Philips 42PF7421D 42" LCD - Page 25 - AVS Forum | Home Theater Discussions And Reviews
post #721 of 733 Old 10-14-2007, 10:47 AM
madh83's Avatar
Does this tv pass through 5.1 DD? Also, has anyone tried a game like guitar hero on this tv, how is the input lag? Note that I'm not asking about blurring or ghosting but rather the delay of the visual processing.
madh83 is offline
post #722 of 733 Old 11-02-2007, 06:02 PM
maverick117's Avatar
I've played Guitar Hero III on it and there is not noticeable lag. It is spot on and I love this TV for all things gaming, movies and tv.
maverick117 is offline
post #723 of 733 Old 11-03-2007, 03:01 PM
hil357's Avatar
Question... I've had this tv for about 6 months now and lately it randomly starts making a whistling/whining noise which can be heard really clear out the top of it. Sometimes it sounds like there's something running hard inside it...
Any ideas what it could be?
hil357 is offline
post #724 of 733 Old 11-05-2007, 12:53 PM
SteveCaron's Avatar
Quoted: 85 Post(s)
Liked: 54
You may want to check to be sure it's not your cable box you are hearing. I know you mentioned that it was coming out of the top of the TV but, any sound emanating from below the set will sound like its coming from the set when standing above it. The new HD boxes with DVR make a lot of noise similar to what your describing primarily because, they are always running even for a minute or so after you have turned the thing off.
SteveCaron is offline
post #725 of 733 Old 12-10-2007, 08:41 PM
siknali360's Avatar
Im also getting this noise coming from my tv. I've also had my tv for about 6 months. My panel was manufactured in october of 2006. does anyone know of any firmware updates?
siknali360 is offline
post #726 of 733 Old 12-12-2007, 02:16 PM
chub's Avatar
Mine makes slight whining noise also, almost like interference, but all my A/V equipment is about ten feet away including the cable box. I have adjusted the picture to a lower contrast and brightness level it seems to help.
chub is offline
post #727 of 733 Old 12-12-2007, 03:19 PM
CheapB's Avatar
Quoted: 42 Post(s)
Mine has a high pitch noise from time-to-time - pretty annoying. I certainly want to get this fixed. This started after a year.
CheapB is offline
post #728 of 733 Old 12-13-2007, 09:52 AM
chub's Avatar
Yea, mine also has a high pitch noise, sometimes pushing the menu button on the remote activating the menu GUI makes it go away for awhile but it would be nice for a permanent fix.
chub is offline
post #729 of 733 Old 12-24-2007, 07:14 PM
kevnb's Avatar
anyone know how to change overscan settings?
kevnb is offline
post #730 of 733 Old 11-24-2008, 03:23 PM
Durbo20vT's Avatar
wondering this as well...?
The Ride
Ps3 500gb & Ps3 250gb
Xbox 360 Elite
Durbo20vT is offline
post #731 of 733 Old 12-06-2008, 06:54 AM
djshema's Avatar
My TV has an issue when going from HD channels to SD channels. The SD channels are all greenish. TO fix the problem I circle around between the channels on the tv (av 1, av2, av3,, then HDMI) and the problem is fixed. Untill next time. The problem does not occur every time, but 80% of the time.
ANybody having this problem?
djshema is offline
post #732 of 733 Old 12-29-2008, 12:05 PM
Pabgon's Avatar
Does anyone have the sony BDP-S550 or the panasonic DMP-BD55 blu ray player? can you comment about the blu ray picture quality on this tv? if any of you has or had both players, which one displays/ed the best picture?
Pabgon is offline
post #733 of 733 Old 12-31-2008, 07:27 PM
BLWedge09's Avatar
I realize this is a long shot, but if anybody has any ideas or knows someone from Philips that could tell me something definitely on this question, I'd appreciate it. Here's the issue I have with this particular model(42PF7421D/37). I subscribe to AT&T U-Verse service. There is an issue on some model televisions where during the HDMI handshake between the STB and TV, the proper HDMI video settings are not negotiated. It seems as though the STB is defaulting to the 0-255 scale while the TV is defaulting to the 16-235 scale. This is causing issues with crushed blacks etc on this particular model. My question is this: is there anywhere in the service menu, etc. that I'm overlooking where this might be able to be set manually? Some other sets will offer a selection such as the following.
Auto
-Detect signal automatically
-Color-1: Set digital video signal format to component 4:2:2
-Color-2: Set digital video signal format to component 4:4:4
-Color-3: Set digital video signal format to RGB 16-235
-Color-4: Set digital video signal format to RGB 0-255
I'd like to be able to set the HDMI input to manually use option #4 that I listed above.
For the moment, I've resorted to component cables to get a proper calibaration. However, the component output from this STB is noticeably softer than HDMI for some reason. I may be forced to just live with one or the other if no fix for this is available, but I haven't decided which is more tolerable yet.
Thanks for any info you might have.
BLWedge09 is offline
Reply LCD Flat Panel Displays
