Interesting 30 LCD" thread and saw a few posts mentioning the Syntax Olevia, whose specs looked pretty promising.
With all the spin-off talk about the Sceptre, the Syntax seems to have dropped out of sight in the AVS Forum, but, in my neck of the woods (Ontario, Canada) there's at least one retailer (tigerdirect.ca) that claims the Syntax 30" and 27" are its two biggest sellers. I think the 27" can be found for as little as $[MSRP ONLY] US.
Are there some happy (or unhappy) Syntax owners out there who can suggest whether or not it's worth considering? Or enough interest to start a thread.
I've pretty much decided to take a gamble on the 27".
tedc
Ted Chase is offline
post #2 of 865 Old 08-15-2004, 07:46 PM
Daleon's Avatar
Just got finished setting up the LT27HV. This is my pc/tv, as I've always used my old 21" for viewing tv.
First hooking up to PC. (Doesn't come with a dvi cable, unlike the Micro Center sales person who told me it did) So just using analog. I get video during boot of the text, which cuts back and forth alot on each screen change. As soon as windows loads, blue screen. And I don't mean BSOD, just the no video kind. So I figure I'm running at a rez/refresh thats not supported. Boot into safe mode, and it works at 800x600. Now booting into safe mode and saving your video settings is supposed to knock your normal windows settings down also, atleast it used to. Doesn't seem to anymore. So hooked up old monitor, set to 640x480 and 60 hrz. Connected the Olevia back up, and still blue screen in windows. Getting tired of disconnecting vga cables, and as I had a new Maxtor 250 HD I had been planning to switch to, I start up windows setup.
Windows reinstalled and the Olevia is working in windows. The screen is about 1-2" over to far to the left. Not to worried about it yet. Install windows updates. Install DX9b and boom, screen is dead center and looking nice. My video card refresh is still crap as no drivers loaded for my Radeon 9800 Pro. So load those, and then ..... My text is now kind of odd. Almost like the contrast is to high making some of the lettering fade out. Hard to explain, as its still freaking awesome looking but not as "soft" as it was before I loaded the drivers. Hoping maybe DVI cable will help fix this.
One note, I do reallllly wish I had the extra money for the 30". As 1280x720, wtf is that. I didn't even realize its not a supported PC resolution. The 30"'s 1280x768 would be highly preferred as right now I'm just doing 1024x768. So I can't even do the monitor's natural resolution.
Second note, there doesn't seem to be any kind of inf for this montior. Just shows as a pnp monitor in windows. No sign of a driver on the syntax website either. This is not the way to get the best performance out of your monitor syntax, write a freaking driver with refresh rates supported.
I'll be updating my comcast digital cable box to a newer HD box and will post results on it. Now time to test what I bought it for, gaming.
Daleon is offline
post #3 of 865 Old 08-16-2004, 12:59 AM
genietime's Avatar
I'm pretty sure your ATI card supports 1280x720. Your "monitor" probably doesn't support this as a standard resolution. You probably need to use Powerstrip. I've heard of someone posting that they got 1280x720 via Powerstrip with this monitor; so I would think it's possible. Powerstrip is your friend.
With analog VGA try these timings:
1280x720p=1280,48,160,200,720,24,10,48,81000,2052
On my (non-syntax) 30" LCD I was unable to get 1:1 pixel mapping without Powerstrip via the VGA connector (I was successful with Powerstrip). However with a 9800 Pro via DVI, it automatically displayed NR (1280x768 in my case) the first time (which almost made me break down and cry after the suffering I had went through with my Nvidia card and the many hours I spent in Powerstrip). You might want to try DVI; you can get a DVI cable as cheap as $15ish if you just to try it out.
Once you see DVI @ 1:1 you'll never go back; this is the only way to run a LCD panel IMO.
genietime is offline
post #4 of 865 Old 08-16-2004, 01:54 AM
Daleon's Avatar
Well I've had a little more time to tweak on the system. I defintely had planned to give powerstrip a try. If it can set my resolution to 1280x720 and I can play that in games I will be happiest man alive. I'll defintely be getting a DVI cable. Is a "dual dvi" cable actually different than any other dvi cable? Better? Supported?
I also turned on truetype, this helped quite a bit to clear up the text in windows and surfing around.
So far, I am truly loving this LCD. As I said earlier, this is mainly my PC monitor for gaming, etc. And it is doing an incredible job. So far Doom 3 and EvE Online look absolutely spectacular. EvE was already a beautiful game, but wow it is like cinematic now. I feel like I am inside Blade Runner. Also tried City of Hero's. Didn't look as good as on my old 21" HP. I think because of the size of the screen and low res, 1024x768 is low now lol, that it causes quite a few jaggies. I tried knocking my AA/AF to max in windows, but this caused everything to start doing the limbo. Basically looked like the pixels were vibrating. I think I had this same issue with my old monitor also so I never usually manually configure my D3D settings like this. I'll try it at a little more moderate setting.
Daleon is offline
post #5 of 865 Old 08-16-2004, 09:48 AM - Thread Starter
Ted Chase's Avatar
In posting my original question, I mainly wanted to hear about the general satisfaction/dissatisfaction with the Syntax 27" or 30" as a TV, in particular its SD and HD picture quality. It's unlikely that I will be using mine as a PC monitor or for gaming, though the info on pixel mapping and DVI is still interesting.
Keep using this thread for the latter, but I'd appreciate hearing about the former, as well!
tedc
post #6 of 865 Old 08-17-2004, 04:29 AM
rednaxela's Avatar
(This is my first post on a forum ever. )
Just wanted to let folks know that there is a decent review on the Syntax LT30HV on Anandtech.
(Unfortunately I'm not allowed to post links yet, I'm too new.)
It notes the lack of drivers and the necessity of PowerStrip. It also gives good marks for the LCD in general based on features, color reproduction and gaming. The review is dated late in June.
To add to Ted's list of questions, I have the following:
1) Does the multiple "grid" display feature exist on the LT27HV ?
2) Does either unit accept the HD signal from satellite or Digital Cable?
3) And for those who have seen the actual displays sidebyside; Is the 30" (2.2"wider and 2.2" taller) screen worth the extra $300-400 in your opinion?
rednaxela is offline
post #7 of 865 Old 08-17-2004, 06:54 AM - Thread Starter
Ted Chase's Avatar
Thanks a lot for steering me to the anandtech review, which is generally positive.
All the info I've seen on the Syntax suggests that the 27" and 30" have identical electronics, inputs and outputs. They differ only in panel size. So, both have the "grid" display feature, and both will accept HD feeds from satellite or cable boxes, via either the component or DVI inputs.
As for the last question, it depends on your personal needs and preferences (viewing distance, shelf or wall space etc). For me, this will be a second TV/DVD display (not really used as a PC monitor or for gaming), so any driver/powerstrip inconveniences are not really an issue, and 27" is more than ample, since it is replacing an old 20" 4:3 set. However, the general wisdom seems to be: if your room and your budget can handle the larger screen, go for it!
tedc
post #8 of 865 Old 08-17-2004, 07:34 AM - Thread Starter
Ted Chase's Avatar
Having now taken the time to carefully read the complete Anandtech review, I'm feeling pretty good about my decision to take a chance on the Syntax, especially given its pricepoint. I encourage others to check out this review, though it requires a little patience to click through the various sections in detail. Bottom line: the Syntax appears to perform as well or better than some of the comparable, considerably higher-priced "brand-name" LCDs on the market. Hopefully, more folks will join this thread as the word gets out.
tedc
post #9 of 865 Old 08-17-2004, 10:11 AM - Thread Starter
Ted Chase's Avatar
For another, generally positive, review of the Syntax Olevia, you might want to check out Robert Silva's assessment at hometheatre.about.com.
He gives the Syntax 4 stars out of 5, noting that it performs strongest on DVD and HD material but less well for analog cable or VHS sources. Again, my own use will be limited to digital satellite TV (including HD) and DVD, so these limitations are of little/no concern to me.
tedc
post #10 of 865 Old 08-17-2004, 10:23 AM
pifcho's Avatar
Syntax should be out with a 32" lcd this fall, so you might want to wait. This would be their second cut at it, so hopefully they will improve on some of the original mistakes... Stats are 1366 x 768 resolution, 800:1 contrast ratio, 550cd/m2 brightness and a 16ms response time.
pifcho is offline
post #11 of 865 Old 08-17-2004, 11:21 AM
Daleon's Avatar
ATI just put our their 4.8 drivers with HD support, including 1280x720, woot. About to install them and crossing fingers it works.
Connected to my pc via dvi now and dvd's, especially widescreens like LotR's look very good. Hope to get my cable box upgraded to HD this week as std tv is just so so.
I saw the 27 and 30 side by side. It was actually rather hard to tell which was bigger. The 27 was also setup better I think, as the brightness looked much better than the 30. Worth it or not... wasn't for me. Even though I would have liked 1280x768 natural support for pc. For HT, I defintely don't think its worth it. Now the 32" coming out, there is a little more size difference there and may be better unit also.
Daleon is offline
post #12 of 865 Old 08-24-2004, 07:55 AM - Thread Starter
Ted Chase's Avatar
I just took delivery of my Syntax Olevia LT27HV yesterday. Overall, I'm extremely satisfied and pleased with what I got for the money. It may not have quite all the bells and whistles of comparably-sized "brand name" LCDs at twice the price, but I was able to set it up quickly, and easily adjust the picture quality to suit my subjective taste.
My 27" panel looks flawless (no dead or stuck pixels). As indicated earlier, I am not using this as a PC monitor or for gaming, so any shortcomings identified in those areas do not affect me.
The Syntax is my "second TV", and, at present, I am running only a digital satellite box (SD only, no HD yet) and a decent Zenith progressive scan DVD player through it. The PQ for the DVD is stunning (using the Zenith's component outs), and I'm quite pleasantly surprised at how good satellite SD looks (better than on my main TV, a 50" Sony Grand Wega LCD rear projection, where HD satellite really shines).
I've experienced no problems with the Olevia's remote, but then I'm only using it for on/off, volume control, video source and picture adjustment, since I have separate satellite and DVD remotes. A tech at Syntax had told me earlier that there is as yet no Syntax code for programmable remotes, but he said that the Harmony remote will recognize and control the Syntax (for whatever that might be worth).
On the negative side, I personally found the picture to be heavily red-pushed, a bit too vivid, and slightly fuzzy OOTB, but I set the backlight to soft and fiddled with tint, saturation, brightness, contrast and sharpness until it now looks very good, at least to my eye. I also found that the speakers, though quite decent, lacked bottom end. However, I took advantage of the subwoofer out feature, and, with an old sub I had from an earlier system, the sound is pretty good now too.
All in all, I'm very happy with the Syntax Olevia 27", keeping in mind my somewhat limited applications.
tedc
post #13 of 865 Old 08-24-2004, 08:09 AM
pifcho's Avatar
Congrats, Ted. Enjoy your new gadget!
Speaking of Syntax I read the following interview with Syntax's CEO -
http://www.digitimes.com/news/a20040818PR202.html
A couple of interesting things come out of it - the 32" set will be priced at $1799 and a 37-inch LCD TV is coming this October and a 40-inch model in the first quarter of next year. The 37-inch LCD TV will be priced at US$2,799 and will have an 800:1 contrast ratio and a 12ms response time, whereas the 40-inch one will be priced at US$3,499.
pifcho is offline
post #14 of 865 Old 08-24-2004, 08:13 AM
PanamaMike's Avatar
Was surprise to see on in a store. Looked pretty good up against the competition.
Mike
PanamaMike is offline
post #15 of 865 Old 08-24-2004, 09:53 AM
Paul Bigelow's Avatar
Saw that one at Fry's too. Great price. Originally, at Frys it was adjusted rather poorly with the brighness set *way* too high giving it a washed out look. Bringing down the brighness, giving the contrast a slight boost, and toning down the color helped a lot.
There is still some issue with contrast ratio and viewing angle and maybe grayscale tracking (not as good as other comparable sets) but sitting next to the Panasonic, Toshiba, and both Sharp 26" sets, it didn't look too bad -- at roughly half the price of the others.
Paul
Paul Bigelow is offline
post #16 of 865 Old 08-24-2004, 11:52 AM - Thread Starter
Ted Chase's Avatar
I'd meant to mention viewing angle in my earlier post. Syntax's claim of a 170 degree viewing angle is definitely bogus, unless it's simply meant to indicate that you can see "something" that far to either side. But, again, this is not a real issue in my case, since all seating positions in the room are within 45 degrees of the center, where the picture looks absolutely fine. Anyway, I recently checked out the viewing angle on a 26" Aquos (at twice the price), and couldn't really say it was noticeably wider than the Syntax.
As for contrast ratio, while the lack of deep blacks can be annoying, I tend not to notice it that much most of the time. LCDs aren't noted for having the best CR anyway, and I'm already used to that from my Sony GWIII.
tedc
post #17 of 865 Old 10-06-2004, 05:36 PM
tivoboy's Avatar
now that you have had it a while, can you update us on this tv? I am thinking of buying one, since the price has now hit oh bout 1K. Makes it a nice bedroom tv.
tivoboy is offline
post #18 of 865 Old 10-07-2004, 08:56 AM
jmorton's Avatar
I notice a Syntax press release this week with MSRPs of the following: 27in - $1,299, 30in $1,599, 32in $1,999, and 37in $2,999.
I have seen the reduction reflected in the 27 inch prices and there is a $100 rebate now on that model to boot. I haven't noticed a reduction in prices on the 30 inch model or a rebate. Most sites list prices above $1,599. I am wanting a 30 inch but am willing to wait a few weeks for the price to drop a little. LCD prices seem to be dropping across the board this week.
BTW, I emailed Syntax and they told me that the 30 inch model would remain in the lineup until sometime next year.
jmorton is offline
post #19 of 865 Old 10-07-2004, 10:09 AM
BobDobalina's Avatar
Still waiting for that 37'' model to hit stores myself... and hoping the reviews are good.
Anyone have any guesses what up-converting a 720p signal to 1080p for the 37'' model will do to the picture quality?
BobDobalina is offline
post #20 of 865 Old 10-07-2004, 10:39 AM
tivoboy's Avatar
Are you guys 27" owners, any feedback?
anyone seen this at a store?
tivoboy is offline
post #21 of 865 Old 10-07-2004, 10:50 AM
jmorton's Avatar
I saw the 27' at a local Fry's but you could tell NOTHING because the signal they were feeding all their TVs was horrible. Every model in the store looked bad. I am amazed that they expect people to spend from $1,000 all the way up to $20,000 on a TV based on what was being shown.
I asked about the 30" but they said they did not carry that model.
jmorton is offline
post #22 of 865 Old 11-15-2004, 12:48 PM
kruel's Avatar
I just got the 30" on Friday. So far so good.
I haven't yet gotten my iBook to do 1280x768 via VGA.
480p content looks fantastic. DVDs and games are super-duper sharp and beautiful.
I do, however, have one gripe. There are two component inputs: Y/Pb/Pr (480i, 480p, 1080i, 720p) and Y/Cb/Cr (480i).
If you plug a 480i source into Y/Pb/Pr, you get noise. That same 480i source plugged into Y/Cb/Cr is crystal clear. Syntax tech support claims that it's because all signals through Y/Pb/Pr go through a comb filter which results in 480i sources to appear noisy and garbled. They said that I should plug any 480i sources I have into Y/Cb/Cr and only plug progressive scan sources into Y/Pb/Pr.
That totally sucks. I use my Playstation 2 as my DVD player which is a progressive scan player, but most games for the PS2 are not progressive scan. So I have to keep my PS2 plugged into the Y/Cb/Cr input for games, then change the cable to Y/Pb/Pr when I want to watch a DVD or play a progressive scan game. Major suckage.
Other than that, the picture quality is surprisingly good, and the unit is very well made. Only one stuck pixel (blue) but I can live with that.
All that for only $1429, a $100 rebate, and $69 shipping (delivered next-day) from Amazon.com ($1398 total).
kruel is offline
post #23 of 865 Old 11-15-2004, 12:55 PM
bee01's Avatar
I'm a Syntax owner now!
Microcenter has a great price on the 30" Olevia this week. You can barely see it in their weekly ad scan on the web site, but the enlarge link leads to an old ad.
Can't wait to get it setup in the bedroom tonight.
bee01 is offline
post #24 of 865 Old 11-15-2004, 12:59 PM
90c4's Avatar
$1000 for this seems like a total steal - running out to get mine now.
90c4 is offline
post #25 of 865 Old 11-15-2004, 01:10 PM
tivoboy's Avatar
uh, where is it listed for 1K?
tivoboy is offline
post #26 of 865 Old 11-15-2004, 01:18 PM
Check **************.
Microcenter is having a big sale. Pretty crazy price... shame 30'' is a bit too small for me
post #27 of 865 Old 11-15-2004, 01:21 PM
jmorton's Avatar
If Microcenter is selling the 30" for $1,000 I would be all over that. I paid $1,500 for mine and I consider that a real bargain. $1,000 is a no brainer. I wonder if they really mean the 27"???
jmorton is offline
post #28 of 865 Old 11-15-2004, 01:23 PM
tivoboy's Avatar
I checked that, I don't see the 30" for 1K anywhere, checked the online add and FW.
Anyone have a link
I have looked at the 27" and find it poor compared to most other LCD's, wondering if the 30" is better. And, for 1K the 30" is a sweet deal indeed, just don't seem to find it for 1K.
tivoboy is offline
post #29 of 865 Old 11-15-2004, 01:36 PM
post #30 of 865 Old 11-15-2004, 01:37 PM
tivoboy's Avatar
thanks!
tivoboy is offline
Reply LCD Flat Panel Displays
